Ride Height? - Mustang Evolution
Old 09-14-2016, 08:47 PM   #1
wmschoonover's Avatar
Ride Height?
Almost finished installing my Air Lift Performance Kit and was curious what everyone that's lowered sets as their ride height?
I am more curious in people that are using this or a similar system or coil overs so they are adjusted to their desired height.
I know people suggest a string and weight taped to the fender so just need a SAFE height to set so that I won't damage anything turning.
Here's aired out in the front only.
Name:	ImageUploadedByMustang Evolution1473904021.616931.jpg
wmschoonover is offline   Reply With Quote
Old 09-15-2016, 05:47 AM   #2
David Young's Avatar
Not too many people with the air lift, looks cool by the way. I only have a 1 inch drop with springs on the front and it measures at 27 1/16 inches from the ground to the lowest part of the fender. This might give you a basic ideal
David Young is offline   Reply With Quote
Old 09-15-2016, 06:11 AM   #3
Noodles76's Avatar
Are you on instagram? Getting bagged is the new it thing like pokemon.
OP if you are on instagram there are a ton of bagged cars /mustangs if you want to message them out might be a good resource for you.
Noodles76 is offline   Reply With Quote
Old 09-15-2016, 09:01 AM   #4
Zombiefro's Avatar
^ This is good advice, the bagged community is all on instagram, or maybe a facebook group.
Zombiefro is offline   Reply With Quote
Old 09-15-2016, 09:45 AM   #5
Thanx, I'll check into Instagram when I have time later.
I've messaged a forum member with this same kit and he's helped me but this question isn't just about air suspension.
Coil overs allow the same adjustments. It's just more labor intensive to change and basically impractical in my situation so I want to set the height for daily driving.
I just wanted to know how much clearance I need to safely turn the wheel when not at stock height.
Old 09-15-2016, 09:06 PM   #6
Harm_3.7's Avatar
Ride Height?
Name:	ImageUploadedByMustang Evolution1473991506.206919.jpg
ID:	205105Click image for larger version
Name:	ImageUploadedByMustang Evolution1473991530.470629.jpg
First picture is my ride height at 45 psi all around and then second picture is aired out.
IG: justaslow3.7
Harm_3.7 is offline   Reply With Quote
Old 09-15-2016, 11:40 PM   #7
Tommybeata's Avatar
lowering springs about an inch front and back, 19" wheels and she stand just fine. wouldn't mind dropping another half inch all around though. Click image for larger version
Name:	ImageUploadedByMustang Evolution1474000813.794967.jpg
2012 Grabber Blue v6
3.73 gears
SR lowering springs
SR Panhard bar
73mm throttle body
Tommybeata is offline   Reply With Quote
Ride Height? JimmyMosqueda Pre-2005 V6 Mustang 25 06-06-2013 08:44 PM
ride height R6man 1996-2004 Mustang GT 21 04-06-2013 09:27 AM
Coilover ride height looks question? McQueen Mustang Paint, Appearance & Detailing 5 01-07-2013 02:59 PM
Ride Height Change obxdude018 Pre-2005 V6 Mustang 5 08-10-2010 08:31 AM
Would it be possible to make a 82 Mustang 4 wheel and still retain it factory ride height? wolfgang General Mustang Discussion 3 03-19-2010 10:17 PM
03:06 PM
