Bama Tune doing its job!! - Mustang Evolution
Old 05-04-2016, 09:47 PM   #1
Billymccrary3's Avatar
So here is a little comparison between stock and the Bama tune... Car has 2.73 gears and is automatic. Feel it could have ran better if had more favorable whether conditions and was spinning so much (stock wheels and tires can't handle the added power off the line)
Name:	ImageUploadedByMustang Evolution1462419912.116862.jpg
Instagram: @Alpha3.7
Billymccrary3 is offline   Reply With Quote
Old 05-04-2016, 09:58 PM   #2
Ferr's Avatar
Nice! I kinda wished I tracked my car before tuning it to see the difference, I guess I could set it back to stock still :p.
I know what you mean with the wheel spin though my car always wants to spin the tires. I have 3.31s with stock MCA wheels.
Ferr is offline   Reply With Quote
Old 05-04-2016, 10:35 PM   #3
jjoinson's Avatar
nice!
2016 GT Premium
jjoinson is offline   Reply With Quote
Old 05-04-2016, 11:35 PM   #4
TRMN8ER's Avatar
Feels great to see lower ETs after installing a performance mod
TRMN8ER is offline   Reply With Quote
Old 05-05-2016, 03:53 AM   #5
Want to help with that wheel hop get some LCAs! Ford Racing's LCAs helped mine a ton (it still does a little but not near as bad 😜)
Wheela is offline   Reply With Quote
Old 05-05-2016, 09:34 AM   #6
Voltwings's Avatar
Interesting to pick up 4/10ths and only 1 mph. Tells you a lot of that comes from tuning that auto to shift quicker rather than real hp gains. Get you an MPT tune and really see that mph go up
Old 05-05-2016, 10:01 AM   #7
MustangDawg's Avatar
Attachment 200610
Was that Bama's Race tune or Performance tune?
---------- Post added at 09:01 AM ---------- Previous post was at 09:00 AM ----------
Major
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 05-05-2016, 10:26 AM   #8
Definitely! That being said I don't know what it would have ran if I was was not spinning or wheel hopping... Plus we had a REALLY bad head wind coming at us so think that could have effected trap speed alittle?
Here's a run with alittle Click image for larger version
Name:	ImageUploadedByMustang Evolution1462465602.596169.jpg
ID:	200622higher trap speed
Old 05-05-2016, 10:29 AM   #9
Major
It was on the Bama Race tune... Once I actually get more mods for my car I'll probably switch over to MPT for a race tune and just daily on the Bama performance tune
Old 05-05-2016, 10:31 AM   #10
Voltwings's Avatar
Here's a run with alittle Attachment 200622higher trap speed
A head wind will most definitely affect trap speed. How were you launching? Just flooring it off idle or were you trying to stage it a little (gas and brake at the same time)?
Old 05-05-2016, 10:36 AM   #11
I was launching at about 1,500... Tried 2,000 like when I was stock but with the tune it just blue the tires off...
I just need bigger wheels then these stock 17's.... Do you think a staggered 19's would hurt the time? Or should I just go staggered 18's?
Old 05-05-2016, 10:43 AM   #12
Voltwings's Avatar
Depends on weight and how serious you are about getting that time down vs aesthetics as to whether you should pick 18s or 19s.
Old 05-05-2016, 11:26 AM   #13
What do you think the difference in time would be between 18's and 19's? Cause I'm hooked on going to the track every week so if it hurts my time to bad id rather go with the one that performs better vs looks better
Old 05-05-2016, 11:28 AM   #14
Voltwings's Avatar
Well like i said, it depends on weight. If you have an 18 thats 30 lbs a wheel or a 19 thats 21 lbs a wheel, the 19 will likely outperform the 18. Granted you still have to factor in the 18 will have more sidewall if you run the same height on both and that will (should) lead to a better launch with the right tire.
There's a lot that goes into it, its hard to just say one is better than the other.
Old 05-05-2016, 11:32 AM   #15
TRMN8ER's Avatar
Track every week?! Whew that's a lot of $$$
I went back to back weekends and now my tires are missing 40% tread and my clutch is murdered. But I know the feeling of the drag strip... such a rush.
Old 05-05-2016, 11:37 AM   #16
Voltwings's Avatar
how many runs did you do to go through half your tires...
