Acceleration is slower than it should be? - Mustang Evolution
Old 07-25-2016, 11:14 AM   #1
potvins cups's Avatar
Okay, so I've got a 2011 pony package v6 manual . Mods are Bama 93 race, JLT cai , BBK throttle body, and axle back exhaust . Rest of the exhaust is stock . Also have 19 inch amr with almost brand new all season tires (forget the tire name off hand ) ....I thought my 0-60 should be somewhere in the mid 5s at the very least. I don't take it to the track because there just isn't one close by where I live . Anyway as of recently I have only been getting mid low 6 with my best out of probably 15 runs being 6 flat . Am I just not driving it well enough ? I have messed around with launching and around 3k seems to work best. At least that's what I think but maybe I'm wrong ...any advice? Oh and also stock 2.73 gears ( i know changing gears makes a huge difference but not in my plans as of now)
potvins cups is offline   Reply With Quote
Old 07-25-2016, 11:46 AM   #2
Everything I've read says cai, tb, and axle back really don't add much hp at all. The rims are probable slowing you down a little as I can accelerate my 14 v6 with stock 17s without spinning so the wheels/ tires are adding weight.
It's also hard to say one way or another because I've read a lot about the track apps not being 100% accurate
StarzTA17 is offline   Reply With Quote
Old 07-25-2016, 11:54 AM   #3
Yea true but combined with a tune it should add at least a some power, or at least I thought it would lol
Old 07-25-2016, 01:05 PM   #4
David Young's Avatar
With just a 93 octane tune (Jon Lund) my 2011 automatic did 5.7-5.8 but i had 3.31 gears at the time. I think your times should be better than what your getting.
David Young is offline   Reply With Quote
Old 07-26-2016, 11:34 AM   #5
I set up my SCT tuner to monitor the knock sensors after loading a 91 MPT race tune. What I found is that under hard acceleration it is pulling timing, reading over +5. The hot weather is most likely contributing to the problem. It could be that I have a bad tank of 91 octane ( I live in Colorado). The end result is that I am losing allot of HP. I'm planning on using an octane booster to try to correct the problem. The product I'm ordering is Torco, found on Amazon. In short, monitor your knock sensors, it could be your not getting the full benefit of your tunes.
sleeper is offline   Reply With Quote
Old 07-26-2016, 12:45 PM   #6
Most Octane Boosters do not work and if you google the reviews of the different brands you will loose HP. You tube had for lab studies also that was useful to watch. They mostly a waste of money.
2013 RedMustang is offline   Reply With Quote
Old 07-26-2016, 12:52 PM   #7
Most yes. Do some research on Torco.
Old 07-26-2016, 12:58 PM   #8
Ok, thanks.
Old 07-26-2016, 01:38 PM   #9
Premium cars with 2.73's are mid 6 second 0-60 cars. Add a tune and you get to 6 flat, change the gearing and you get deep into the 5's. The magazines tested the base interior 3.31 cars on sticky tires to get the low 5 second 0-60's.
2011 Mustang 3.7: 13.2 @ 105
BBK Shorty, MRT H, Borla S, 3.55 Gear, MPT Tuned.
LiveWire003 is offline   Reply With Quote
Old 07-26-2016, 03:03 PM   #10
tombrochard's Avatar
I've got the same car with pretty much the same mods except I've got BBK headers and a stock throttle body. You're only going to get low 6's with that combo. I've got 3:55 gears for mine that I'm planing on installing in the next couple of weeks. That should get me into the mid 5's. I'll let you know how it works out
How did the throttle body work out? I've been thinking about getting that
2011 V6 Premium Pony Package
Bama Tunes, BBK Shorty Headers, Magnaflow Exhaust, Airaid cold air intake
Flux Capacitor with a Mr. Fusion
tombrochard is offline   Reply With Quote
Old 07-26-2016, 06:51 PM   #11
Yeah my 14 v6 premium with 2.73's does low 6 seconds and everything else is stock so that seems about right. Also what helped me get a low 6 I think it was almost a flat 6 when I tested it was resetting the fuse that controls the transmission I think it's fuse 47. Before doing that I was running high 6's. Also when I tested mine and it got a flat six was in pretty hot weather probably close to 90 degrees and it was on 87 octane on a bad country road without launching the car. Now what I will tell u is there is definetly something weird with the stock tune on my car. Some days it'll just be an absolute beast (especially after taking it in to the dealer for service) and will jump so hard coming out and the tires will chirp a bit while other days the car will be an absolute dog and come off the line real slow. I would attribute it to different variables such as weather and roads and all that kind of stuff but the difference can be seen just stopping turning the engine off and filling up the gas tank. So I guess maybe try resetting the fuse and see if that gets u anywhere especially if you notice the shifts aren't as good as they should be and also I've gotten my best times leaving my car in automatic sport mode rather than shifting it myself.
rubyredv6 is offline   Reply With Quote
My 14 seems slower than 11GT Waylap1 2011-2014 Mustang GT 11 04-05-2015 01:03 PM
07 mustang automatic accelerates slower than my 04 standard Zacrk 2005-2010 V6 Mustang 1 07-30-2014 12:45 PM
Smokes on the drivers side alot more than than the passenger side Drgula5 1979-1995 Mustang GT 4 09-15-2012 12:08 PM
suggestions for cheap, slower bike tedness The Bar 10 10-02-2005 05:08 PM
05:02 AM
