What I need to upgrade strut mounts - Mustang Evolution
Old 07-06-2016, 09:49 AM   #1
CorneliusRox's Avatar
Hey guys, I live down a dirt road and the dust kills my strut mounts in less than 30k. I'm sick of replacing them, so I read the GT500 style has much better sealing and bearings, plus they're cheaper.
(Ford Racing Mustang GT500 Style Strut Mount Upgrade M-18183-C (05-14 All) - Free Shipping)
American Muscle says I'll need GT500 lowering springs and shocks to make these work, but I've read I can use 2005-2010 GT struts and springs. I wanted to lower my car at the same time and was looking at the SR coils.
My biggest question is, do these strut mounts and the new struts work as a lift for the suspension, in which case, I need to get really low front springs to compensate for it, or would they put me back at stock height, so when I do SR springs with them, I'll be lowered evenly front and rear?
Corey | BSME
2012 Mustang - 3.7L - Loaded - Completely Stock!
CorneliusRox is offline   Reply With Quote
Old 07-06-2016, 11:29 AM   #2
tombrochard's Avatar
[QUOTE=CorneliusRox;2381402]Hey guys, I live down a dirt road and the dust kills my strut mounts in less than 30k. I'm sick of replacing them, so I read the GT500 style has much better sealing and bearings, plus they're cheaper.
My biggest question is, do these strut mounts and the new struts work as a lift for the suspension, in which case, I need to get really low front springs to compensate for it, or would they put me back at stock height, so when I do SR springs with them, I'll be lowered evenly front and rear?[/
They will maintain stock ride height when you use them with the 2005-2010 struts. I have a 2011 v6 and that's what I just did. I used them with the factory V6 performance springs and Strange Engineering adjustable shocks and struts. Works great.
2011 V6 Premium Pony Package
Bama Tunes, BBK Shorty Headers, Magnaflow Exhaust, Airaid cold air intake
Flux Capacitor with a Mr. Fusion
tombrochard is offline   Reply With Quote
Old 07-06-2016, 12:12 PM   #3
Thanks for the info! So my next question is, do stock springs (2011-14 V6) fit this strut and strut mount?
Corey | BSME
Old 07-06-2016, 02:17 PM   #4
Like I said, I already have the GT500 strut mounts, so here's what I'm planning on getting:
If I need anything else, or I'm getting something that looks dumb, let me know.
Corey | BSME
Old 07-06-2016, 06:31 PM   #5
jande063's Avatar
Instead of buying camber bolts, slot the bottom lower strut mount hole and use the factory bolts.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 07-06-2016, 07:25 PM   #6
Commercial Member
au01st's Avatar
Or instead of buying camber bolts you can turn the GT 500 mounts backwards (there should be an arrow telling you which way to mount them) and get back some camber. I did this and was still within spec when I had the alignment checked after lowering.
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 07-06-2016, 09:25 PM   #7
Yep, stock springs fit. Running those now
Old 07-06-2016, 09:27 PM   #8
I can't comment on the lowering stuff because I haven't done that. Although I think you need an adjustable upper control arm for the rear end too?
Old 07-07-2016, 06:42 AM   #9
That just makes so much more sense. Thanks for the idea!
So you're saying if I put them on with the arrow facing the rear of the car, it'll give me positive camber (to fight the negative camber that comes with lowering)? Any idea how much positive camber I can expect?
From what I've read, these springs don't drop it low enough to need those, but that's such an easy thing to swap, I'd just do it afterwards if needed. Good thinking though. Thanks again.
Corey | BSME
Old 07-07-2016, 04:57 PM   #10
Gt500 struts,shocks,springs etc.
I have gt 500 kit it's a take off kit 05-14 like new. Front and rear every thing you need for your vehicle. OEM Ford. I don't have the camber bolts, the rest is here. 185.00 you pay the ship. I have no need for them. I think that I a lot less then what you pictured!
goman is offline   Reply With Quote
Old 07-07-2016, 06:21 PM   #11
Commercial Member
au01st's Avatar
I think they actually say point toward fender. So you point them toward the engine. You'll see the arrows, just point them 180 degrees from what it says.
Old 07-07-2016, 06:49 PM   #12
jande063's Avatar
No, you do not need an adjustable upper control arm. Literally every SCCA guy has run for the last 12 years without adjustable upper control arms due to rule book conflicts. Vendors are telling you that you "have" to in order to sell more parts. I have not had any problems with my car, and I am on an unfortunately low spring (making spacers to keep this spring, but be near stock ride height to eliminate the ridiculous amount of front roll center travel which results from lowering on a strut based suspension).
By the way, here is a picture of the slotted strut for reference.
Old 07-08-2016, 08:51 AM   #13
I appreciate it, but I think I'm going to go with new parts. And I already have the strut mounts.
Good to know. Thanks!
Thanks for the input. I'll definitely be slotting my own struts.
Corey | BSME
strut mounts gtstyles2 2011-2014 Mustang GT 4 06-01-2012 07:04 PM
Strut top mounts. GT vs. GT500 tea84 2011-2014 Mustang GT 26 05-19-2012 10:23 AM
GT500 strut mounts gtstyles2 2011-2014 Mustang GT 3 09-02-2011 03:08 PM
Hard time getting FORD Racing GT500 strut mounts M3hunter 2011-2014 Mustang GT 6 05-05-2011 12:02 AM
Prothane Strut mounts runvsofthisbull Pre-2005 V6 Mustang 2 04-25-2011 02:27 PM
06:03 AM
