Nitrous, turbo, or pro? - Mustang Evolution
Old 04-15-2016, 06:13 PM   #1
iamcesarmiranda's Avatar
I'm looking into making my car just a tiny bit more faster if you know what I mean😉 lol if any of you have any idea or experience with any of these please comment!
How much is it to put nitrous onto our 3.7s?
What's the best of all three options?
I'm leaning toward pro charging it but I heard nitrous is a good, affordable mod to do. Thanks fellas
iamcesarmiranda is offline   Reply With Quote
Old 04-15-2016, 06:17 PM   #2
bamaboy2014's Avatar
You can run a 125 shot safely the kit cost ik not sure there is another discussion about nitrous kit cost
bamaboy2014 is offline   Reply With Quote
Old 04-15-2016, 06:26 PM   #3
How much would you say it'll cost to buy and instal?
Old 04-15-2016, 07:42 PM   #4
That I'm not sure man I just Google nitrous kits mustang 3.7 NX from Summit Racing is $720. Then a tune will cost some as well.
Old 04-15-2016, 07:43 PM   #5
Count Dragula's Avatar
Turbo everything. Can't beat it.
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-15-2016, 08:25 PM   #6
How much would that be ahha
Old 04-15-2016, 08:26 PM   #7
Just depends on how radical you get lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-15-2016, 08:56 PM   #8
Ahah btw guys I'm on 2.73 gears rn, should i get my 3.73 first? Or get my nitrous kit installed?
Old 04-16-2016, 05:24 AM   #9
Gears 373 will make a big difference
Old 04-16-2016, 06:52 AM   #10
That big of a gear change would make a huge difference. Usually going from 3.31 to 3.73 is a huge difference lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-16-2016, 08:51 AM   #11
Slickmullet's Avatar
Trade it in for a GT...
Slickmullet is offline   Reply With Quote
Old 04-16-2016, 02:08 PM   #12
I'm good.
Old 04-16-2016, 09:45 PM   #13
I'm good.
In all seriousness the cost of going one of these routes is substantial enough to warrant just upgrading to a GT maybe with the exception of NO.
Old 04-16-2016, 10:15 PM   #14
Lol I opened this thread just to see the "upgrade to a GT" comment. But I vote one for twin turbo. Your looking at about 6500 for jmp base kit.
2013 mustang v6 premium package
Powder coated gold metallic wheels
MPT ghost cam tune
Quarter window louvers
3.55 gears manual
2008 fz1
Chris44117 is offline   Reply With Quote
Old 04-16-2016, 10:17 PM   #15
Alrefire. Twins on his cyclone.
Adventure till you drop.
Old 04-17-2016, 12:10 AM   #16
I don't really wanna have this conversation here. Thanks guys
Old 04-17-2016, 12:24 AM   #17
I'm a v8 guy through and through but I'll never tell someone else to get one just cause they have a v6 or 4 cylinder. The new v6s can out run the motors in my car so in that particular case the v6 is superior than a v8 lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-17-2016, 11:27 AM   #18
No worries man. Just a suggestion. To each his own. Hope you find what you're looking for. Good luck my friend.
Old 04-17-2016, 11:30 AM   #19
I have a V6 Mustang so I understand where the guy is coming from. Just a suggestion.
Old 04-18-2016, 09:23 PM   #20
So I'm going with the nitrous kit, will keep you guys updated.
Old 04-19-2016, 05:58 AM   #21
Let us know I thought about it too!! Just curious how much it cost to get a bottle refilled
Old 04-19-2016, 09:41 AM   #22
Voltwings's Avatar
So i went ahead and did the math on this, because these are the kinds of things that will end up keeping me up at night.
For the sake of keeping things incredibly basic, i am comparing the cost of nitrous to ONLY the base procharger kit. You will likely need additional items, but i am only considering the base cost of the kit:
Base kit with forum discount: $5,475
Now nitrous is a little more tricky because of all the options. I am seeing prices go for around $700-$800 for single nozzle systems with WOT switches and window switches, so i will just call it $750. As far as refills, it looks like it just depends on shop and part of the country, i'm seeing prices reported anywhere from $3 a pound to $8 a pound -_- useless. I'll just run the math a few different times, its easy enough.
So when we consider the cost of nitrous is y= 30x + 750 ($3 a pound for 10 lbs + base cost of kit) and set that equal to y = $5,475 for the base procharger kit you get x = 157 bottles of nitrous before you break even. This of course is assuming perfect draining and perfect filling and exactly 10 lbs of nitrous each time. I can tell you that its likely not the case, and you will never get perfect filling / draining, but i cant tell you by how much. Here's a few different scenarios depending on cost:
$3 / lb = 157 bottles.
$4 / lb = 118 bottles.
