Accelerate quickly, yellow wrench light, car won't accelerate?? - Mustang Evolution
Old 12-31-1969, 07:00 PM
Guest
Posts: n/a
h
  Reply With Quote Moderated Post
Old 08-09-2016, 08:50 AM   #1
Slickmullet's Avatar
So this has happened twice, when I accelerate very hard I get a yellow wrench light and the car will not accelerate any more, idles rough. I turn the key off and on, it takes a second to get started but after runs ok and the wrench light goes away. Ideas?
2012 Race Red 3.7 Coupe: Steeda CAI and 93 Steeda Tune / Borla S-type Axle-Backs / Boss Strut Tower Brace / FRPP 3.55
Slickmullet is offline   Reply With Quote
Old 08-09-2016, 09:07 AM   #2
Strange Mud's Avatar
internet diagnosis=throttle body. Try cleaning it 1st
New England Cruise June 3rd!
see regional forum for details
http://www.mustangevolution.com/foru...post4261510322
Old 08-09-2016, 09:10 AM   #3
Ok. That's an easy start. We'll see how it goes.
Old 08-09-2016, 09:50 AM   #4
Hawkstang's Avatar
Region: Iowa
Does the wrench light stay solid or blink? Could be a bad coil as well.
Sent from my SM-G930V using Mustang Evolution mobile app
Hawkstang is offline   Reply With Quote
Old 08-09-2016, 10:47 AM   #5
Wrench light stays solid. I turn they car off and back on and it goes away. It's only happened when I slammed the gas, hauling ***. Twice in 2 weeks.
Old 08-09-2016, 11:24 AM   #6
Hawkstang's Avatar
Region: Iowa
Bad coil can act up on wot. It's happened to me. Same effect after light went on too. Then normal driving later.
Old 08-09-2016, 12:30 PM   #7
Sounds like throttle body to me. I had replaced mine from AM for the larger one and if was defective and that is what it did.
2013 RedMustang is offline   Reply With Quote
Old 08-09-2016, 02:48 PM   #8
Any good way to test coils?
Old 08-09-2016, 03:01 PM   #9
Hawkstang's Avatar
Region: Iowa
Google "how to test ignition coils". Got some good step by steps on there
Old 08-09-2016, 03:09 PM   #10
Cool. Thanks.
Old 08-09-2016, 03:16 PM   #11
Hawkstang's Avatar
Region: Iowa
Sounds like if you see a orange spark when you test it, it means a bad coil. Again, Im not expert so be very careful checking this. Sounds like if you dont follow the steps carefully you could damage your engine. Keep us posted plz.
Old 08-09-2016, 03:57 PM   #12
The throttle body had some gunk on it. Cleaned it up. I'll give this a go initially.
Old 08-09-2016, 03:58 PM   #13
Hawkstang's Avatar
Region: Iowa
Prob your culprit. Good luck!
Old 08-09-2016, 03:59 PM   #14
Hawkstang's Avatar
Region: Iowa
Also, if yout tb had gunk in it you may want to get some maf cleaner and clean your maf. That could be a factor as well.
Old 08-09-2016, 04:04 PM   #15
Instead of guessing what triggered the CEL, why don't you scan for codes?
Old 08-09-2016, 07:23 PM   #16
Stop wot'ing. Problem solved : )
Doyal_McNeff is offline   Reply With Quote
Old 08-11-2016, 12:35 PM   #17
Hawkstang's Avatar
Region: Iowa
Hey slick, figure anything out yet?
Old 08-11-2016, 08:30 PM   #18
Throttle position sensor.
Luv2shart is offline   Reply With Quote
Old 08-11-2016, 08:37 PM   #19
Hawkstang's Avatar
Region: Iowa
Is your name slick? Oh wait... with 50 screen names it might actually be! Lol
Old 08-11-2016, 08:43 PM   #20
Haha is that you Doyle? Jeez I can't keep track of your screen names lol.
Old 08-11-2016, 08:47 PM   #21
Hawkstang's Avatar
Region: Iowa
Yup, you got me. Im a pathetic loser that cant stay away from a forum that Ive been banned from multiple times.
Darn it!!
Old 08-14-2016, 12:12 PM   #22
I haven't had any other issues really. Keep y'all posted.
Old 08-18-2016, 09:25 AM   #23
Happened again. No CEL. Tried to read codes and no code available.
Old 08-18-2016, 10:55 AM   #24
Hawkstang's Avatar
Region: Iowa
Hard accel? Flashing or solid?
Old 08-18-2016, 03:42 PM   #25
It's happened 4 times in 2 days. Finally threw a code. Throttle Body Actuator fault / Throttle Body stuck open.
Any suggestions? Will the car run like this?
Old 08-18-2016, 03:46 PM   #26
It also showed traction control lights on, blinking in and out. Could it be a bad tune? Bad PCM?
Old 08-18-2016, 03:55 PM   #27
Maybe a bad TPS? Where is the TPS located? I'm on freaking vacay and the pos has to start acting up...
Old 08-18-2016, 04:52 PM   #28
iguanaman3's Avatar
The TPS is in the throttle body which is not repairable. Replacing the entire unit is the only option. Good luck.
iguanaman3 is offline   Reply With Quote
Old 08-18-2016, 05:42 PM   #29
Ok man. Thanks for the info. So does it sound likely that the Throttle Body is the culprit?
Old 08-18-2016, 09:55 PM   #30
iguanaman3's Avatar
The symptoms are consistent and the codes pretty much verify that the fault is in the throttle body mechanism. The ECU is pretty fussy about it because the engine is "drive by wire". It goes into "limp mode" to protect you. Can you imagine if your throttle was really "stuck open"? That might cause an accident. LOL
Old 08-19-2016, 11:07 AM   #31
Is there a "relearn" needed or anything on install?
Old 08-19-2016, 12:16 PM   #32
I would do idle re-learn (see manual)
Old 08-19-2016, 12:38 PM   #33
I'm guessing it is the throttle body. My car was acting similar and that is what it was on mine. Replaced the throttle body with the BBK and no further issues.
andrev6 is offline   Reply With Quote
Old 08-19-2016, 02:01 PM   #34
I'm just going to beat it with a sledgehammer.
Old 08-19-2016, 02:20 PM   #35
wrench light on the dash jessesse 2011-2014 V6 Mustang 17 06-24-2016 12:28 PM
Wrench Light/check engine krusignuolo 2005-2010 Mustang GT 8 02-04-2015 12:37 PM
2012 Mustang GT wrench light Sprintradc 2011-2014 Mustang GT 7 07-24-2012 02:19 PM
How to quickly accelerate the 2012 Mustang? imported_Matt General Mustang Discussion 2 07-20-2011 08:24 AM
won't accelerate upton7 Pre-2005 V6 Mustang 14 01-24-2010 06:16 PM
09:35 PM
