Best drop in air filter - Mustang Evolution
Old 09-06-2016, 07:15 PM   #1
Hey guys I was checking out air filters on American muscle and wanted the opinion of some of you out there who might have the filter or have any opinions on what you think of them. First of all my car has 25000 miles is it too soon to change factory air filter? I think the interval is 30000 on the stock ford one. Secondly I want a drop in not cold air intake as I want to try to keep the car as stock as possible in order to avoid issues with the warranty. Ok so I noticed two k and n filters the regular drop in and the ford racing drop in. What's the difference between these two? To me they looked the same. I also noticed two afe filters a regular drop in and then one with a kind of weird shape. Now which do you guys think is the best in terms of performance mpg sound etc. I know I shouldn't expect much but since I'm going to keep the car for a while I think a washable filter would be the best option economically. Thanks for the guys.
rubyredv6 is offline   Reply With Quote
Old 09-06-2016, 07:31 PM   #2
TrevorMCA's Avatar
An intake won't void your warranty but K&N is a trusted brand. I personally have one and it'll go 50,000 miles before they recommend cleaning it. I personally do it more because it's not that big of a hassle to clean it. I'm not sure about the difference in the two that you mentioned but you should be able to chat with a rep on the website and he can tell you. Good luck.
---------- Post added at 01:31 AM ---------- Previous post was at 01:30 AM ----------
What year is the car?
TrevorMCA is offline   Reply With Quote
Old 09-06-2016, 07:45 PM   #3
Shadetree43's Avatar
I use an aFE drop in. It's a dry filter & extremely well made (but pricey). When it's time, remove, & hose off, let dry & reinstall. Should last as long as the car.
Shadetree43 is offline   Reply With Quote
Old 09-06-2016, 08:17 PM   #4
GrabberMeBlue's Avatar
Same one I have. AFE Pro-Dry.
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 09-06-2016, 08:19 PM   #5
TrevorMCA's Avatar
Try using simple green when you clean it. Spray all over and let it sit for 10 minutes then hose off. Works wonders
Old 09-06-2016, 10:30 PM   #6
Mlp07's Avatar
The k&n will actually give you loss of hp, not much but it will.
Mlp07 is offline   Reply With Quote
Old 09-07-2016, 10:20 AM   #7
TrevorMCA's Avatar
How does that work?
Old 09-07-2016, 10:50 AM   #8
Senior Member
dgc333's Avatar
I can see no gain but there is no reason a K&N would cause a loss of power.
Dave
dgc333 is offline   Reply With Quote
Old 09-07-2016, 10:58 AM   #9
Diehard's Avatar
I assume that's based on the actual dyno test someone made and which is on Youtube somewhere.
But I wonder, how do we know if the AFE Pro-Dry is any different? I know I can't tell.
I was thinking I may put the stock filter back in to see if I notice a difference with MPG.
Old 09-07-2016, 11:01 AM   #10
TrevorMCA's Avatar
The stock filters are already amazing as it is just don't look as cool. I would guess the mpg is close to if not the same
Old 09-07-2016, 11:18 AM   #11
ajkillgore's Avatar
WIX.
2012 Race Red Convertible V6
A work in progress.
New bits added as I can!
ajkillgore is offline   Reply With Quote
Old 09-07-2016, 11:20 AM   #12
Mimi15GT's Avatar
Either filter is good. You won't notice any gains, but at least they last a lifetime.
Mimi15GT is offline   Reply With Quote
Old 09-07-2016, 11:28 AM   #13
Diehard's Avatar
Originally Posted by ajkillgore View Post
WIX.
WHY?
Old 09-07-2016, 11:32 AM   #14
Mlp07's Avatar
Dave
Someone actually made a test on it, loss around 4hp I think compare to the stock paper one.