$5 / lb = 94.5 bottles
$6 / lb = 78.75 bottles
$7 / lb = 67.5 bottles
$8 / lb = 59 bottles
Now, as far as how long a bottle lasts, i found a NX calculator that basically states you'll use about .8lbs per 100 hp (sprayed) per 10 seconds. So lets assume a bolt on 3.7 with a 100 shot is making around 400 whp and running about 12 seconds flat. If you're running a 12 second pass, thats 20% more than the 10 seconds in the calculator, so multiply .8 * 1.2 and you get about .96 lbs of nitrous used per pass. Take that number applied to our number of bottles and you'll basically get the number of passes to break even:
$3 / lb = 157 bottles. / .96 = ~163.5 12 second passes
$4 / lb = 118 bottles. / .96 = ~123 12 second passes
$5 / lb = 94.5 bottles / .96 = 98.5 12 second passes
$6 / lb = 78.75 bottles / .96 = 82 12 second passes
$7 / lb = 67.5 bottles / .96 = 70 12 second passes
$8 / lb = 59 bottles / .96 = 61 12 second passes
Depending on the cost of nitrous in your area, the procharger very quickly becomes an appealing option, granted the cost is much higher up front. I'm fairly certain my math is all right, but i laid it out in case people want to check my numbers or run it a few different ways (quicker 1/4 times, larger shots, different FI options, etc). If i made any mistakes please let me know.
Old 04-19-2016, 08:16 PM   #23
You need to find a day job lol usually a 10 pound bottle is around 40-45 dollars. "Usually" lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 04-19-2016, 11:26 PM   #24
Voltwings's Avatar
Going back to school at the moment, so i find myself with a bit more free time haha.
Old 04-20-2016, 10:44 AM   #25
king_13's Avatar
Turbo if you like looking at the car on jack stands.
Pro if you like looking at other cars in the rearview.
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 04-20-2016, 10:47 AM   #26
ZombieSlayer's Avatar
MPT ghost cam tune
3.55 gears manual
2008 fz1
I have to man I am sorry!!!!
But I say 5.0...
But I know you said this so I would say Turbo if any new plans come up..
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
Follow me on Instagram: https://www.instagram.com/kevin.cook2016/?hl=en
ZombieSlayer is offline   Reply With Quote
Old 04-20-2016, 01:14 PM   #27
Voltwings's Avatar
You get it now don't you Kevin, welcome to the dark side. Nice car BTW.
Old 04-20-2016, 01:17 PM   #28
Yes. After driving my 3.7 for awhile and it having a ton of mods, it only took 1 drive in the 5.0 to realize how big of a power gap there still is between the two. And that was with driving a stock 5.0.
And thanks for the compliment. I am still pinching myself to make sure this is real.
Old 04-20-2016, 03:49 PM   #29
So you're saying nos will have my car in the shop? Can you explain please
Old 04-20-2016, 04:54 PM   #30
nwewing's Avatar
I think what he is trying to say is that if you go with a turbo your car will seem to always have something wrong do to the complexity of a turbo system. While if you went with a procharger you will instead have a more reliable and a lot faster car than you do now.
Personally my choice would be procharger, but thats just me.
2014 DIB V6 manual. FP6 Tech package.
nwewing is offline   Reply With Quote
Old 04-20-2016, 07:12 PM   #31
But I say 5.0...
Congrats on the big upgrade man.
MPT ghost cam tune
3.55 gears manual
2008 fz1
Old 04-20-2016, 07:52 PM   #32
king_13's Avatar
This.
I said nothing about NOS, which is a good option in my opinion if you aren't going to race it often, otherwise it'll get real expensive real quick.
If this car is your daily, SC or NOS would be my choice hands down.
If you have another vehicle to get to work, then a vacuum leak or a bearing issue wouldn't be as back breaking.
Old 04-20-2016, 08:42 PM   #33
JimC's Avatar
This.
NOS is the ricer term for nitrous - NOS is a company that makes a kit (Nitrous Oxide Systems), just like Zex, Nitrous Express, etc. So I don't know that NOS is any more likely to cause issues than any other kit if it isn't set up properly.
Nitrous is great, just get a proper tune for it. The only drawback is the ongoing cost of filling the bottle. You also will need a heater - cool evenings and early spring or late fall racing will hurt performance because you can't keep the bottle pressure up. And nitrous is a track only power adder. You can't keep it hooked up and on all the time because the pressure will wear on your solenoids. So it isn't like a supercharger or turbo where you have power on demand at all times.
Also, you need a window switch to control the nitrous. Start flowing too early and low in the rpm and you will have problems; don't rely on the switches that are supposed to read when you are at WOT before firing. I had that on my 2006, and at the track lining up pulling into the staging beams the system decided that 1,800 rpm was WOT and fired making the car jump ahead very quickly. I was lucky enough that time to lift quickly.
The window switch will stop the system from seeing anything as far as a signal until you reach your pre-determined rpm "window" to open the system.
JimC is offline   Reply With Quote
nitrous
Running a bigger shot of nitrous / NITROUS GUYS Jsmorley81 2011-2014 Mustang GT 5 02-14-2014 02:31 PM
Pro-m 3" pro tube 92coupe 1979-1995 Mustang GT 6 10-30-2013 07:45 AM
turbo, pro charged, or super charged? 03gt5.4l 1996-2004 Mustang GT 7 03-01-2012 09:50 AM
Nitrous Express wet nitrous kit Zim Mustang Parts for Sale and Wanted 24 06-15-2005 01:43 PM
Pro Turbo Kits Seph Pre-2005 V6 Mustang 3 03-28-2004 11:51 AM
09:29 AM
