Check Engine Light! - Mustang Evolution
Old 06-28-2016, 08:21 PM   #1
Brandonb2012's Avatar
Check Engine Light!
Name:	ImageUploadedByMustang Evolution1467166795.292752.jpg
Have y'all guys had any experience with this? Part came up for like $25 at autozone but wondering how hard this is to get to?
2013 v6 mustang 97k miles
Car is running normal
Brandonb2012 is offline   Reply With Quote
Old 06-29-2016, 03:16 AM   #2
bucko's Avatar
Do you stop fueling when the nozzle clicks the first time, our do you "top off" a few times?
Always stop fueling when the nozzle shuts off the first time. Continuing to fuel after that overfills, and allows the fuel to slosh up the filler neck, allowing raw fuel to enter into the charcoal canister, damaging it. Its intent is to capture the fumes only.
If this is not the case, it could be the fuel filler "flap"; these model years do not have a gas cap, but rather a flap in its filler neck.
Old 06-29-2016, 03:40 AM   #3
Bucko is right about "topping off", I did that to my '00 zr2 blazer, the charcoal canister was easy enough to replace tho.
Wheela is offline   Reply With Quote
Old 06-29-2016, 05:50 AM   #4
Lately I just been doing it till it clicks but I used to ALWAYS put a little bit more 😅 well now I know, any idea where this is located? Is there a difference in purge valve solenoid or canister?
Old 06-29-2016, 05:52 AM   #5
I was also thinking the capless gas tank could be a problem, I had the same code come up in my girlfriends car and it was just the gas cap not sealing
Old 06-30-2016, 08:33 AM   #6
Well after brutally raping my gas tank inlet after the car showed me a message saying to check the fuel inlet, i blew as hard as I could into the fuel inlet then I used the little funnel that comes with the cars and went in and out about 50 times wiped it down as good as I could and sprayed it with some WD40 and went another 50 times, cleaned it and wiped it all down as best as I could and gave it another 50 pumps lol then I unplugged my negative for a second and haven't had the light come back on since doing this yesterday
check engine
Check Fuel Cap & Service Engine Soon Light??????? mattstang Pre-2005 V6 Mustang 8 12-25-2006 01:33 PM
check engine soon light finally off stangracer Pre-2005 V6 Mustang 4 02-04-2004 10:41 AM
Check Engine Light MUSTANGJUNKY420 Pre-2005 V6 Mustang 11 08-09-2003 12:29 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 1 08-03-2003 08:24 AM
Check engine light, codes inside, cause? MUSTANGJUNKY420 Pre-2005 V6 Mustang 2 07-30-2003 12:22 AM
03:07 AM
