Suspension problems - Mustang Evolution
Old 03-20-2016, 05:41 PM   #1
Dcauchon's Avatar
Suspension problems
Hi everyone. Need some help last week end I installed this kit..and since then I have noise like if something was loose...but it s all tight...any clues or anyone had thos kind of problem ? Thanks in advance
https://lmr.com/item/KYB-5300BAK/mus...ring-kit-05-14
Airaid Bama tune/Hood strut/MBRP axel back/ Lower control harm (red)
Dcauchon is offline   Reply With Quote
Old 03-20-2016, 05:46 PM   #2
FastFord13's Avatar
Was it done by a shop or yourself?
I had mine done by Mustang direct in laval, just springs and adjustable pan hard par 2 years ago and everything still great.
I would definitely get it checked out by them, they are awesome. I believe they are on the south shore now in St Constant.
Sent from the future.
Old 03-20-2016, 06:00 PM   #3
Dcauchon's Avatar
Did it myself....maybe I should have sent somewhere to get it installed...but it was so easy to do I figured I could it myself...I will have to see with Mustang Direct...just to make sure everything is ok..
Old 03-20-2016, 08:27 PM   #4
Hampton CIT's Avatar
What kind of noise? All the time or under what conditions?
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 03-20-2016, 08:59 PM   #5
Dcauchon's Avatar
Clinking noise as if something was loose, rear only
Old 03-21-2016, 01:55 AM   #6
Siber Express's Avatar
Did you put all the Spring insulators (rubber piece on the bottom coil) on when you put the new springs in?
Old 03-21-2016, 03:11 AM   #7
Being the rear makes it easier. Less difficult and few items to check. I'm assuming you methodically went through checking fitment/tightness of all your sway bar mounting points, upper and lower shock nuts, bottom coil of spring facing rear of car and ensure you put the isolator back on top of the new rear spring you installed to dampen where the spring contacts your car at its upper point. (I'm wondering if you laid the isolators to the side and forgot to reinstall them when putting it back together.)
Old 03-21-2016, 06:37 PM   #8
Dcauchon's Avatar
Hampton, what isolators are talking about, the back springs already some plastic on them...is this what you mean ?
Old 03-21-2016, 06:54 PM   #9
Bill does a good job in this video. FF to 10:50 seconds in.
Old 03-21-2016, 07:37 PM   #10
Dcauchon's Avatar
Voila
Old 03-21-2016, 07:38 PM   #11
Dcauchon's Avatar
2
Old 03-21-2016, 07:40 PM   #12
Dcauchon's Avatar
Part 2
Old 03-22-2016, 04:57 PM   #13
If I remember correctly when I did my LCA and relocation bracket, I had to put a bolt in at the top of the bracket to help secure it. Yours seems to no have it from that picture. Not sure though as you said it was when you installed the kit, not the LCA.
Sent from my Nexus 5X using Mustang Evolution mobile app
ibejt is offline   Reply With Quote
Old 03-22-2016, 05:15 PM   #14
Dcauchon's Avatar
Yes I am the one that did the job too...the LCAs, and everything else, and yes you are right I did not put that screw, anyhow tomorow its going to my mechanic to change water pump ( yeah it leaked) and he will look at it at the same time...so thanks fo all the inputs guys I will let you what was the prob. And sorry I tried posting pics yesterday night...bit it didnt work.
Old 03-23-2016, 08:25 AM   #15
Let us know what you find. I hear same kind of noise from my car too.
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 03-23-2016, 08:48 AM   #16
Jza1736's Avatar
I just did mine and i think it's the 2 piece drive shaft. I get almost clicking noise
Sent from my SM-N920P using Tapatalk
Jza1736 is offline   Reply With Quote
Old 03-23-2016, 08:52 AM   #17
Dcauchon's Avatar
Yep I will...its in the lift as we speak, as soon as I have an update I will let you know.
Thanks
Old 03-23-2016, 09:01 AM   #18
Dcauchon's Avatar
I am suspectiing this part knocking together...
I m having a hard posting a pic !! how do we do it ?
Name:	relo brackets.jpg
Old 03-23-2016, 09:10 AM   #19
Jza1736's Avatar
I'll look at mine tonight, but i think when the suspension is compressed they are not that close.
suspension unloading problems Speed_Mister 1996-2004 Mustang GT 0 03-11-2016 08:46 AM
14 Track Package Suspension Problems Red Stallion 11 2011-2014 Mustang GT 11 08-17-2013 03:30 PM
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
Suspension & Steering Problems. megax29 Pre-2005 V6 Mustang 5 01-05-2009 05:48 PM
Rear Suspension problems BigL34461 Pre-2005 V6 Mustang 3 03-06-2006 01:58 PM
04:24 AM
