Transmission Check Valve - Mustang Evolution
Old 05-13-2016, 01:34 PM   #1
Ok guys I have a 2014 Mustang V6 Automatic, and this is something I keep seeing floating around. I am told you CANNOT flush this transmission because it has a check valve that keeps the fluid from circulating properly. However I am also hearing that when you bring it to Ford for servicing they flush it. I have also heard Ford just does a pan drop and does not flush it. The whole reason for this post is I am looking to buy a transmission flush machine and I have come across a few deals but don't know if I should or should not buy it. I mean if I can't use it on my 'stang why bother.
Logan541 is offline   Reply With Quote
Old 05-22-2016, 07:12 PM   #2
FastFord13's Avatar
Wrong section.
Sent from the future.
Old 08-31-2017, 03:25 PM   #3
Originally Posted by FastFord13 View Post
Wrong section.
where should it go?
Old 08-31-2017, 03:30 PM   #4
FastFord13's Avatar
2011-2014 V6 section, you'll have better luck there with your question. Your in the pre 2006 section, completely different powertrain. 👍
Unless you meant you have a 2004 V6 instead of a 2014?
LG G4
Old 09-01-2017, 05:34 AM   #5
Strange Mud's Avatar
moved for ya!
Old 09-09-2017, 05:31 PM   #6
MustangDawg's Avatar
I just had my transmission flushed at the dealer a couple of weeks ago. It's called a "Transmission fluid exchange" at the Ford dealer. It took 13qts of fluid and cost $239 out the door. Call a couple of Ford dealers in your area and get a quote, they should be able to answer your questions. Here's a link to the workshop manual, hope that helps. Ford Workshop Service & Repair Manuals Home - 2011 Mustang
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 09-09-2017, 05:49 PM   #7
Originally Posted by MustangDawg View Post
I just had my transmission flushed at the dealer a couple of weeks ago. It's called a "Transmission fluid exchange" at the Ford dealer. It took 11qts of fluid and cost $239 out the door. Call a couple of Ford dealers in your area and get a quote, they should be able to answer your questions. Here's a link to the workshop manual, hope that helps. Ford Workshop Service & Repair Manuals Home - 2011 Mustang
Hey thanks I appreciate that. fell a little dumb I should have thought of that
---------- Post added at 05:49 PM ---------- Previous post was at 05:49 PM ----------
Hey thanks I appreciate that. feel a little dumb I should have thought of that
Old 09-09-2017, 06:12 PM   #8
No problem. I felt since my ride is a 2013 and is still under the drivetrain warranty, I'd have the dealer handle it so if something goes wrong, it's on the dealership. I'm not comfortable messing with a sealed automatic transmission. Some things I will have an experienced mechanic handle and I can handle the rest. I just picked up the updated Haynes Repair Manual for the 2005 thru 2014 Mustangs on eBay for $22. Pick one up, it answers a lot of your questions and helps you do some of the work yourself
Does a 98 have a single over___ valve or double ____ valve? SwatKatz901 1996-2004 Mustang GT 14 02-13-2012 08:03 AM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 06:29 AM
where pcv valve on my 3.8L v6 valve cover to where? Pascullon Pre-2005 V6 Mustang 2 02-28-2011 09:47 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 03:24 AM
Bypass valve & Blowoff valve sporter 2005-2010 Mustang GT 7 05-27-2007 03:57 PM
01:27 AM
