Overheating issue -2012 40k miles - Mustang Evolution
Old 07-25-2016, 01:05 PM   #1
Hello all - I've searched the internet and this forum for some insight to the overheating issue I'm having, but haven't had much luck. That being said, I apologize if this is a topic that's been covered.
I have a 2012 V6 Premium with just under 40k miles on it, and in the last month or so (great timing as its 100+ degrees in NC), I've noticed an overheating issue.
While I'm moving - no problems. However, if I am idling, whether just parked and sitting still or being stuck in traffic, my temp gauge goes up pretty quickly. Once it hits the max line, my AC just starts blowing hot air, and eventually the warning light will come on (I've only let it get this far a couple of times).
My first thought was the radiator fan isn't functioning correctly, as I had a similar issue on my Dodge Charger that I previously owned.
I was thinking maybe it was somewhat of a common problem, but again, I haven't found much about it in the research I've done.
Any ideas?
hbp0819 is offline   Reply With Quote
Old 07-26-2016, 02:12 AM   #2
oxford5pointoh's Avatar
I would agree it doesn't sound like your fan is functioning at all or as it should.
First, do you have a tune? Tuners can modify the fan functions and possibly have made it come on less or not at all
Second, have you checked to see if it's turning in at all? It's loud. Hot day, in traffic...you should hear it kick on.
Third, if you don't hear or notice it kicking on have you checked the fuse/relay and connection?
That's where I would start buddy.
Old 07-26-2016, 04:30 AM   #3
Noodles76's Avatar
Also check thermostat and water pump
Noodles76 is offline   Reply With Quote
Old 07-26-2016, 05:37 AM   #4
Strange Mud's Avatar
and while you are at it look for a new style replacement hose between the tstat and overflow tank. The new style has a check valve in it that helps prevent pump failures.
Welcome to Mevo and when you get a chance we expect to see pics as payment for our advice.
Mud
Strange Mud is online now   Reply With Quote
Old 07-26-2016, 07:31 AM   #5
Noodles76's Avatar
Mud
Did they upgrade that for the 13 and 14 cars or do they have the same house.
Old 07-26-2016, 07:43 AM   #6
FastFord13's Avatar
I think I have the old one on my 13. If I post a pic can you tell?
Sent from my SM-G925W8 using Mustang Evolution mobile app
FastFord13 is online now   Reply With Quote
Old 07-26-2016, 08:01 AM   #7
I believe so....there will be a small metal band that holds a little piece in place. I'll look if you show pics but in the V6 forum we did have a good thread about it. 6-9 months back?
Old 07-26-2016, 08:03 AM   #8
FastFord13's Avatar
Hey thanks, I'll post a pic in a couple minutes.
Old 07-26-2016, 08:05 AM   #9
https://www.google.com/search?q=modi...PzAHLsXo0pM%3A
see if this works...small band on left side of hose = check valve. $20 on-line 5-10 minute job
Old 07-26-2016, 08:09 AM   #10
FastFord13's Avatar
Yep, from the link you posted it looks like I have the old version.
Is their a tsb for this part, or should I go ahead and just order one?
Thanks 4 the link!
Old 07-26-2016, 08:11 AM   #11
FastFord13's Avatar
Or wait, is it this hose?
Old 07-26-2016, 08:25 AM   #12
I believe it's picture 2...I'll look at mine in a couple of hrs
Old 07-26-2016, 08:27 AM   #13
FastFord13's Avatar
Okay thanks Mud!
Old 07-26-2016, 09:44 AM   #14
Thanks 4 the link!
I replaced the hose on my 13 Cyclone. And this is the one which need to be replace not the second pic.
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 07-26-2016, 11:02 AM   #15
001 has it correct, it is the hose in the first picture. The hose coming out of the rear of the overflow. I do not see the check valve in yours...I replaced mine as preventive measure and suggest others do the same.
Old 07-26-2016, 11:48 AM   #16
tym_v6's Avatar
+1 on replacing hose as preventative maintenance. Are there any coolant leaks from your water pump? It seems that the failure mode when they start to go is that they leak first.
If all of the above is OK and the fan is working, I'd echo the suggestion of replacing the thermostat. If it isn't opening fully, the radiator isn't able to do its job and the car will tend to overheat while idling. The heat coming on is the car going into a failsafe mode to protect the engine.
