Check engine light flashing - Mustang Evolution
Old 03-26-2016, 11:00 AM   #1
Hi any ideas on why my check engine light flashes for about 60 seconds when I accelerate hard only sometimes and then goes off and everything is fine again? Dealer can't solve the issue because the light won't stay on and it only does it sometimes. It's a 14 v6 premium with no add ons or modifications to the engine.
Christy jo is offline   Reply With Quote
Old 03-26-2016, 11:15 AM   #2
jayochs's Avatar
are you sure it's the check engine light, and not the traction control light? if you're spinning the tires at all, traction control is gonna kick in and the light will go on and off
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 03-26-2016, 11:24 AM   #3
No it's definitely not that light, it's for sure the check engine light. It's only when I'm on the interstate and go to pass someone and I accelerate hard.
Sent from my HTC6525LVW using Mustang Evolution mobile app
Old 03-26-2016, 11:37 AM   #4
ZombieSlayer's Avatar
If you had a tuner, you could datalog it or have someone watching the diagnostic tool and try to catch the code while doing your thing on the interstate.
Other then that, have you tried leaving the battery disconnected for an hour to let everything reset?
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
ZombieSlayer is offline   Reply With Quote
Old 03-26-2016, 12:00 PM   #5
Yeah I have
Old 03-26-2016, 12:08 PM   #6
Definitely gotta catch the code then. Otherwise, you are spinning your wheels.
You can try checking your maf sensor and stuff. But i believe that kind of stuff throws a wrench light.
Old 03-26-2016, 12:09 PM   #7
I would just go through and make sure everything is plugged in and secure. What happens if you park it and rev it really high? Curious if it is speed related or rpm related.
Old 03-26-2016, 12:17 PM   #8
Hummmm not sure, I'll try it and let you know.
Old 03-26-2016, 12:25 PM   #9
natestang07's Avatar
It is a misfire
Old 03-26-2016, 12:33 PM   #10
If it is a misfire, maybe change the spark plugs and inspect your coils.
Old 03-26-2016, 12:35 PM   #11
Done that already too and car doesn't run bad at all.
Old 03-26-2016, 12:37 PM   #12
SouthernCyclone's Avatar
Misfire like Nate said. If your lucky and pull the code it will tell you what cylinders the misfire is on. If not you will just get a general misfire code.
SouthernCyclone is offline   Reply With Quote
Old 03-26-2016, 01:02 PM   #13
What kind of fuel are you using? Maybe try a fuel system cleaner in case you got ahold of some bad stuff.
Old 03-26-2016, 01:02 PM   #14
Ok thanks!
Old 03-26-2016, 01:15 PM   #15
I did that too lol. Dealership said could be bad gas so I put cleaner in it and only use top of line gas now.
---------- Post added at 07:15 PM ---------- Previous post was at 07:14 PM ----------
Someone said something about a possible vacuum leak or breather problem, idk.
Old 03-26-2016, 02:03 PM   #16
David Young's Avatar
Your 'dealer' can hook up something (some kind of box) that will remember the code or codes while you drive. You have a pretty new Mustang, let the dealer worry about it
David Young is offline   Reply With Quote
Old 03-26-2016, 02:05 PM   #17
What kind of "dealer" are we talkin?
Old 03-26-2016, 02:13 PM   #18
Ford dealership in Louisiana lol and yes at least it's still under warranty
Old 03-26-2016, 02:36 PM   #19
Ha ha
Old 03-26-2016, 02:54 PM   #20
heebe_geebe's Avatar
Wow still under warranty and they're blowing you off. Is it the dealer you got the car from? IMO Regardless I'd be hunting up another dealer...
2014 MCOA, V6 PREMIUM, PERFORMANCE PACKAGE, COMFORT PACKAGE, SECURITY PACKAGE, DEEP IMPACT BLUE WITH SILVER CUSTOM COBRA STYLE STRIPES, AIRAID TUBE, TINTED 35%, PIONEER 8000 NEX, REAR CAMERA, BORLA TOUR AXLE BACK, K&N FILTER. JLT OIL CATCH CAN, CUSTOM MADE HOOD STRUTS, BBK SHORTY CERAMIC
heebe_geebe is offline   Reply With Quote
Old 03-26-2016, 03:30 PM   #21
Junior Member
Isn't this typically a sign of detonation?
Sent from my SM-G900P using Tapatalk
gt_thunder is offline   Reply With Quote
Old 03-26-2016, 06:19 PM   #22
Yes it is the dealership I got it from
Old 03-26-2016, 09:35 PM   #23
Hawkstang's Avatar
Region: Iowa
It is a misfire
This is correct. I had this happen on my last car (2006 CTS) and it happened more than once, all on hard accelerations.
Turned out I had three coils go bad. When I asked the tech how 3 could go bad all at once, he didn't have an answer, though my amateur guess is one was bad and the other two on that side over compensated?
Bottom line is whenever your engine light flashes it's a misfire. Back off the gas and drive conservative until you get it diagnosed.
Mine was flashing once then stayed on and I could feel a considerable loss in power so I grannied it home and to the shop asap the next day.
Don't take chances with misfires. Good luck and keep us posted.
Hawkstang is offline   Reply With Quote
Old 03-26-2016, 09:39 PM   #24
Hawkstang's Avatar
Region: Iowa
You don't have a cold air intake do you?
Old 03-28-2016, 05:45 AM   #25
No sure don't but the misfire sounds about right because that's exactly how the car is acting and they did change a coil before I bought it and yes if I drive it normal it doesn't do it at all so I'll take your advice and don't accelerate hard if I don't have to until it gets fixed.
check engine
Flashing Check Engine light, Random Misfire code Crystalwilliams Pre-2005 V6 Mustang 5 10-14-2014 03:38 PM
Flashing check engine light Seanp94 2011-2014 Mustang GT 29 10-12-2014 08:30 PM
Flashing check engine light after hard pull Pancakes 1996-2004 Mustang GT 2 08-28-2014 06:52 PM
2013 V6 Check Engine Light Flashing vcantrell 2011-2014 V6 Mustang 8 06-22-2013 09:43 PM
Check engine light flashing!!! rich671 Pre-2005 V6 Mustang 8 09-14-2012 05:39 PM
» Members Mustangs
Other Toy
mjscc1
Pig
gtcpa
Add your Mustang
10:49 AM