Old 05-05-2016, 12:01 PM   #17
TRMN8ER's Avatar
18 runs the first night, 14 runs the second night; each night was at the track for roughly 4 hours. Running 275/35/20 M/T Street Comps with 4.10s @ roughly 400whp. I really beat the **** out of my car those nights, as it was my first time down at the strip... The strip is also untreated, so there's a lot of spinning going on. Was also doing light burnouts in the water box.
Old 05-05-2016, 02:35 PM   #18
Reaction time is where the pickup is coming from.
2013 RedMustang is offline   Reply With Quote
Old 05-05-2016, 02:46 PM   #19
TRMN8ER's Avatar
RTs do not affect ETs, unless you are heads up racing. You could react 5 seconds slower than your lane opponent but still have a faster ET down the track.
Old 05-05-2016, 03:00 PM   #20
Ya what he said... My fastest time stock was only me running so was not going for reaction time.
Old 05-05-2016, 03:04 PM   #21
Looks like the majority of the increase is from the 60' time. The MPH is an indicator of the car's power. You picked up 1mph.
Old 05-05-2016, 03:35 PM   #22
Like I said before traction and a really strong head wind coming at us most likely effected my trap speed
Old 05-05-2016, 06:18 PM   #23
Slickmullet's Avatar
I'd say pretty nice pick up from the tune.
2012 Race Red 3.7 Coupe: Steeda CAI and 93 Steeda Tune / Borla S-type Axle-Backs / Boss Strut Tower Brace / FRPP 3.55
Slickmullet is offline   Reply With Quote
Old 05-05-2016, 08:14 PM   #24
Hawkstang's Avatar
Region: Iowa
If you ever replace those heavy stock wheels you will be chirping in 2nd
Hawkstang is offline   Reply With Quote
Old 05-11-2016, 08:51 PM   #25
No change! Still stock with tune and Axlebacks!
Name:	ImageUploadedByMustang Evolution1463021454.418369.jpg
Old 05-11-2016, 08:54 PM   #26
Voltwings's Avatar
Attachment 200840
Sorry if i missed something, were you expecting a change?
Old 05-11-2016, 10:00 PM   #27
TRMN8ER's Avatar
Attachment 200840
Was that without headwind? If so, maybe that headwind was creating forced induction! Lol kidding... but Voltwings is here and he'd be one of the guys to help answer that.
Old 05-11-2016, 11:57 PM   #28
Ran 13.914 last time... still was winding but had better traction today... Stock- 14.349, Bama tune- 13.865
I was just saying "nothing changed" like I didn't add anything but got a new best
Old 05-11-2016, 11:59 PM   #29
Na still real windy! Just hooked better... I'm confused on your comment haha I ran faster this time 😂
Old 05-21-2016, 06:07 PM   #30
CyberCarnage12's Avatar
That's awesome. I have been thinking about getting a Bama tune myself so great seeing the actual real world gains
CyberCarnage12 is offline   Reply With Quote
Old 05-25-2016, 10:50 PM   #31
New best time by a little 😊 broke out though on this run because dialed 13.86 😅 think it was worth it though
Name:	ImageUploadedByMustang Evolution1464238185.182447.jpg
Old 05-27-2016, 10:55 AM   #32
b2673ad's Avatar
Hello
So you spent $600 plus dollars to go less than a 1/2 second faster in a 1/4 mile?
Kevin C.
2015 Roush RS1 Premium w PP
Roush Performance upgrade-- Tinted Windows
JLT Catch Can--Ford Racing Strut Brace
Flowmaster scavenger "Y" pipe resonator delete
b2673ad is offline   Reply With Quote
Old 05-27-2016, 11:08 AM   #33
b2673ad's Avatar
Hello
Kevin C.
Old 05-27-2016, 11:24 AM   #34
DiESeven's Avatar
Originally Posted by b2673ad View Post
Hello
What's your point?
Instagram: @v6beast
Old 05-27-2016, 02:47 PM   #35
b2673ad's Avatar
Hello
Keep feeding the machine, the never ending toss of money while drinking the Jim Jones Kool-Ade.
You will figure it out one day grasshopper.
Kevin C.
What all to replace when doing clutch job. PBrown92 1996-2004 Mustang GT 9 12-26-2013 06:45 AM
bama race tune > bama hybrid tune 13 stang22 2011-2014 V6 Mustang 11 04-16-2013 05:26 PM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
Question on installing Bama tune if previous tune already loaded on car ljn21 2011-2014 Mustang GT 7 08-01-2012 10:08 AM
11:08 PM
