Lowered the car today... - Mustang Evolution
Old 06-18-2016, 01:30 PM   #1
2012MCA's Avatar
Put on SR Springs that say they will drop it 1.5"
I didn't measure before I installed them but the front left and right are at 28". The back left is at 28.5", and the right is at 28.75".
Test drove it and was getting a popping noise from the front right. I assumed the strut mount wasn't tightened all the way so i drove the right side up on a ramp to put more tension on it and tightened it up.
Hoping that it settles in about another .5", but it does look much better and even on stock shocks and struts rides much better. I will be changing the shocks and struts out very soon though.
ID:	202628   Click image for larger version
2012 Mustang Club of America Edition Silver Ingot V6 Premium, 6MT, BBK Shorty Headers, Mak Performance catless H-Pipe (not MAC), Magnaflow Street Catback, Airaid CAI, MPT 93R Tune, 80mm Throttle Body, Ported Intake Manifolds, SR Lowering Springs, SR Adjustable Panhard Bar, Lakewood 50/50 Shocks, Steeda Heavy Duty Strut Mounts.
2012MCA is offline   Reply With Quote
Old 06-18-2016, 01:48 PM   #2
sunnytan06's Avatar
Panhard bar and camber plate as well?
sunnytan06 is offline   Reply With Quote
Old 06-18-2016, 02:00 PM   #3
2012MCA's Avatar
just an adjustable panhard bar
Old 06-18-2016, 02:29 PM   #4
Two or three days of driving and they will be perfect.
Bigshow14 is offline   Reply With Quote
Old 06-18-2016, 02:39 PM   #5
king_13's Avatar
What all is needed for "proper" lowering? I've read a couple different posts but want to know for sure.
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 06-18-2016, 02:43 PM   #6
Shocks, struts, adjustable panhard bar, strut mounts, LCA relocation brackets. If you have a one piece driveshaft, adjustable upper control arm and mount.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 06-18-2016, 02:55 PM   #7
Cooolbreeez's Avatar
Let me know if you hear any creaking noises from the rear. Mine makes a creaking noise when pulling in and out of driveway. Not during regular driving but it is quite annoying. I actually think it might be the double adjustable SR Panhard bar that's making that noise. I changed the rear shocks to konis yesterday hoping it might help some but it didn't.
Cooolbreeez is offline   Reply With Quote
Old 06-18-2016, 03:13 PM   #8
2012MCA's Avatar
I have the same panhard bar and haven't heard anything yet.
Old 06-18-2016, 04:14 PM   #9
king_13's Avatar
So with the stock 2 piece it will be fine?
Will getting the GT500 mounts require GT500 shocks/struts, or will ones made for 5.0s be compatible?
Old 06-18-2016, 04:34 PM   #10
2012MCA's Avatar
I think if you use the gt500 mounts you have to use 05-10 struts
Old 06-18-2016, 05:24 PM   #11
Hampton CIT's Avatar
Had a similar "popping" when I did my springs. I didn't torque down the top center nut enough. You can access it with a deep drive from under the hood. Tightened mine and popping went away. Not sure if that's your issue but as soon as I read "popping" it sounded familiar.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 06-18-2016, 05:28 PM   #12
2012MCA's Avatar
Yea it was the top nut. I got it taken care of though.
Old 06-18-2016, 05:36 PM   #13
Excellent
Old 06-18-2016, 06:13 PM   #14
Yea, you should be ok.
Old 06-18-2016, 07:31 PM   #15
Maybe after it's been in the elements for a bit. I didn't have that problem when I first installed it. I sprayed some wd40 on the ends where the swivel bushings are and it's not making that noise now. I think they were dirty, it's the second time I've done that and the noise has gone away. Might look into getting a different Panhard bar.
Old 06-19-2016, 03:52 AM   #16
David Young's Avatar
Looks great. When i lowered mine, i didn't have to buy an adjustable panhard bar because my rear measurements moved 4mm closer to perfect than it was before i lowered I got lucky
David Young is offline   Reply With Quote
Old 06-19-2016, 07:21 AM   #17
Correct!
Old 06-19-2016, 07:49 AM   #18
Originally Posted by Bigshow14 View Post
Correct!
And the drop in the front is a little more because the combo is a bit shorter than the 11-14 shocks with 11-14 mounts.
Sent from my SM-T710 using Tapatalk
Old 06-19-2016, 05:15 PM   #19
Hawkstang's Avatar
Region: Iowa
Looks very nice! Love your vinyl too!
