Hvac making buzzing noise in passenger foot area - Mustang Evolution
Old 06-06-2016, 02:54 PM   #1
Hawkstang's Avatar
Region: Iowa
Started on Saturday.... The very day my 3 year basic warranty expired. Im hoping it's something I can fix myself.
Hawkstang is online now   Reply With Quote
Old 06-06-2016, 02:58 PM   #2
wmschoonover's Avatar
Possibly broken fin on blower motor blades. Pretty easy fix and usually cheap.
wmschoonover is offline   Reply With Quote
Old 06-06-2016, 03:22 PM   #3
Hawkstang's Avatar
Region: Iowa
Thanks, how can I check that?
My vents still blow hard, but the buzzing started when my wife had her vent closed for most of the trip. Now it makes that noise whenever hot or cold is turned on at any fan speed or and vent setting.
Its definitely coming from behind the glove box.
Old 06-06-2016, 04:47 PM   #4
It will be accessed under the dash on that side. Usually 3 bolts and a plug to drop it out and you should see easily if there is one broken or cracked.
Cheapest I found one was about $40 but name brand ones about $70
Name:	ImageUploadedByMustang Evolution1465253234.001854.jpg
If any are broke the weight difference causes a vibration.
Old 06-06-2016, 04:51 PM   #5
Here is a picture of what it looks like under there.
Name:	ImageUploadedByMustang Evolution1465253493.282013.jpg
Old 06-06-2016, 06:06 PM   #6
Hawkstang's Avatar
Region: Iowa
Thats the view from inside the cabin?
Old 06-06-2016, 06:29 PM   #7
Docstang's Avatar
Does the noise change W fan speed? I have seen actuators make noises
Sent from my QTAIR7 using Tapatalk
Docstang is offline   Reply With Quote
Old 06-06-2016, 06:31 PM   #8
Docstang's Avatar
Does it happen/change when changing the temp?
Old 06-06-2016, 06:32 PM   #9
Hawkstang's Avatar
Region: Iowa
No its a pretty consistent noise. Like something broke.
Old 06-06-2016, 06:37 PM   #10
Docstang's Avatar
Does it quit when blower is off?
Old 06-06-2016, 08:10 PM   #11
Hawkstang's Avatar
Region: Iowa
Yes.
I laid upside down and saw the stuff you describes. The noise was coming from a small round hole in the middle of the fan casing. I put a piece of 3m tape over it and it quieted it completely up. But will this fan eventually fail? Is there anything bad about waiting for it to fail before replacing?
Old 06-06-2016, 08:13 PM   #12
Hawkstang's Avatar
Region: Iowa
Attachment 202114
Thank you! If air still comes out the vents strong am I ok to run it with a broken fan blade?
Old 06-06-2016, 08:22 PM   #13
Docstang's Avatar
Run it till it quitsπŸ˜€
Old 06-07-2016, 04:44 AM   #14
As easy as it is to check, I'd drop it down and make sure that actually is the issue. But yeah. If that's it... Then run it until it quits. I've never changed one without changing the motor/blade combo so if what vibration is still there doesn't bother you then leave it. I would lol
Old 06-07-2016, 09:48 AM   #15
MustangDawg's Avatar
If It were me, I would change it out now. We're heading into the hot summer months and it would be just my luck for it to quit on the hottest day of the summer and the part not being available for a couple of weeks or something. It's a cheap fix and you won't have to deal with it during the summer. Just sayin' . . . . . .
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 07-06-2016, 03:38 AM   #16
Post Causes of an Buzzing Noise
Here I am defining some causes of an buzzing noise
Breaking down compressor – The compressor in your aerating and cooling unit is the piece of your cooling framework that attempts to pressurize and cool the refrigerant in the unit. A humming sound means your compressor may not work appropriately, or that the electrical voltage coursing through your open air aeration and cooling system is not at its right amperage.
Lost or harmed disconnection feet – The compressor in your aeration and cooling system is mounted to the base of the AC unit and sits on little elastic feet (called segregation feet). Over the long haul and after proceeded with utilize, the elastic on the segregation feet once in a while splits and/or breaks down, bringing about the compressor to wind up uneven and creating an uproarious, humming commotion while working.
Solidified AC unit – Even however your aerating and cooling framework is intended to be utilized amid the most sweltering times of the year, AC units regularly solidify up. Solidifying is the aftereffect of refrigerant breaks and can bring about a humming sound to be gotten notification from your unit.
Free parts – Your aerating and cooling unit is an intricate arrangement of moving parts working in a state of harmony to cool your home. On the off chance that a section turns out to be free or is missing (e.g. free orientation), it might bring about different parts of your framework to experience the ill effects of untimely wear and cause the humming clamor you listen.
Martinadam is offline   Reply With Quote
2003 GT buzzing noise from radio Cam416 1996-2004 Mustang GT 0 05-30-2016 06:51 PM
Rear view mirror buzzing fishman General Mustang Discussion 1 12-01-2015 09:11 PM
Buzzing Noise From Tire Well Mutafov 2011-2014 Mustang GT 0 10-08-2015 10:24 PM
Strange buzzing sound from dashboard jande063 2011-2014 V6 Mustang 2 12-11-2014 05:53 AM
1996 Mustang gt v8 Stock /Buzzing noise/ Kid_Ceej 1996-2004 Mustang GT 11 01-26-2013 07:02 PM
08:08 PM
