First gear not engaging - Mustang Evolution
Old 08-12-2016, 12:19 PM   #1
elkoritaNAY's Avatar
Had to start off 2nd. Drove up cruising speeds as soon as I hit my exit I felt first second stiff gear wouldn't go into first. Drove around some more turned it off and back on an nothing. Just dropped it off at the dealer and agrees that first very very notch up. Let's see what it is...
410 rwhp 320 ft-lbs
elkoritaNAY is offline   Reply With Quote
Old 08-12-2016, 05:51 PM   #2
Got call back from dealership they had no problem getting into first during test drives... Noted it if it occurs again... Anybody else have similar issues? If so, what adjustments did u guys do?
410 rwhp 320 ft-lbs
Old 08-12-2016, 07:47 PM   #3
FastFord13's Avatar
Have you done anything to your shifter, or is it still the stock stuff?
Oem fluid?
Sent from my SM-G925W8 using Mustang Evolution mobile app
Old 08-12-2016, 09:06 PM   #4
Sr bracket and all fluids have been drained and replaced...
410 rwhp 320 ft-lbs
Clutch is engaging farther than normal kb3030 Pre-2005 V6 Mustang 7 12-02-2014 01:36 PM
Clutch not engaging right !! jking97gt 1996-2004 Mustang GT 37 12-01-2014 08:19 AM
Sport mode not engaging _nathannnn 2011-2014 V6 Mustang 11 05-28-2014 07:04 AM
Does your clutch make a weird noise when engaging disengaging? pwrby4d 2011-2014 V6 Mustang 19 08-06-2012 01:37 PM
Shattering noise and vibration when engaging the clutch only on first gear and reverse? wolfe General Mustang Discussion 3 03-10-2010 05:40 AM
10:04 PM
