Sway Bar Bushings - Mustang Evolution
Old 05-09-2016, 09:59 AM   #1
AssaultGerble's Avatar
Sway Bar Bushings
I don't know if anyone else has ran into this issue but after a number of hours of searching I cannot seem to find Poly bushings that will fit the rear sway bar on my car (2012 v6 Mustang w/ the Mustang Club of America Package). After measuring the Bar it appears to be 22MM. All of the bushings that i have found in poly are either 20MM or 24MM. Does anyone by chance know where I can order 22MM ones that are not just universal?
AssaultGerble is offline   Reply With Quote
Old 05-09-2016, 10:11 AM   #2
Strange Mud's Avatar
energysuspension.com | parts search
here you go...pay attention to the color choices. Red is more popular but black has graphite in it. I chose black (bought mine through summit)
Old 05-09-2016, 10:15 AM   #3
Thank you sir. But that is actually the first place I looked. They only offer 24MM ones that fit my car per their website.
Old 05-09-2016, 03:01 PM   #4
tym_v6's Avatar
OP, do you have the Performance Pack?
Old 05-09-2016, 04:19 PM   #5
No sir. Just the base setup suspension wise.
Old 05-09-2016, 05:14 PM   #6
tym_v6's Avatar
Gotcha. I have the Perf Pack and recall the 24 mm bar and there was an equivalent bushing in inches from Energy Suspension.
If you can't find anything on their website, I'd give 'em an email or call and see what they have.
That said, the factory end links are kinda poopy. You might want to upgrade to a Steeda or BMR unit while you have the thing apart.
Old 05-09-2016, 06:18 PM   #7
Voltwings's Avatar
Originally Posted by tym_v6 View Post
That said, the factory end links are kinda poopy. You might want to upgrade to a BMR unit while you have the thing apart.
Fixed.
Old 05-09-2016, 09:53 PM   #8
tym_v6's Avatar
Originally Posted by Voltwings View Post
Fixed.
Actually, I tried both and wound up preferring the Steeda units. You can service the bushings without taking the stabilizer bar off the car. Plus, the Steeda units use commonly available bushings vs. BMR's custom ones.
Old 05-10-2016, 09:15 AM   #9
I ended up just snagging a larger sway bar (24MM) from a scrapped GT for $25. Thank you all for the input though.
Old 05-10-2016, 09:33 AM   #10
good deal. + any parts from a GT add HP. My biggest HP increase for my V6 came from the Weather Tech floor mats from a friends wrecked Boss 302.
Old 05-10-2016, 10:50 AM   #11
Voltwings's Avatar
Not a super big deal, but something i feel inclined to mention. When going to a larger rear bar on a RWD car, the rear will have a tendency to rotate more. Again, not an issue unless you're really getting on it, but if they're $25, maybe grabbing the GT front bar to even things out wouldnt be a bad idea. You're also talking the difference of 2mm though, and on a factory bar at that, so again not a super big deal just something i thought i'd mention.
Old 05-10-2016, 12:01 PM   #12
Thanks for the input. It looks like the front sway bar on a GT is 34MM while the one on a V6 base is 33.2MM. Will 0.8MM really make that much of a difference?
Not a super big deal, but something i feel inclined to mention. When going to a larger rear bar on a RWD car, the rear will have a tendency to rotate more. Again, not an issue unless you're really getting on it, but if they're $25, maybe grabbing the GT front bar to even things out wouldn't be a bad idea. You're also talking the difference of 2mm though, and on a factory bar at that, so again not a super big deal just something i thought i'd mention.
Old 05-10-2016, 12:19 PM   #13
Diehard's Avatar
Thought the GT front was 34.6 mm same as the V6 with PP.
Old 05-10-2016, 12:37 PM   #14
also, is this something with the lighter V6 it ain't wise...idk I have fun with my car but not that much. I will say a slight increase in od will make a moderate increase in stiffness.
Old 05-10-2016, 12:43 PM   #15
Diehard's Avatar
The GT stabilizers are exactly the same as what's used on the V6 PP. Does a decent job on the V6, to the best of my knowledge.
Old 05-10-2016, 01:15 PM   #16
Hmm, LMR lists it at 34MM?
Old 05-10-2016, 01:26 PM   #17
Diehard's Avatar
A page from the 2012 Source Book..
Old 05-10-2016, 01:51 PM   #18
Attachment 200792
I stand corrected.
Sr adjustable panhard bar bushings Mustangreazon50 2011-2014 Mustang GT 11 04-23-2015 10:57 PM
Poly bushing replacement in PH bar and sway bar rear 5LHO 2011-2014 Mustang GT 0 02-21-2015 12:38 PM
'05 GT sway bar bushings and end links Fasted58 2005-2010 Mustang GT 2 03-03-2014 04:40 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
energy suspension sway bar bushings for 03 v6 Liltroy Pre-2005 V6 Mustang 0 01-20-2011 06:04 PM
11:18 AM