Sent from my SAMSUNG-SM-N915A using Mustang Evolution mobile app
Old 09-07-2016, 11:33 AM   #15
Mlp07's Avatar
Here's proofs just found the website http://www.svtperformance.com/forums...nt-Filter-Test
Old 09-07-2016, 12:39 PM   #16
ajkillgore's Avatar
Originally Posted by Diehard View Post
WHY?
WIX..... I've used them for many years on several brands of vehicles including my current mustang, a Jaguar XJ6 I once had. A couple of Land Rovers, and a couple of Dodge Quad Cab pickups.
No oils, no brand name pricing and gave great performance both in air flow and cleaning.
I also use their oil filter. I did the research several years ago and they came out on or near the top enough to convince me.
I'm sure the links are still out the somewhere.
I've tried the K&N but did not get the performance boost promised and to me it was messy and a lot of cash to pay for an air filter!
Others will disagree but I don't care!
A work in progress.
Old 09-07-2016, 12:39 PM   #17
DrDave's Avatar
The K&N drop in filter was developed in collaboration with Ford Racing and, according to Ford Performance, provides an immediate 7 HP gain with no other changes. K&N is proven and is approved by Ford as far as warranty issues go.
I've personally given a lot of thought to going with the aFE filter, but have not been able to find any substantiated evidence of superiority to the K&N.
My recommendation is go with the K&N or stay with the stock filter.
DrDave is offline   Reply With Quote
Old 09-07-2016, 12:49 PM   #18
Diehard's Avatar
The need to require oil discourages some from the K&N. Must be careful not to over oil or it can mess up your MAF.
I have a K&N in one of my cars with no problem. I haven't had to re-oil it yet though.
Old 09-07-2016, 02:32 PM   #19
Mimi15GT's Avatar
Well if Wix is a lifetime filter for less money, then it is well worth it. I think he's looking for one that doesn't have to be replaced, but just cleaned.
Old 09-07-2016, 02:52 PM   #20
Look close at the Ford stock air cleaner filter and you can plainly see it has more then enough area to feed more air into the engine then the engine needs.
I have an Airaid "CAI"on my car but more for the great sound and eye candy under the hood then anything else.
Old 09-07-2016, 03:41 PM   #21
ajkillgore's Avatar
How much are the recharge kits now? A WIX filter runs around $18.
A work in progress.
Old 09-07-2016, 04:19 PM   #22
TrevorMCA's Avatar
The recharge kits are about $15-$20 but you only have to do it every 30k-50k. I have AIRAID and its non-oiled so I just use simple green
Old 09-07-2016, 05:09 PM   #23
ajkillgore's Avatar
I'd not heard of the AIRAID till today. But for $68+- ($85 some places) you can get one of those and wash it every 30k or so miles. In 200,000 miles you'll do that call it 6 times.
Get a fresh WIX every 30k and in 200,000 you'll spend about $108.
So you'll save a few bucks with the AIRAID and I'm sure washing it out with the simple green is no big deal.
I'm also sure that either one gives equal air cleaning and "performance"
Maybe I'll look at the AIRAID in about 25000 miles!
Just have to see what mood I'm in when the time comes!
A work in progress.
Old 09-07-2016, 05:52 PM   #24
TrevorMCA's Avatar
Is yours a drop in or a CAI? I know this thread is about a drop in but I can't remember who started it
2012 Kona Blue MCA Cyclone
AIRAID CAI
4.10 gears
Ford Racing Axle Backs
'Unknown Tune'
Old 09-07-2016, 06:35 PM   #25
ajkillgore's Avatar
AIRAID CAI
4.10 gears
'Unknown Tune'
Mine's a drop in. Not going to do a CAI . I read on this very forum about how while they look pretty there is no real power gain as the stock air intake is, you guessed it, a basic factory CAI.
A work in progress.
