Rear end off center - Mustang Evolution
Old 07-29-2016, 04:42 PM   #1
tombrochard's Avatar
Rear end off center
Hi guys, here's a weird one - stock suspension in rear (other than new shocks) and my rear end is off center toward the drivers side by about an inch or less. Anybody hear about that or see it? The car has 70k miles on it
2011 V6 Premium Pony Package
Bama Tunes, BBK Shorty Headers, Magnaflow Exhaust, Airaid cold air intake
Flux Capacitor with a Mr. Fusion
tombrochard is offline   Reply With Quote
Old 07-29-2016, 04:49 PM   #2
FastFord13's Avatar
Mine was off from the factory also, stayed like that until I lowered and added an adjustable pan hard part.
From what I've read in the past we weren't the only ones.
Sent from my SM-G925W8 using Mustang Evolution mobile app
Old 07-29-2016, 04:51 PM   #3
Its been known to happen. Throw an adjustable pan hard bar on and you will be good.
Old 07-29-2016, 04:53 PM   #4
Robostang's Avatar
Not unusual in our cars. Most people don't notice it with stock tire width and stock suspension. Those of us that are lowered have installed an adjustable panhard bar to correct it as it can get worse when lowered.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 07-29-2016, 07:11 PM   #5
That's so weird, I wonder if it came that way or just loosened up over time. In any case I'll end up putting a Pan hard bar in
Old 07-29-2016, 07:23 PM   #6
FastFord13's Avatar
I don't think it can loosen over time to throw off the rear end.
There is literally no play on the stock bar.
Old 07-29-2016, 07:33 PM   #7
Robostang's Avatar
There is no adjustment on the stock bar and no room for play so I say It came that way.
Old 07-29-2016, 07:43 PM   #8
Wow. Weird. Oh well, I've always wanted to buy an adjustable pan hard bar....ill just add it to the list 😜
Old 07-29-2016, 07:47 PM   #9
Robostang's Avatar
Might as well lower it while you are at it 😮
Old 07-30-2016, 06:17 AM   #10
Nah, I could have done that with all the used stuff I bought but I really don't want to deal with clearance issues on a daily driver. On the other hand, since I'll have the panhard bar it opens up the opportunity I guess
Old 07-30-2016, 08:40 AM   #11
They seem to come with a 3/8 to 5/8 bias, some are closer than others. Adjustable phb fixes it right up.
Sent from my SM-T710 using Tapatalk
2013 SGM 3.7 | MPT Tune | JBA Titanium Ceramic Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | BBK TB | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 07-30-2016, 12:39 PM   #12
David Young's Avatar
My off center got 4mm closer to perfect after i lowered it. I'm not going to buy an adjustable pan hard bar.
David Young is offline   Reply With Quote
Old 07-30-2016, 02:32 PM   #13
Robostang's Avatar
Yup. It all depends on which direction it was off center from the factory.
Old 07-30-2016, 03:33 PM   #14
How are you measuring, the wheel to the quarter panel?
SVOGT302 is online now   Reply With Quote
Old 07-30-2016, 05:36 PM   #15
oxfordwhite's Avatar
Yep! I think they're all off center. I didn't notice it till we put wider wheels on. Then it stood out like a sore thumb. Adjustable PHB later-all fixed. I swear it handles better too.
oxfordwhite is offline   Reply With Quote
Old 07-30-2016, 05:54 PM   #16
Thanks, mine was off a good 1/2" to the drivers side too but I still want to check the actual tracking. Probably get it up on a rack after I lower the rear.....
Old 07-31-2016, 03:15 AM   #17
audioAl's Avatar
Your right, from the factory built wrong, unforgivable from FORD! I helped a neighbor near me with his GT 500 trying to kill him, He consulted with me and I advised him to replace the lca's and get an adj. BMR panhard. The lca's were "stamped unit's", on a GT 500??
2014 DIB 3.7 "Blue Cyclone" on 275/40/18 RE 760 Sports/Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/J&M Bushings/ BMR cradle lockout/BMR CB006 brace/BMR cc bolts/S-04 pole position'
Old 07-31-2016, 05:58 AM   #18
I take a string around 2 feet long. On one end i tie some washers to hold it straight. I use painters tape to tape the top of the string 6 inches above the wheel on the body after i center the line with the center cap of the wheel. I do this to both sides. Then I measure from the wheel lip to the string.
I can't explain this in a way to make sense. I was going to take a picture the last time i measured but i forgot.
Old 07-31-2016, 05:58 AM   #19
I put a Steeda adj panhard bar & brace, next will be a UCA, then LCA's & finally rear springs, all Steeda. I'll leave the front alone being on NJ roads.
Old 07-31-2016, 06:02 AM   #20
Thanks...
Pretty much what I did too.... Unreal how they are off.
Old 07-31-2016, 07:36 AM   #21
It will handle better, the poly bushings take the deflection the soft oem rubber bushings would allow out of the equation.
Old 08-02-2016, 08:30 PM   #22
That's the nature of the 3-link solid axle rear end, they're never perfectly centered from the factory. Plus, under compression, the panhard bar will push the axle out more to the left. Then at re-bound, it'll re-center where it was at ride height. It does this too on aftermarket setups unless you have something like the Whiteline Watts Link.
2013 v6, performance pack, mt82 manual, MGW Race Spec shifter, SVE Drifts 19x9.5, H&R Supersport springs, Koni yellows, BMR panhard bar, adjustable UCA and LCA, shorty antenna, GT500 strut mounts, black painted roof, Roush splitters all around, GT hood and fog lights.
Josh_101 is offline   Reply With Quote
Wanted: Center cap off brbo wheels Redstang1 Mustang Parts for Sale and Wanted 3 06-26-2013 06:59 PM
Wheel is off center in wheel well. S197stanGT 2005-2010 Mustang GT 9 03-04-2013 03:55 AM
Off center pony front grill. Manning3398 2011-2014 Mustang GT 5 03-21-2012 07:25 PM
How long is a mustang rear end compared to a ranger rear end. lenth meaning from tire to tire? macray33 General Mustang Discussion 1 03-14-2010 04:43 AM
Is a 1995 Mustang V6 rear end different from a 1995 Mustang V8 rear end? celyddon Pre-2005 V6 Mustang 2 08-25-2009 07:56 PM
12:58 PM
