Shortage?? - Mustang Evolution
Old 06-21-2016, 12:52 PM   #1
asvpedwin's Avatar
Shortage??
I recently had my park lamp fuse (#22) on passenger side on my 2014 Mustang v6 blow up. Replaced it and saw that it blew up again within 5 minutes. So know i've been told there is a shortage happening that's causing it to blow up. Anyone have an idea what could be causing the shortage?
asvpedwin is offline   Reply With Quote
Old 06-21-2016, 04:47 PM   #2
wmschoonover's Avatar
Manual lists parking lamps and license lamps.
wmschoonover is offline   Reply With Quote
Old 06-21-2016, 08:42 PM   #3
Diehard's Avatar
I know you're hoping for an easy answer and fix but in case you don't get one I had a learning experience finding this stuff that may or may not help.
You have a short(it's grounding out somewhere) in the circuit controlled by that fuse. The problem of course is to locate the short.
You could first just look at any and all easily visible connections and wiring on the circuit for frayed lines that may be touching a ground or any other suspicious looking items.
YouTube has a lot of videos that explain methods of finding shorts.
One device that is mentioned is a device which can be purchased or made, that's called a "Short Circuit Detector" or a "Power Probe Short Finder". This device helps locate the short in the circuit. I believe the one used in one of the videos is about $75 but I believe you can find lesser expensive versions for as low as $20 or so.
I think this first video is a bit easier to follow and understand the principle and use, compared to some of the videos I came across. (I know it was for me, as I am just learning about this stuff as well.
Oh BTW I dug up these wiring diagrams, " Parking, Rear and License Lamps", that should be useful in determining what and where things are on the circuit.
Name:	Parking, rear & license lamps Diagram 1 of 3.jpg
Name:	Parking, rear & license lamps Diagram 2 of 3.jpg
Name:	Parking, rear & license lamps Diagram 3 of 3.jpg
Old 06-21-2016, 09:17 PM   #4
Shadetree43's Avatar
A 14 should be to new to have any corrosion. Did you add LEDs to license lights? Vaguely recall AM or one of the Mustang speciality stores having license light wiring & bulb sockets. Ad mentioned was common failure point. Haven't seen any threads about that item, but sure would be an easy place to start. I have a 14 also & noticed lighting is all relays & lots of 22 gauge wire (Very small). License bulbs should be easy to remove then replace fuse & turn on lights. (if you don't have a meter & want to chase it that way).
Wiring diagram (thanks Diehard) should be big help.
Good luck.
Shadetree43 is offline   Reply With Quote
Old 06-21-2016, 09:19 PM   #5
asvpedwin's Avatar
Good luck.
Found it Click image for larger version
Name:	ImageUploadedByMustang Evolution1466565576.698364.jpg
Old 06-22-2016, 06:23 AM   #6
bucko's Avatar
Found it Attachment 202716
Yes, you did!
Old 06-22-2016, 06:52 AM   #7
MustangDawg's Avatar
Where was that a shot of exactly?
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 06-22-2016, 07:58 AM   #8
Diehard's Avatar
Excellent!
Old 06-22-2016, 08:35 AM   #9
Strange Mud's Avatar
unless you put in aftermarket bulbs it should be wtty. Bulbs will depend on your dealer.
Old 06-22-2016, 11:28 AM   #10
Yap, that's the one alright.
peter123wallace is offline   Reply With Quote
Old 06-23-2016, 04:57 AM   #11
David Young's Avatar
Looks like that would cause your problem to me
David Young is offline   Reply With Quote
Old 06-23-2016, 07:11 AM   #12
Diehard's Avatar
I'd like to know how those wires and casing got that way. Kinda looks like they were worn away by something. Like hanging on the ground.
Old 06-23-2016, 11:08 AM   #13
asvpedwin's Avatar
Shortage??
Yeah, when i did my GT500 front end conversion i forgot to plug them back in and i guess they dragged on the floor.
My alternator has a shortage Bnasty 1996-2004 Mustang GT 2 07-03-2013 09:29 PM
Gas shortage JJB82 General Car Discussion 7 11-05-2012 08:33 PM
power shortage immenukka Pre-2005 V6 Mustang 4 06-12-2007 02:49 PM
The Oil Shortage 00vertstang The Bar 9 09-02-2005 07:08 AM
02:08 AM