Old 09-07-2016, 07:53 PM   #26
TrevorMCA's Avatar
Yeah personally I wouldn't buy one for performance just for looks and only if it was cheap enough. Mine came on the car when I bought it so can't complain
AIRAID CAI
4.10 gears
'Unknown Tune'
Old 09-08-2016, 04:15 AM   #27
atgonzales's Avatar
Check Advanced Auto Parts for the K&N filter, they have a code for 10% off and free pick up at a local store, hope this helps
Anything in life worth doing is worth over doing, moderation is for cowards
Anything in life worth doing is worth overdoing, moderation is for cowards
atgonzales is offline   Reply With Quote
Old 09-08-2016, 04:44 AM   #28
I run the afe pro dry, gains? Doesn't hurt and offers more surface area. Of course I bought it because it's cleanable and non oiled which will last years.
Stay away from oiled filters, they only end up slowly gunking up your maf sensor as the oil gets sucked off the filter.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 09-08-2016, 06:55 AM   #29
Senior Member
dgc333's Avatar
I find a sample of one interesting but hardly conclusive of anything. It would be even more interesting to see the results of a stock filter with 10k miles vs a K&N with 10k miles.
Old 09-08-2016, 07:14 AM   #30
Everyone is free to run what they please but before people start claiming it pays for itself you need to realize that is roughly the cost of 4-5 paper filters. You would need to keep the car for a minimum of 120,000 miles to break even (not factoring in the cleaning kits). Very few people will keep/ drive the car long enough to see any sort of cost benefit from it.
StarzTA17 is offline   Reply With Quote
Old 09-08-2016, 07:30 AM   #31
I may just end up putting a new factory air filter in. Due to my driving habits it would take a long time to justify getting a rewashable filter. Somewhere like 5 years when I consider how much I drive per year. So if there is no real gain at all in performance or mpg then it seems like the best option for me at least would be to just get a factory air filter.
Old 09-08-2016, 03:14 PM   #32
VIG
VIG's Avatar
Region: Delaware
I did an experiment and the stock filter actually flows better than the K&N drop in. Also the stock has more filter area than the K&N.
Also, keep in mind, that the stock V6 filter is the same exact filter as the V8. It flows more than enough air for another 1.3 liters of displacement.
Honestly, on the intake side of things Ford nailed it.
Instagram: workshardplayshard
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 09-08-2016, 03:21 PM   #33
Hi Vig,
Just what I said.
I really don't think the Ford filter can be beat for performance and filtering.
Old 09-12-2016, 06:02 PM   #34
Update
Went into the auto parts store to get a new stock filter but they had the ford racing kn filter discounted and ended up getting it. Soon as I put it in I noticed a bit louder of intake sound, air/fuel ratio according to the ford monitors on dash were the same except when I accelerated it didn't go down as much as it used to, it felt a bit faster and more responsive at higher rpms, and mpg seems down a bit, also according to the 0 to 60 timer it's about the same as with the stock filter except the launch wasn't great so I'm thinking it could be better. Keep in mind that what I have noticed could just be the difference between a clean and a dirty filter and not the difference between the stock filter and the kn filter.
Now here's where things really change up. So I was happy with the filter but started thinking hmm maybe the ecu hasn't adapated to the added airflow, if in fact there's any, so I disconnected the battery about 10 or 15 minutes and disconnected the MAF in case it made a difference at all. After reconnecting everything I started the car up and engine sound was way louder like a lot while idle rpm was still the same. Also there's a slight pop in the exhaust when accelerating which activities wasn't there before. Note this whole part was tested with the car parked. Will update tomorrow on if there are any other gains or losses when I take the car out on the road.
Best drop in air filter? ragtopman 2005-2010 Mustang GT 13 07-09-2015 05:42 PM
Is anyone using the K&N drop in air filter? ronnie948 2011-2014 V6 Mustang 11 07-10-2012 08:17 PM
K&N Drop In Air Filter 08Mustang 2005-2010 V6 Mustang 6 04-17-2012 12:14 PM
K&N drop in air filter Everett Mustang Parts for Sale and Wanted 7 02-23-2011 11:40 PM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 05:37 PM
06:18 PM
