Axle Shaft Replacement - Mustang Evolution
Old 05-18-2016, 08:48 PM   #1
VIG
VIG's Avatar
Region: Delaware
I was doing Mustang things in my Mustang and took a corner a little too hot. Well long story short I whacked my right rear wheel and it sounds like the axle shaft is slightly bent.
How hard is it to take the ABS ring off the original shaft and get it back on to the new one?
Is there anyplace that sells the shaft with the ABS wheel already installed?
Thanks guys.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 05-19-2016, 12:22 AM   #2
tombrochard's Avatar
Check Dorman, they make a lot of replacement stuff and they might have an axleshaft
2011 V6 Premium Pony Package
Bama Tunes, BBK Shorty Headers, Magnaflow Exhaust, Airaid cold air intake
Flux Capacitor with a Mr. Fusion
tombrochard is offline   Reply With Quote
Old 05-19-2016, 06:24 AM   #3
VIG
VIG's Avatar
Region: Delaware
Yeah, there are plenty of places that have it but I'm trying to find one that already has the ABS ring installed because they're pressed on.
Old 05-19-2016, 07:59 AM   #4
See if you could find a junkyard near you that has a squished Mustang. It seems like there's a lot of them out there you just need to call. Otherwise you'll need to find a machine shop to press the fitting on, or better yet get the replacement part and ask your local Ford dealer if they can just press it in place
Old 05-19-2016, 08:00 AM   #5
ZombieSlayer's Avatar
I would say just go to the next Mustang show and wait for someone to wreck when they are leaving. Then throw them an offer for the axle.
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
Follow me on Instagram: https://www.instagram.com/kevin.cook2016/?hl=en
ZombieSlayer is offline   Reply With Quote
Old 05-19-2016, 11:25 AM   #6
tym_v6's Avatar
LOL.
*cough*Rental*cough*
Kidding!
Old 05-19-2016, 11:43 AM   #7
VIG
VIG's Avatar
Region: Delaware
Originally Posted by tym_v6 View Post
LOL.
Kidding!
Haha I knew I could count on you guys to help out.
Old 05-19-2016, 05:04 PM   #8
ak_stang's Avatar
Region: Alaska
Did the same thing in the snow, curb was buried under snow and drifted right into it. Went to Ford dealer and they wanted 700 to repair it. Bought an axle from Ford with abs ring already pressed on for about 300 I believe and changed it myself
Sent from my LG-AS811 using Mustang Evolution mobile app
ak_stang is offline   Reply With Quote
Old 05-19-2016, 05:24 PM   #9
tym_v6's Avatar
Dealership test drive?
LOL!
Old 05-20-2016, 11:09 PM   #10
VIG
VIG's Avatar
Region: Delaware
Lol it doesn't seem like there's a ton of knowledge on the subject but I'm going to try to ask anyway.
Is the ABS ring actually pressed on or can you slide it on?
Old 05-21-2016, 06:43 AM   #11
ak_stang's Avatar
Region: Alaska
It's pressed on I've heard that you can put the ring in the oven to expand it a little and possible get it on yourself, IF YOU BUY A NEW AXLE FROM FORD THE AND RING IS ALREADY PRESSED ON.
Old 05-21-2016, 07:41 PM   #12
VIG
VIG's Avatar
Region: Delaware
I might go this route. It will double the cost though.
Old 05-25-2016, 06:07 PM   #13
ak_stang's Avatar
Region: Alaska
I took this into consideration but in the end it was worth it for me to get it done in one day, rather than buying. one and it possibly not having a ABS ring then having to find one of those, then finding a shop to press it on.
Balancing drive shaft or replacing drive shaft Iryan7 Pre-2005 V6 Mustang 6 03-22-2015 12:57 PM
Drag tires, axle and drive shaft crev 2011-2014 Mustang GT 31 05-28-2014 04:41 PM
2010 Rear Axle Shaft Issues ElGrandeBurrito 2011-2014 Mustang GT 2 08-02-2013 01:03 PM
Rear Axle Shaft Sycopath80 2005-2010 V6 Mustang 4 04-04-2012 04:25 PM
1965 Mustang 200ci drive shaft and axle Tuch65 Classic Mustangs 6 11-06-2011 12:39 PM
10:19 AM