Old 07-26-2016, 12:42 PM   #17
FastFord13's Avatar
Thanks guys! I'll get on that asap.
When or did Ford ever correct this? And if the water pump fails is it covered under the 5y powertrain warranty? I'm guessing no lol.
Old 07-26-2016, 12:55 PM   #18
2013/2014 my guess is they figured it out in 2013 but used all the old hoses to get them out of the system. Most folks I've seen have had it under 5/60 wtty, but I did read a few that had it denied under it was the hoses fault. Those would be dealers to avoid.
Old 07-26-2016, 01:54 PM   #19
No tune, so that's not it. I don't believe I hear it turning on period. I'm trying to check the fuse now, and have located it...but dumb question...how does it come out? Does it just pull or is it clipped in somehow? I tried yanking on it pretty good but don't wanna break it.
Thanks for the welcomes and advice.
Old 07-26-2016, 02:40 PM   #20
Jbone007's Avatar
https://www.ifixit.com/Guide/2010+20...lacement/10823
Haven't had to change one in a few years but it should pull straight out.
Jbone007 is offline   Reply With Quote
Old 07-26-2016, 03:23 PM   #21
Diehard's Avatar
Keep in mind that not only could the fuse cause the fan not to work but also the two relays that control the fan speed.
Here's a typical wiring diagram for that system.
Ford Service Manuals - Wiring Diagrams
Also, radiator shops(if they still exists) can generally check for adequate flow from the water pump.
FYI...
http://asc-ind.com/cooling-system-in...f-overheating/
Old 07-26-2016, 03:44 PM   #22
pull hard to get fuse out, but if it popped 1x it is likely to pop again. you need electrical skills to tshoot this. As others mentioned relays/sensor/fan could all be bad. Heck I bet it even goes through the engine control module.
check fuse the check for voltage at fan when engine is hot (BE CAREFUL IF IT'S A LOOSE WIRE FAN CAN COME ON!!!!!!!)
Old 07-27-2016, 01:35 AM   #23
I hope you can get it fixed with a simple fuse. Who knows, it could be a fluke.
Easiest way to test a fuse is to get a 5.00 test light and once you have it on a ground, poke the top of the fuse where you see the metal on Both sides. If you don't get a light on both sides...she is blown.
Also, removing them can be a pain. Simple needle nose pliers and a good pull straight up and it should come out. But they also make little fuse puller pliers made specifically for this.
Good luck man
Old 07-27-2016, 05:48 AM   #24
audioAl's Avatar
I replaced the hose in my 14 and my dealer charged me $45.00 for the replacement. I installed the new hose, as to the fuse and fan you seem to have plenty of help, great forum. Yes, there is a TSB on this hose.
2014 DIB 3.7 "Blue Cyclone" on 275/40/18 RE 760 Sports/Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/J&M Bushings/ BMR cradle lockout/BMR CB006 brace/BMR cc bolts/S-04 pole position'
Old 07-30-2016, 04:00 PM   #25
David Young's Avatar
Find anything wrong yet? Just wondering
David Young is offline   Reply With Quote
Old 07-31-2016, 06:05 PM   #26
Hawkstang's Avatar
Region: Iowa
Order it. Took me 7 mins to replace.
Sent from my SM-G930V using Mustang Evolution mobile app
Hawkstang is offline   Reply With Quote
Old 08-01-2016, 06:07 AM   #27
Me? If so, I changed mine a year or two ago
Old 08-01-2016, 03:54 PM   #28
Changed the fuse, and haven't had a problem since, so hopefully we're good now
Thanks everybody
Old 08-02-2016, 06:27 AM   #29
Thanks everybody
Great!
727-HP supercharged mustang for $40k Cooolbreeez General Mustang Discussion 17 05-13-2016 08:38 PM
Lowering springs on 40k mile GT? Safe? Jvibe92 2011-2014 Mustang GT 19 01-27-2015 01:47 PM
Another Issue (overheating) bradh2414 Pre-2005 V6 Mustang 18 07-27-2011 04:19 PM
Overheating issue Edge4 1979-1995 Mustang GT 11 07-19-2011 10:06 PM
Would it be a good trade? my 2001 Ford Mustang V6 80000 miles for a 69 Cougar 351W 90000 miles? annawan General Car Discussion 7 03-03-2010 04:34 AM
04:04 PM
