2012 6 speed manual when cold - Mustang Evolution
Old 06-08-2016, 04:01 AM   #1
Guys, just picked my car a little over a week ago. When its cold, first and second gear isnt real easy to get into. Is this common? Car only has 41k and was driven by an adult female so i cant believe it was beat on.
Thanks!
1970Fordmann is offline   Reply With Quote
Old 06-08-2016, 04:03 AM   #2
Noodles76's Avatar
Yes. A lot of people swap the tranny fluid and install a new shifter and have pretty good results.
Noodles76 is offline   Reply With Quote
Old 06-08-2016, 04:16 AM   #3
Great, thanks!
Old 06-08-2016, 01:36 PM   #4
Voltwings's Avatar
Most other brands (royal purple, redline, amsoil...) wont have a specific recommendation for fluid because Ford has changed the factory fill 3 or 4 times now. Just make sure you're getting a quality synchromesh GL-4 fluid. I personally like using the redline 75w90, but I have also used the amsoil synchromesh 5w30 (gear oil is not weighted the same as engine oil) with great success. The amsoil stuff gets expensive though, which is why I made the shift to the redline fluids.
Old 06-08-2016, 04:39 PM   #5
Im a big Amsoil believer. They raised prices a few years ago though....
Thanks for the input!
Old 06-08-2016, 04:45 PM   #6
Noodles76's Avatar
I bought the royal purple synchronmesh fluid. I'll be doing the flush within the month.
Old 06-08-2016, 04:52 PM   #7
FastFord13's Avatar
I did the swap over 2 years ago to Royal Purple.
When its cold its still notchy.
Sent from the future.
Old 06-08-2016, 05:32 PM   #8
Noodles76's Avatar
Luckily I'm in Florida. It's never really cold lol. Other than that any complaints with the royal purple?
Old 06-08-2016, 05:48 PM   #9
FastFord13's Avatar
None.
Old 06-08-2016, 06:44 PM   #10
tombrochard's Avatar
Thanks!
Just put new ford fluid in and the little bottle of friction modifier and that will go away. I had the same issue with my 2011 and that's what the TSB (technical service bulletin) said to do. I know a lot of guys use different fluids and love them but I'd prefer to follow the guidelines the ford engineers recommend
2011 V6 Premium Pony Package
Bama Tunes, BBK Shorty Headers, Magnaflow Exhaust, Airaid cold air intake
Flux Capacitor with a Mr. Fusion
tombrochard is offline   Reply With Quote
Old 06-09-2016, 11:18 AM   #11
DEvermore's Avatar
Region: Iowa
My solution is simpler. I just wait for the car to finish warming up and the RPMs to sink back down to 650-700. At this point, it seems to have splashed enough oil around to make the shifts smooth.
2017 GT350 w/electronics package.
DEvermore is offline   Reply With Quote
Old 06-09-2016, 04:51 PM   #12
Voltwings's Avatar
The reason the factory fill has changed so many times is because they don't know what to recommend. Just saying.
Old 06-09-2016, 05:30 PM   #13
Mlp07's Avatar
Mine shifts perfect no complaints, but once the transmission gets hot and shift from 1st to 2nd I will hear it grind at the low rpms. Hopefully it's not damaging anything.
Mlp07 is offline   Reply With Quote
Old 06-10-2016, 04:35 AM   #14
Strange Mud's Avatar
grinding is not good (well, not in a transmission) and if it's reproducible and under wtty (5/60) bring it in for service.
Old 06-11-2016, 10:41 AM   #15
Mlp07's Avatar
It won't do it when cold, only when the transmission gets on its normal hot temperature. I did took it to a dealership and they said that ford told them it was normal. Will changing to a better transmission oil help with this problem since it only does it hot.
Sent from my SAMSUNG-SM-N915A using Mustang Evolution mobile app
Old 06-11-2016, 10:43 AM   #16
FastFord13's Avatar
Heat was the main reason I went with Royal Purple 2 years ago.
Old 06-11-2016, 12:27 PM   #17
Mlp07's Avatar
But if something happens they will blame it on the oil and won't honor the warranty
Old 06-11-2016, 01:36 PM   #18
It ain't supposed to grind. That is NOT normal. Notchy/finicky is. I would try another dealer and escalate it to Ford customer service if needed. If that does not work after really trying they are NOT honoring the wtty in the 1st place. I went with RedLine MTL and it improved the notchy feeling in mine some.
hint: save the OEM oil in a clean container in case it end up imploding and swap it back in before you tow it. I doubt that is necessary but simple/cheap enough to do.
good luck and remind them grinding ain't normal (w/o insulting, clutch all the way to the floor!)
Old 06-11-2016, 08:08 PM   #19
Voltwings's Avatar
If you can prove, which you can, the oil you are using meets or exceeds factory specifications they cannot deny warranty because of it.
2012 Boss 302 VS 2012 GT TOP SPEED test on the autobahn. Phoenix64 2011-2014 Mustang GT 15 01-10-2016 07:18 PM
Manual vs "auto manual" elkoritaNAY 2011-2014 V6 Mustang 5 08-24-2014 08:22 PM
Who wins? 2008 v6 manual vs. 92 mustang lx 5.0 manual. wc3john The Bar 1 06-23-2011 07:10 AM
06:44 AM
