Steering Wheel Swap - Mustang Evolution
Old 04-04-2016, 12:51 PM   #1
parkerbickel's Avatar
Steering Wheel Swap
So I bought a steering wheel with audio controls for my 2011 Base V6 without audio controls. I read that to get the audio controls working you needed a Ford dealership to update the ACM. I called 2 different Ford dealerships, each being a hour away from me, one said that they might be able to but at the same time might not but it would cost $90 regardless and then the other dealership told me it was impossible because there was no wiring or power to the new buttons and basically I was an idiot for thinking I could. Has anyone done and can verify it can be done? I only spent $45 on a used GT wheel so I won't be out a lot if it can't, just want to know if it can or not.
2011 V6 Race Red - Roush Axle Back Exhaust, GT500 Steering Wheel, GROM Audio Bluetooth Module, Raxiom Aero Smoked Tail lights, Raxiom GPS
parkerbickel is offline   Reply With Quote
Old 04-04-2016, 01:47 PM   #2
nwewing's Avatar
From what I know about the steering wheel swap is as long as you aren't trying to use the sync buttons (since you have a base) then the dealership would be able to get basic audio controls to work with their IDS tool.
I am not 100% sure on this, but from what I have read it should almost be plug and play with the cruise control also. I would keep calling around and maybe read other threads and see what you can find out. I do know it has been done! Good luck!
nwewing is offline   Reply With Quote
Steering wheel swap 11 base gt? help. 94gtconvert 2011-2014 Mustang GT 4 04-21-2015 09:49 AM
2014 to 2010 steering wheel swap ShelbyNCGT 2005-2010 Mustang GT 5 10-04-2014 09:35 AM
Where can I find steering damper for 66 manual steering? Daniod9 Classic Mustangs 11 11-06-2013 10:19 AM
Steering wheel shaking, power steering? toro 2011-2014 V6 Mustang 3 05-04-2013 06:31 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
08:11 PM
