Airaid mit - Mustang Evolution
Old 06-14-2016, 07:01 AM   #1
jek57's Avatar
Airaid mit
Just put on my Airaid tube on had these ford stickers i got from advance auto last yr perfect fit in place of the airaid stickers looks much better for sure
ID:	202469   Click image for larger version
jek57 is offline   Reply With Quote
Old 06-14-2016, 10:01 AM   #2
iguanaman3's Avatar
That looks good but I noticed that you still have the defective degas hose on your radiator bottle. You should get the one with the backflow valve ASAP or risk premature water pump failure. It is worth the $20.
iguanaman3 is offline   Reply With Quote
Old 06-14-2016, 03:10 PM   #3
Shadetree43's Avatar
I've got one of those also. (With the new overflow tank hose)
AIT much cooler than my original Airaid CAI too.
Shadetree43 is offline   Reply With Quote
Old 06-14-2016, 05:25 PM   #4
jek57's Avatar
I didn't realize that was a problem ..Whats the deal with it and did you get the part from the dealer.
Old 06-14-2016, 05:35 PM   #5
Its looks like you have the updated hose. The one on my car looks identical to yours.
Bigshow14 is offline   Reply With Quote
Old 06-14-2016, 06:41 PM   #6
jayochs's Avatar
i've got this badboy too..kept the logo on it though.
do i need an updated hose?
Name:	2016-04-30 12.20.55.jpg
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 06-14-2016, 06:44 PM   #7
Need a better overflow pic. The front hose cannot be seen in this pic.
Old 06-14-2016, 07:48 PM   #8
Diehard's Avatar
It's not the front hose, to the best of my knowledge. It's the overflow hose(ER3Z-8276-A) that runs between the thermostat housing and the degass bottle (overflow tank).
This was discussed back in this thread...
2012 leaking coolant. Help! starting around Post #20.
Old 06-14-2016, 07:55 PM   #9
This is the pic that you posted in another thread. Ive got it backwards, going to have to check out my car again.
Old 06-14-2016, 08:04 PM   #10
Diehard's Avatar
Here's another view of it with reference to the Fords OEM Parts diagram.
Ford 11 14 Mustang 3 7L V6 Radiator Overflow Hose ER3Z8276A | eBay
Old 06-14-2016, 08:09 PM   #11
Heres a pic from the thread that you was talking about. Thx Diehard for clearing up the confusion. Looks like I need the upgrade also.
Old 06-14-2016, 08:13 PM   #12
Diehard's Avatar
I haven't done mine yet!
Old 06-14-2016, 08:16 PM   #13
And you picked on me about not updating my axle vent tube Btw I finally swapped it!!
Old 06-15-2016, 05:40 AM   #14
jek57's Avatar
Glad i posted the pic would of never known ...Thanks guy for the info plan on getting on for sure..Also nice pic of your airaids mit
Old 06-15-2016, 06:33 AM   #15
jayochs's Avatar
damn guess I need one too
Sent from my Samsung Galaxy S7 using Tapatalk
Old 06-15-2016, 07:03 AM   #16
jek57's Avatar
I just ordered one off ebay for 27.00 part # ER3Z8276A they had 3 left where i ordered it from
Old 06-15-2016, 12:15 PM   #17
Voltwings's Avatar
Does anyone have one of these as well as a tuner and wouldnt mind doing some datalogging for us?
Measure the MAF flow with the factory inlet tube, then measure the MAF flow with the MIT and compare. Unless of course this is purely a cosmetic mod, then do as you see fit.
Old 06-15-2016, 02:21 PM   #18
iguanaman3's Avatar
I'm glad I could help. The worst part is that some owners that have had water pump failures were told that the pump wasn't covered because the defective hose was the cause of the failure and that was not covered by the 5 year warranty! It is easy to tell if you have the updated hose because it drops down right after it leaves the tank instead of going straight out like your does.
Old 06-15-2016, 04:14 PM   #19
jayochs's Avatar
found the link. so i can see in my pic it comes straight out from the resovoir, but the updated version like in the pic drops down like said above. ok, so i think i'll order it if it's going to save me money.
simple to put on i assume? any issues with opening up the system and getting air into it or anything? not sure how it all works, but apparently air in the system is what causedd it to fail in the first place
Old 06-15-2016, 04:49 PM   #20
iguanaman3's Avatar
The new hose goes on easily. Do it when the engine is cold and you shouldn't lose any coolant. The new hose has a backflow valve that prevents air in the tank from entering the system. It is called a degas hose so its job is to remove air which is ironic considering that without the valve it is blamed for causing pump failures from air bubbles.
Old 06-15-2016, 05:44 PM   #21
jek57's Avatar
The Airaid website says it will increases the cfm to 400 over the stock tube but i bought for the looks only and not expecting any real hp gains from it.
Old 06-15-2016, 06:59 PM   #22
Voltwings's Avatar
lol, thats like a 680 whp gain... someone over there is smokin some good ish
Old 06-15-2016, 08:00 PM   #23
Diehard's Avatar
Pretty sure when they say, "...can improve airflow up to 400 CFM over the restrictive stock intake tube" it simply means that it is capable of flowing up to that much more capacity at a given pressure loss. Or another way to say it would be that at the same flow it(the airaid tube) would have less pressure loss. It's not saying it WILL BE flowing that much air.
Old 06-15-2016, 08:48 PM   #24
Voltwings's Avatar
I know its fluffy wording, but still... its a ridiculous thing to say because it has no practical meaning whatsoever.
Old 06-16-2016, 05:31 AM   #25
jek57's Avatar
Wow with 680 i can beat a shelby now lol
Old 06-16-2016, 02:28 PM   #26
jayochs's Avatar
lol. tbh as dumb as it sounds, my throttle felt slightly more responsive with the tube.
Old 06-16-2016, 05:29 PM   #27
jek57's Avatar
I have a mpt tune on mine so it's hard to really tell but with the airflow more of a straight shot with the tube it should make a bit of a differance ...going to open a can of worms now
Old 06-18-2016, 09:06 AM   #28
Hawkstang's Avatar
Region: Iowa
Did it make your engine bay louder?
Also, where is the cheapest place I can get the differential vent?
Hawkstang is offline   Reply With Quote
Old 06-18-2016, 09:46 AM   #29
jayochs's Avatar
nah, but i think thats because I already had a louder whoosh noise when i ditched the stock airfilter and got the afe pro.
Airaid Throttle Body Spacer/ Airaid CAI Question MP0986 2011-2014 V6 Mustang 39 09-17-2015 08:21 AM
05:41 PM
