2014 mustang v6 perm pack - Mustang Evolution
Old 04-16-2016, 07:24 PM   #1
4lexC's Avatar
Hey guys
On my way home tonight and started smelling something like it was burning. I pulled up to my place and looked under the vehicle. When I did I saw rusty colored fluid, almost like it was spilled over and dripping.
I thought transmission fluid. (I have a manual transmission) I drove it around some more and it's not leaking. I was more "on the throttle" than I normally am but idk what caused such a "spill" and then no more "leaking. "
Is there a overflow valve or something crazy lol. Please if you have any info if like to know before I go to Ford.
I attached an image(yes it's dark) but it's in that area where leak is dripping to.
Name:	ImageUploadedByMustang Evolution1460856263.718172.jpg
4lexC is offline   Reply With Quote
Old 04-16-2016, 08:00 PM   #2
Hawkstang's Avatar
Region: Iowa
Didn't I see some people on here saying that the water pump is suspect on our Stangs? Could that be leaking and the fluid mixing with some of that rusty residue that is on your pully wheels?
Just shooting out an idea.
Hawkstang is offline   Reply With Quote
Old 04-16-2016, 08:05 PM   #3
4lexC's Avatar
Very good possibility. Didn't even register. Whatever it was is on the ground and oily though. Sorry don't know too much about that stuff I'm more of an electronics guy lol
Old 04-16-2016, 08:29 PM   #4
Hawkstang's Avatar
Region: Iowa
It's the right area for it and the coolant has a slick texture to it. It does make a bad smell if it spills onto hot parts. I'd get it to the shop asap.
Good luck
Old 04-16-2016, 08:34 PM   #5
4lexC's Avatar
Girlfriends dad came and looked he said antifreeze (his dad was a mechanic). Is there any pipes running underneath the engine where it could of leaked ?
Old 04-16-2016, 09:05 PM   #6
Hawkstang's Avatar
Region: Iowa
Antifreeze is your coolant. 99% sure it's your water pump.
Old 04-16-2016, 09:17 PM   #7
Hawkstang's Avatar
Region: Iowa
Read this thread...
Pump
Old 04-16-2016, 09:59 PM   #8
4lexC's Avatar
Yes it was red and that must be the wrong link or either you're trolling lol
Old 04-16-2016, 10:26 PM   #9
Hawkstang's Avatar
Region: Iowa
Trolling? Help yourself then, I've got better things to do.
Old 04-16-2016, 10:44 PM   #10
DiESeven's Avatar
The mobile app isn't known for redirecting people to the right link.
Instagram: @v6beast
Old 04-17-2016, 04:12 AM   #11
David Young's Avatar
Could be a hose leaking somewhere but its probably the 'weep hole' on your water pump. Its a little hole on the bottom of the water pump that leaks when the bearings are worn out.
Shouldn't call someone a 'troll' just because of, ****ing trying to help you out.........
David Young is offline   Reply With Quote
Old 04-17-2016, 04:25 AM   #12
Strange Mud's Avatar
2012 leaking coolant. Help!
fyi Hawk ain't a troll
see bit about overflow hose.
Mud
Old 04-17-2016, 04:53 AM   #13
Siber Express's Avatar
Mud
Next you will say I 'm not too
Water pump, should be covered under the 5 year/ 60,000 mile power train warranty and make sure the dealer changes out the little hose that goes from the thermostat housing to the degas tank.
Old 04-17-2016, 01:27 PM   #14
Sorry dude.....
Old 04-17-2016, 06:24 PM   #15
bigmac3's Avatar
My '11 spewed all of its water out the bottom of the pump. Made it to the dealer without any damage and was replaced under warranty. Only problem I have ever had and that was four years ago.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 04-17-2016, 06:43 PM   #16
Hawkstang's Avatar
Region: Iowa
Any chance they fixed it by the 2014 model?
Old 04-17-2016, 06:57 PM   #17
bigmac3's Avatar
No clue. Apparently the replacement fixed the problem.
Frank
Old 04-18-2016, 12:53 AM   #18
iguanaman3's Avatar
As far as I know the 2014's did not have the correct degas hose with the backflow valve either. Ford has blamed premature water pump failure on the "faulty" hose so I have replaced mine on my own...so far so good at 40,000 miles.
iguanaman3 is offline   Reply With Quote
Old 04-18-2016, 04:24 AM   #19
look at the hose yourself, the updates one has a clamp and a small piece (check valve) in the middle. I would bet beverage they did change it to the updated one.
Old 04-18-2016, 05:14 AM   #20
I bought one from my dealer. Part number ER3Z-8276-A.
Old 04-18-2016, 06:07 AM   #21
Hawkstang's Avatar
Region: Iowa
Awesome! Heck that's all it is? Looks like a very easy swap, right?
How much did it cost?
Thx!
Old 04-18-2016, 08:11 AM   #22
It's around $20.
Sent from my LG-D850 using Tapatalk
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 04-18-2016, 10:12 AM   #23
easy-peasy...I did it with a small pair of channel-locks no real coolant loss
Old 04-18-2016, 10:36 AM   #24
tym_v6's Avatar
Do the swap with the engine cold if you can. Coolant level will be lower in the degas bottle so less chance of spillage.
Old 04-18-2016, 02:17 PM   #25
Thx!
Yep. A little over $20 from Ford.
2014 mustang
For Sale: (NJ) 2014 Mustang GT - Oxford White, 5K miles, RECARO, TRACK PACK, BREMBO PACK jeffrey5.0 Mustangs for Sale and Wanted 5 12-23-2015 08:13 AM
2014 Mustang V6 Performance pack Brakes 4lexC 2011-2014 V6 Mustang 32 07-23-2015 08:08 AM
2014 mustang gt track pack 750rwhp suspension. Drivtrain. Etc.. brett.fries23 2011-2014 Mustang GT 10 02-18-2015 02:45 PM
2014 Ford mustang GT TRACK PACK BREMBO maxricher Member Garages 1 01-13-2015 07:53 PM
For Sale: 2014 track pack mustang parts Joey8 Mustang Parts for Sale and Wanted 8 11-10-2013 08:18 AM
11:19 PM
