Audio Help - Mustang Evolution
Old 04-23-2016, 04:03 PM   #1
Slickmullet's Avatar
Audio Help
So I have 2 wires in the trunk, I assume a positive and negative. I also have a set of RCA jacks in the back. There is a volume control on the dash. There is a power wire with fuse in the engine bay duct tape to the side. There is no negative. I assume this was a setup for a sub for the stock system. Is there no negative needed in the engine bay?
I'm looking to add a powered sub.
Slickmullet is offline   Reply With Quote
Old 04-23-2016, 05:05 PM   #2
papivo's Avatar
Is the power currently connected to the positive post?
2014 V6 Convertible Ruby Red Tint, Borla S-Types
papivo is offline   Reply With Quote
Old 04-23-2016, 07:00 PM   #3
The power wire is duct taped to the side of the battery because it's not in use.
I don't see a negative though?
Old 04-23-2016, 07:10 PM   #4
papivo's Avatar
It sounds to me like they may have grounded it to the chassis. Just need to find out where. Opinions vary in regards to where to ground an amp. I always grounded mine to the battery but I know some who experienced a whine so they needed to install an isolator between the alternator and battery to eliminate it. I do agree with your analysis that a sub and amp were probably installed.
Old 04-23-2016, 07:57 PM   #5
Looks like a professional install. According to the previous owner it was. What are the RCA cables for?
Old 04-23-2016, 08:00 PM   #6
papivo's Avatar
The RCA cables run into an amplifier and then the amp to the subs. Before anything is hooked up I would check out the head unit to see exactly what has been installed and how. It does sound like a good setup but better to be sure than sorry. The volume control would allow you to regulate the amount of bass from the subs.
Old 04-24-2016, 06:35 AM   #7
The head unit is the base stock radio. Does it have RCA jacks on the back? Seems like most OEM base HUs I've pulled do not.
Old 04-24-2016, 08:00 AM   #8
FastFord13's Avatar
Nope no RCA.
I had to tap into the rear speakers for my amp.
Sent from the future.
Old 04-24-2016, 12:55 PM   #9
papivo's Avatar
They probably used a PAC interface. It connects to your factory harness near the HU and provides RCA outs.
Help me build better car audio PureVenom Mustang Audio & Video 10 07-23-2008 02:28 AM
Car Audio Wiring - Help Needed! ChrisxF Mustang Audio & Video 2 06-04-2008 11:42 AM
help building an audio system 02whitemustang Mustang Audio & Video 8 08-28-2006 11:57 AM
audio help 1997grnstang Mustang Audio & Video 8 05-19-2004 10:44 AM
audio noob needs help Monkey Mustang Audio & Video 21 11-23-2003 08:57 PM
08:12 PM
