Water in Power Control Module? - Mustang Evolution
Old 05-31-2016, 04:55 PM   #1
I have a 2013 Mustang, V6, 66,000 miles. Recently the Powertrain
Malfunction light comes on and car loses drive and acceleration. I can pull
off to the side of the road, turn the car off and back on and it runs fine. This
makes me think the problem is electrical and not mechanical.
I notice this almost ALWAYs happens after driving in the rain or
getting the car washed. One of the indicators of the On-board Diagnostics
light coming on is that the electrical system "may be wet."
Is it possible I am getting water in the electrical system and this may be
causing this problem?
Thanks for your help
bkdockery1 is offline   Reply With Quote
Old 06-01-2016, 09:54 AM   #2
I now have the error code P2111. Any advice?
Old 06-01-2016, 11:19 AM   #3
iguanaman3's Avatar
That is a throttle body fault code. I have seen a few TB failures and they have similar symptoms to yours. Perhaps it is the time to upgrade to a BBK. Ford will charge you nearly the same for a new one of theirs. It is an easy swap so don't pay Ford to do it.
iguanaman3 is offline   Reply With Quote
Old 06-01-2016, 12:15 PM   #4
I am not very car smart. What is a BBK?
Old 06-01-2016, 12:56 PM   #5
MustangDawg's Avatar
Here ya go:
BBK Power Plus Mustang 73mm Throttle Body 1822 (11-16 V6) - Free Shipping
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
04 Mach 1 Constat Control relay module (ccrm) install help Ksantos Other Special Edition 0 08-10-2013 09:40 PM
Ignition Control Module problem? 3.8Monster Pre-2005 V6 Mustang 4 07-20-2013 06:23 AM
ignition control module ebourd 1979-1995 Mustang GT 3 04-21-2012 03:35 PM
Engine control computer/ module Matt5.0 1979-1995 Mustang GT 7 02-06-2012 11:30 PM
Venom 400 Control Module greenpony02 Pre-2005 V6 Mustang 1 03-15-2004 04:24 PM
07:31 AM
