Best / Safest way to jack up Mustang... - Mustang Evolution
Old 04-12-2016, 04:06 AM   #1
Slickmullet's Avatar
I've read various ways to do this but the information is all over the place. Some say use the differential. Some say don't. Some say use the K-member. Some say don't. I know the pinch welds are meant to be the OEM jacking spot. What are y'all using to jack there? Hockey puck? Wood?
Slickmullet is offline   Reply With Quote
Old 04-12-2016, 04:47 AM   #2
Robostang's Avatar
Not inexpensive but they work great.
https://www.zl1addons.com/index.php/...ackpads-detail
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 04-12-2016, 05:16 AM   #3
wmschoonover's Avatar
Seen on another forum for a different car but probably would work the same...
Hard rubber hockey pucks with a grove cut in them the size of the weld point. Very cheap and easy to make.
wmschoonover is offline   Reply With Quote
Old 04-12-2016, 05:24 AM   #4
Scott2's Avatar
Since I have had my car I have used the K-Member and differential for lifting without issue. When using the differential I use a phone book, a catalogue or thick cardboard pieces to apply less stress on the differential cover to avoid causing an issue with the seal. I have had a BMR K-Member for a number of years and made up a 2 x 6 with holes drilled to fit the steering bolts to position the 2 x 6.
Since this picture was taken I have made up 2 x 6 blocks that are two thick and three thick that are screwed together.
2 x 6 for BMR K-Member
In this picture you can see the Steering bolts I position the jacking board under.
I also installed sub frame connectors on my car and they make excellent jacking points. Using them as a jacking point will lift the whole side of the car.
I like to work on the underside of the car with the wheels resting on 12” Race Ramps wheel cribs. The wheel cribs while not cheap are light weight and very strong.
Old 04-12-2016, 05:56 PM   #5
tym_v6's Avatar
I place small blocks of wood just inboard of the pinch welds at the factory jacking points and lift with a floor jack.
Old 04-12-2016, 06:36 PM   #6
This is what I was thinking. Never has any issues? Where are you putting the jack stands?
Old 04-12-2016, 07:26 PM   #7
tym_v6's Avatar
No issues. If you use two blocks right next to each other inboard of the pinch weld, you can use one block for the floor jack and the other block for the jack stand.
Works great for me and the wood blocks can be had for a good price.
Old 04-12-2016, 07:41 PM   #8
Sounds good. Thanks.
You just use 2x4 blocks?
Old 04-12-2016, 08:14 PM   #9
Hawkstang's Avatar
Region: Iowa
I used the pinch welds when I dropped my pan last week and when I swapped out my wheels and they held up just fine. And I had it jacked up pretty high. I put the jack stand on the spots to the sides of it and it was all good.
If you go this route just make sure you don't get under the plastic side skirt and you should be fine.
---------- Post added at 09:14 PM ---------- Previous post was at 09:13 PM ----------
I want Scott's garage.
Hawkstang is offline   Reply With Quote
Old 04-12-2016, 08:32 PM   #10
tym_v6's Avatar
Originally Posted by Hawkstang View Post
If you go this route just make sure you don't get under the plastic side skirt...
My (former) dealer didn't get that memo!
Framingham Ford: avoid at all costs!
Old 04-12-2016, 08:37 PM   #11
Hawkstang's Avatar
Region: Iowa
Yeah dude, that place sounds like a nightmare. You should seriously lodge a BBB complaint. That's the only thing that gets through to those places.
Old 04-13-2016, 08:22 AM   #12
Strange Mud's Avatar
no help to OP, but Scott2 has a real nice ride
Old 04-16-2016, 07:58 AM   #13
Used the pinch welds and 2 1.5 ton scissor jacks. Then used jack stands for safety. I'll post a few pictures next time I jack it up. Definitely the way to go IMO.
Old 04-19-2016, 12:57 PM   #14
CyberCarnage12's Avatar
Maybe this diagram from Ford will help you:
CyberCarnage12 is offline   Reply With Quote
Old 04-20-2016, 06:31 AM   #15
David Young's Avatar
The 'pinch welds' are plenty safe and strong enough to jack up your Mustang. Ford Motor Company is not going to risk legal action over something as simple as this. Just saying.........
David Young is offline   Reply With Quote
Old 04-20-2016, 09:12 PM   #16
Pinch welds worked great for me. Very sturdy. The perfect jack seems to be a scissor jack from my experience.
Old 04-20-2016, 10:05 PM   #17
tym_v6's Avatar
I dunno...my dealer managed to peel one layer of metal away from the other on the pinch weld and deform it, so they do have their limits.
I'd much prefer supporting the weight of the car on a horizontal surface to spread the load instead of having essentially a point load on the edge of the pinch weld.
Best jack / jack stand points on '14 mustang. Noodles76 General Mustang Discussion 14 10-13-2015 01:10 PM
Jack & jack stand point Otis 2011-2014 V6 Mustang 6 10-15-2013 12:48 AM
1998 Mustang GT Best way to increase hp/performance? JDmustang98' New Member Introductions & Greetings 7 04-23-2010 09:57 AM
What's the best way to buy a classic mustang project car? wolfe Classic Mustangs 7 04-10-2010 03:18 AM
Best way to sell a mustang *WW* Zim The Bar 6 04-13-2006 11:08 PM
04:21 AM
