Another suspension question - Mustang Evolution
Old 05-13-2016, 10:51 PM   #1
jonyou's Avatar
So I am lowering my car this Thursday. I have an adjustable panhard bar installed along with a brace, and bmr adjustable lower control arms. I'm installing maximum motorsports caster camber plates, rtr lowering springs, koni STRs , bmr upper control arm and bracket.
Do I need to use lower control arm relo brackets if I have the adjustable lower control arms?
I have them if needed but I am missing a bolt and can't find a decent replacement M14x1.5x100mm 10.9 grade. (bought used )
2014 V6 Performance Package Sterling Grey
MPT Tuned.
Airaid CAI, BBK Shorty Headers, Borla S-types, Stubby Antenna, JLT Catch Can, MMD hood struts, GT500 spoiler, Oracle Halos on GT Grille, Dynotech One piece Aluminum Driveshaft.
jonyou is offline   Reply With Quote
Old 05-14-2016, 04:06 AM   #2
Robostang's Avatar
The adjustable LCAs can move the axle forward or backward. The relocation brackets move the rear attachment point of the LCA up or down allowing you to change the angle of the LCA so that it is parallel to the ground. So basically they serve two different functions. If after you lower the car you find that the LCAs are lower at the body end then they are at the axle end you should probably install the brackets. This will help plant the rear wheels during hard acceleration.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 05-15-2016, 01:27 PM   #3
jande063's Avatar
If you need a bolt, call Fastenal.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 06-17-2016, 06:57 PM   #4
Gil05GT's Avatar
Region: Oregon
Hmm, so here is another question then, my '05 GT is lowered ~ 1 inch in the rear, (the front ~ 1 1/2 inch) when on a flat level surface the body end is about 1/2 to 1inch higher than the rear end height. Is this good, bad or indifferent? My best short time (60 foot) with Nitto 305/35/18 tires on the rear is 1.95 seconds. I took a couple of pictures but can't figure out how to attach then, (JPEGs).
Gil05GT is offline   Reply With Quote
Old 06-17-2016, 09:52 PM   #5
Voltwings's Avatar
305 35 18 is about a 26.5" tire, which is rather short, most tires for this car fall in the 27-28" range, but i imagine you would notice if the tires were an inch different in height?
Old 06-18-2016, 10:26 AM   #6
Gil05GT's Avatar
Region: Oregon
I put the lower profile tires on to help keep the rev's in the higher range one the top of the strip in third gear. I'm running a PA beefed up automatic. yes I know the tire is shorter than what came with the car. The question still remains the same, what position should the LCR for this kind of setup? Thanks for your comment... Should I open this in it's own thread?
Old 06-18-2016, 07:40 PM   #7
Diehard's Avatar
I can't tell if this guy's for real.
Old 06-19-2016, 01:53 PM   #8
NewMtang's Avatar
Yep, another one of the V8 Group.
Old 06-19-2016, 04:14 PM   #9
Gil05GT's Avatar
Region: Oregon
Diehard/NewMtang I assure you I'm for real. I didn't think it would be out of line considering the original thread about LCA angles. Anyway I'll drop out of this thread since I'm "another one of the V8 Group".
Old 06-19-2016, 06:55 PM   #10
jande063's Avatar
Sorry about the poor reception, there was a set of inflammatory threads in which certain words were spoken by many, and the effects have been a bit unfortunate.
Generally speaking, you want your axle end to be sitting lower than the body end. There are in incredible array of variables which determine how far below you go.
A few key topics that I would recommend researching would be anti-squat suspension geometry (how and why it works), all three major components of weight transfer (particularly elastic), and the actual geometry of your three link system (so that you can understand the difference in your axle steer produced by the change in trailing arm longitudinal lengths caused by body roll).
Old 06-19-2016, 09:37 PM   #11
Gil05GT's Avatar
Region: Oregon
jande063, thank you for your understanding and information, you answered my question the axel end of the LCA should be parallel or lower than the body end. I'll try playing with tire pressures now.
Old 06-20-2016, 07:06 AM   #12
Diehard's Avatar
I apologize for my misunderstand of what was being asked. It was a bit confusing to me at the time for some reason. Had nothing to do with being a V8.
As far as posting pictures, see post #4 of this link. It may be of some help.??
uploading photo
Another Suspension Question Diehard 2011-2014 V6 Mustang 19 10-17-2015 08:48 AM
Another day, another problem SixBanger General Mustang Discussion 69 03-05-2014 11:40 AM
Sorry, another suspension thread... Need exp advice here SolidRRaxle 2011-2014 Mustang GT 15 11-09-2012 09:24 AM
Another Year, Another USC FAIL!!!!!!!!!!!!!!!!!!! Brent The Bar 20 09-27-2008 07:08 PM
Well, I got another car, guess I won't be getting another stang anytime soon :(. Rick0636 The Bar 12 09-25-2005 10:10 PM
12:47 AM
