Borla X Pipe weld failure - Mustang Evolution
Old 05-19-2016, 12:29 PM   #1
jande063's Avatar
So I have been noticing for a while now that my car seems down on power, and when I went to get the state inspection done by a friend, we were underneath, and found that my X Pipe had cracked along the full length of the weld on the crossover section, and had propagated into a tear past the end. Has anyone else had an issue with this, and how well does Borla respond to requests to repair manufacturing issues? Pictures are below.
This would certainly explain why it smells faintly of carburetor at stoplights. The things that get missed when you stop racing a car regularly, and it gets daily driven without regular inspection. Oops.
ID:	201156   Click image for larger version
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 05-19-2016, 01:08 PM   #2
David Young's Avatar
If it was leaking i would have expected to see a lot of black soot
David Young is offline   Reply With Quote
Old 05-19-2016, 01:13 PM   #3
I think Borla had some problems with the welds on some of their axle back mufflers rusting a few years ago.
Old 05-19-2016, 01:17 PM   #4
Voltwings's Avatar
You know, i was literally about to message you earlier asking how you liked the Borla Long tubes since i saw them in your sig... interested to see where this goes.
Old 05-19-2016, 01:33 PM   #5
oxford5pointoh's Avatar
They will warranty that.
Old 05-19-2016, 02:30 PM   #6
jande063's Avatar
I have spoken with Borla, and they were extremely helpful. The problem is that the x pipe is not designed for the extreme heat that I subjected it to, and has since been redesigned.
The problem is that the x pipe is experiencing extreme temperatures, then once it gets to temperature, the torque of the motor on a hard downshift tends to twist the weld apart.
The solution is to completely weld the plates mounted at each end of the crossover (the early and current ones are only tac welded on), and the best results from their testing was to add two more to each end (for a total of six). This increases the torsional rigidity of the final product, and prevents the failure.
I am not going to ask them to warranty it, but will repair the existing part, and take video at the next track event I do with the car. I will keep everyone posted, but it will likely be either July or October before I have an opening to run my own car.
I just want to be clear, the customer service group at Borla was extremely helpful, and I would like to thank them for that.
Old 05-19-2016, 02:34 PM   #7
Voltwings's Avatar
Aside from this though, happy with the Borlas? They're at the high end of the price range, but i've considered them more than once for our car.
Old 07-28-2016, 10:27 PM   #8
jande063's Avatar
Update:
I pulled it apart, and there were literally only two tac welds holding this together. After some creative use of home depot, I have reassembled it. Pro tip: Grind the old tac welds down, or you get to pull it off, and do that later, because they will stress crack after a few harsh heat cycles.
So far, no repeat issues, will pull this thing back off in a month, since I will be putting over 12 hours of track time on the car next month. If it is going to repeat, this will do it.
Old 07-28-2016, 10:45 PM   #9
jande063's Avatar
For most people, they are fine. I have been pretty pleased with them. With the factory mufflers, I only register 82 decibels at sea level past redline, so you will not have any issues with breaking the noise limit at tracks (95-105 is a common range of limits).
Other than the X Pipe, they have been bullet proof. I have heat cycled them past the point that many would have cracked a weld. I would definitely not pay full price for them though, the $600 I paid was about right.
Borla Over-the-axle pipe & Borla X pipe weiyuhan Mustang 101 - Tech Basics | Ask an Expert 1 01-27-2016 06:16 PM
Weld in h pipe and cats? NicholasP 2011-2014 V6 Mustang 2 09-22-2012 02:03 PM
05-09 mustang gt weld-in o/r H pipe FORDuhl6 Mustang Parts for Sale and Wanted 0 06-27-2012 05:40 PM
Universal weld-in X pipe FORDuhl6 Mustang Parts for Sale and Wanted 0 06-23-2012 12:25 PM
I was wrong about the war on drugs: It's a Failure Brent The Bar 7 06-11-2008 12:29 AM
03:59 AM
