Restored to Stock Tune, Got code PO111 - Mustang Evolution
Old 04-05-2016, 10:37 AM   #1
DrDave's Avatar
I re-installed the factory airbox and restored factory program on my '14 Cyclone last night, took a 45 minute drive, all was fine. This morning she's throwing a code PO111, something to do with the intake air temp sensor. Anybody else ever have this? I've been trying to get her to pass inspection for 3 weeks, Steeda custom tune apparently bypassed O2 and Catalyst sensors for some reason, so we could not get O2, O2 heat and Catalyst sensors to set, mechanic said it had to be the tune. She's under 15K miles, with BBK Shorty Headers and BBK 73mm T/B and FRPP Axle Backs, beyond that she's stock. Kept in garage, Engine bay kept clean, no corrosion on connections (which were all unplugged/reconnected last night). Any suggestions?
DrDave is offline   Reply With Quote
Old 04-06-2016, 08:35 AM   #2
David Young's Avatar
You might have damaged the sensor, it is very delicate. You have to be careful and not hurt the little wire in it. It might not be seated good to. The sensor could be bad also. Here is a list of things that might be wrong
P0111 - OBD-II Trouble Code | BestRide.com
David Young is offline   Reply With Quote
Old 04-06-2016, 08:55 AM   #3
DrDave's Avatar
Thanks, but turned out to be a 'calibration soak' thing thankfully. Cleared the code, all is well.
Old 04-07-2016, 08:31 AM   #4
What is a calibration soak? And how did you fix the issue? Would like to get some knowledge
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 04-07-2016, 09:09 AM   #5
DrDave's Avatar
Calibration soak
As I understand from the article I read, when the ECU is initially flashed, it performs calibration functions for approximately 8 hours after you shut the engine down. When you start it up after that "soak" time it compares the intake air temp and the coolant temp, if there is too much difference between the two it codes PO111, which indicates a potential problem with the IAT sensor. Monday morning there was a 20 degree change from my garage to the driveway, hence the temp deviation. I cleared the code and it has not returned.
After the initial calibration, anytime the battery is disconnected, it goes thru another 'Calibration soak', but now, it's only 6 hours, so under similar conditions it's possible to throw a code; if that code is due to this Calibration soak' (I wonder who came up with that term?) clearing the code should be all that's needed.
Old 04-07-2016, 12:11 PM   #6
Learn something today. Thank you guys.
alfaromeo is offline   Reply With Quote
Old 04-08-2016, 08:42 AM   #7
Thank you for the explanation!!!
PO111 PapiJose 2011-2014 V6 Mustang 4 09-07-2015 09:52 AM
My restored 65 deere Taxman Pictures and Videos 7 01-22-2012 12:14 PM
91 GT restored exterior moving to motor.. Any ideas?? 91mustangGt New Member Introductions & Greetings 13 09-29-2009 12:11 PM
Alright guys all posts restored. Brent The Bar 3 11-17-2003 09:21 PM
04:28 AM