Hawkstang is offline   Reply With Quote
Old 06-20-2016, 11:12 AM   #20
sunnytan06's Avatar
So for a 1.5 drop theres no need for camber plate?
Old 06-20-2016, 11:22 AM   #21
Harm_3.7's Avatar
No you don't need camber plates. When I had SR springs I didn't need camber bolts either. A panhard bar is recommended.
IG: justaslow3.7
Harm_3.7 is offline   Reply With Quote
Old 06-20-2016, 11:25 AM   #22
sunnytan06's Avatar
IG: justaslow3.7
So if I dd my car realistically I only need panhard bar and lca brackets at first until my shocks give out
Old 06-20-2016, 11:28 AM   #23
Harm_3.7's Avatar
When I had my SR springs I didn't do anything else other than the springs. Went almost 20k miles on them without any issues then I upgraded to coilovers. That's when I went and upgraded LCAs/UCA and added a panhard bar. Now I'm actually on bags and I am adding a watts link soon.
IG: justaslow3.7
Old 06-20-2016, 11:41 AM   #24
sunnytan06's Avatar
IG: justaslow3.7
Coilover are quite expensive, will you happen to know the ride quality from coilover to springs and matching shocks?
Old 06-20-2016, 12:15 PM   #25
Harm_3.7's Avatar
Ride quality wise my bags are by far the best choice for ride quality. The coilovers were better than the stock shocks and struts with SR springs.
IG: justaslow3.7
Old 06-20-2016, 01:30 PM   #26
king_13's Avatar
That's what I'm reading as well, then it's time for Konis.
Old 06-20-2016, 10:02 PM   #27
Jn2
Looks really good. I just ordered a set of FRPP K springs from AM, should be a very similar for mine as well.
13' Mustang GT w/Track Pack: Bottle fed CJ manifold, FRPP Intake,FRPP Monoblade TB, Speedmaster headers, Magnaflow 3" X pipe, Bassani quad tip ABs, Jn2uned, SRP Axles, MGW shifter, BMR LCA's
Jn2 is offline   Reply With Quote
Old 06-20-2016, 10:03 PM   #28
Jn2
Godspeed coil overs are on eBay for around $630 shipped, prob made in the same plant as all the major brands. My friend ordered a set of BCs and they were drop shipped from overseas. I believe the god speeds have spring rates of 8#f, 6#r and have built in camper plates just like BC
Old 06-21-2016, 03:12 AM   #29
audioAl's Avatar
My cyclone has koni sports and J&M cc plates and they really make an improvement in handling set @ 1.5 neg camber. I am not lowered except for my wheel & tire package.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 06-21-2016, 08:12 AM   #30
Strange Mud's Avatar
yes, but you'll pay (or do) install & alignment 2x. This is one of those do it once things.
.02
Old 06-21-2016, 08:43 AM   #31
king_13's Avatar
.02
So get everything done at once instead of progressively?
Old 06-21-2016, 09:38 AM   #32
45thMustang's Avatar
That is the best way to get it done. Ive got all of the parts needed to lower the car spread over my room but I still need shocks and struts. Its best to just put it on all at once so I dont have to basically install the springs twice but also as previously mentioned, you probably don't want to pay for two alignments after getting the parts installed. I also would rather keep the factory ride quality until i have shocks and struts that were meant for lowered cars. Trust me i know it sucks having the parts just sit around while you wait for the money to buy those last few parts.
Sent from my SAMSUNG-SGH-I257 using Mustang Evolution mobile app
45thMustang is offline   Reply With Quote
Old 06-21-2016, 09:53 AM   #33
I would (and did) I collected parts for over a year when on sale and used/never installed. If you do the work yourself including alignment by all means piecemeal it but if you are paying don't pay twice.
Old 06-21-2016, 07:21 PM   #34
sunnytan06's Avatar
Anyone can chime in on the quality of those?
Old 06-22-2016, 08:00 AM   #35
Generally speaking, you get what you pay for. I wouldn't buy them expecting years of trouble free use, that's for sure.
Lowered with 19's vs lowered with 20's. Post your pics! Xedes Pictures and Videos 38 01-06-2014 10:02 AM
Lowered car. Car wash? Martysmustang62 General Mustang Discussion 6 08-10-2013 11:05 PM
Lowered it today whatcha think greenstang41 Pre-2005 V6 Mustang 16 06-05-2013 06:24 PM
Lowered the stang today! TopgearGT 1996-2004 Mustang GT 7 09-10-2012 08:00 PM
my car lowered... Zim Pre-2005 V6 Mustang 29 02-06-2004 01:57 PM
04:10 AM
