SCT X4 not properly reading data from my car - Mustang Evolution
Old 09-19-2016, 08:39 PM   #1
Ferr's Avatar
So my SCT X4 has been reading datalogs from my car completely wrong. It also tends to turn it self off a lot while I'm driving so I am thinking the OBDII port is loose or the cable connecting it is. The port does wobble which it did from when I got the car but I got it used so I'm not sure if it was like that stock, if someone could help me out I'd greatly appreciate it!
I also took a video of what the SCT X4 is reading the data as. The car was just idling but the rpms are flying all over the place.
Ferr is offline   Reply With Quote
Old 09-19-2016, 10:29 PM   #2
A few things.
1. I think you are supposed to have the key in the second position, not the"Run" position, do not start the car. This is how most devices connect to the PCM.
2. If this doesn't work you might be entering the demo mode somehow. Hit configuration instead of continue and then select "FORD GAS 08 NEWER".
If you are trying to datalog with a laptop, follow these instructions on bama's site.
https://support.bamaperformance.com/...ama-SCT-X4-SF4
AKDMB is offline   Reply With Quote
How to properly wax a car? centrifugal 4ce Mustang Paint, Appearance & Detailing 46 06-03-2014 12:08 PM
headlight not fitting properly? austinknoll Mustang Paint, Appearance & Detailing 2 01-25-2012 11:18 PM
Car air conditioner not working properly? wicleah26 1996-2004 Mustang GT 3 03-09-2010 10:26 AM
SCT Data log how-to now up! SpectorV General Mustang Discussion 2 12-31-2009 06:45 PM
10:22 AM
