Wheel questions - Mustang Evolution
Old 05-12-2016, 01:49 PM   #1
Wheel questions
I'm getting ready to purchase a new set of wheels for my 14. I want to be a little different than most so most of American muscle and latemodel restoration wheels are all too common. I found a set of wheels on summit racing that looks very similar to the wheels on the original Eleanor car. Which I am wanting my car to look like. But I'm not sure on the back space and off set of these will look good or even fit.
Front
http://m.summitracing.com/parts/vsw-1438865gmml1
Rear
http://m.summitracing.com/parts/vsw-1438965gmml1
That's the link. I compared the bs and offset to a set of fr500 on American muscle and the am wheels are 6.2in bs and +30mm offset. The summit wheels I want are 5.2 bs and +10 offset. They are 18x8.5 for the front. The ones for the rear would be 18x9.5 and have a 5.75in bs and +12mm offset.
Would these fit and look good without having any rubs?
Acaudill23 is offline   Reply With Quote
Old 05-12-2016, 02:03 PM   #2
MustangDawg's Avatar
Estimated Ship Date: 6/10/2016 (if ordered today)
They're nice, but that is one heck of a long time to wait since today is 5/11/16.
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 05-12-2016, 03:31 PM   #3
stang3.7's Avatar
Name:	ImageUploadedByMustang Evolution1463088565.859539.jpg
Just for reference these are 18/9 18/9.5 and 30mm 39mm respectively. I'm about 99% sure that's what I've got.
stang3.7 is offline   Reply With Quote
Old 05-12-2016, 04:22 PM   #4
Originally Posted by stang3.7 View Post
Attachment 200856
So you know the back space on those?
Old 05-12-2016, 04:24 PM   #5
How do you measure bs and offset? I really like these wheels but want to be certain they will fit and look good before I buy. And what's the factory v6 17x7 bs and offset for comparison?
Old 05-12-2016, 05:19 PM   #6
stang3.7's Avatar
Your backspace is a product of the wheel width and measured offset. If you have a 10 inch wide wheel with a zero offset your inside is 5 inches and outside lip is 5 in. If you have a (let's just say) +50mm offset. that's the length in mm that the hub of the wheel is aligned to the width. In basic terms a positive offset pushes the wheels in or under the car and negative offset pushes the wheels out. Does that make any sense?
Old 05-12-2016, 05:20 PM   #7
stang3.7's Avatar
It's kind of that same math concept as metric tire sizes and using the width and the profile to measure hight.
Old 05-12-2016, 05:33 PM   #8
stang3.7's Avatar
Yes my tears are +39 directly over top of left side and behind right.
Name:	ImageUploadedByMustang Evolution1463095894.844791.jpg
ID:	200866Click image for larger version
Name:	ImageUploadedByMustang Evolution1463095970.536638.jpg
Old 05-12-2016, 06:02 PM   #9
Well using that math and a online wheel calculator it says that wheel would be 12mm closer to the suspension and 66mm more stick out compared to my 225/65 r17 stock wheels. I hope I did that correctly. If so I think these will fit and do ok. As long as they wont rub anywhere I don't care about if they fill the fender or not. Just as long as they don't stick out of the fender any.
Old 05-12-2016, 06:28 PM   #10
stang3.7's Avatar
If you're going with the 18/8.5 and 18/9.5 I think you could use my tire set up and it be about right! I've got 255/45/18 and 285/40/18 nt555 g2
Old 05-12-2016, 07:22 PM   #11
I picked out a 255/45 18 and a 275/40 18 in Firestone Indy fire hawk. They look like the nt555 but have just a little more tread. They are like 1/4inch different in height so that's bout as close as I can get. If the websites math is correct.
---------- Post added at 01:22 AM ---------- Previous post was at 01:21 AM ----------
I appreciate the help!
Old 05-12-2016, 10:04 PM   #12
stang3.7's Avatar
285/40/18 is dead at stock hight (27") with 11.2 width. 275/40/18 is 26.6 hight and 10.8 width. Your 255/45/18 front will be 27.03 hight and 10 wide so your rear tire will be almost 3/8ths in shorter. Depending on the tire companys' size variations. Just a heads up.
Wheel is off center in wheel well. S197stanGT 2005-2010 Mustang GT 9 03-04-2013 02:55 AM
Questions about wheel spacers ArmyScout 1996-2004 Mustang GT 13 02-07-2012 09:18 PM
Wheel and tire questions- need help RVAStang05 Mustang Wheels & Tires 4 10-27-2011 03:43 PM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
Upgrade wheel questions DMAC Mustang Wheels & Tires 15 08-02-2004 03:38 PM
06:09 PM
