Battery Pad & Battery Warranty? - Mustang Evolution
Old 09-23-2016, 06:13 PM   #1
I have a 2014 V6 that is 26 months old 28,000 miles. I noticed today that the pad that goes around the battery is disintegrating. Not the pad actually but the outer black fabric. When you touch it, it just dissolves. Has anyone else had this happen? Is this something that is covered under the 3 year / 36 month warranty? Also, what about the battery itself? For the first time I noticed corrosion on the positive terminal and cleaned it off. Is that a sign the battery is about to go?
tucsondivots is offline   Reply With Quote
Old 09-23-2016, 07:14 PM   #2
iguanaman3's Avatar
Both the crumbling holder and the corroded terminal are evidence of acid leakage from a defective battery. Go see your dealer.
iguanaman3 is offline   Reply With Quote
Old 09-24-2016, 05:43 AM   #3
Hampton CIT's Avatar
Had the exact same issue on my old sixer. I'm not sure I had a leak as the outer synthetic fabric was disintegrating more on the outside than portions that were in physical contact with the battery. It was frustrating but the material was crap anyway so I pitched it. I was considering one of those battery and master cylinder covers that AM sells.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 09-24-2016, 07:50 AM   #4
This sounds like what is happening to mine. I do not see any evidence of leaking but the synthetic fabric is just disintegrates. I do not look under the hood too often but there was no corrosion two months ago. I
Living in Tucson, I have never gotten more than 2-3 years out of a battery. The only question is whether the battery and cover are covered under warranty. Thanks.
Old 09-24-2016, 11:08 AM   #5
iguanaman3's Avatar
Batteries spit acid out of the vents when they "leak", spraying acid on everything outside the battery. That is why the outside of the cover was crumbling. It is usually caused by overcharging, but defective batteries can also "spit:.
Old 09-24-2016, 01:02 PM   #6
Normal wear and tear
Just recently happened to my V6. The outside cover was cheap and easy to replace. I was having terminal corrosion problems. The battery was still strong but vapors leaking from the battery were corroding the positive battery cable (cable replacement cost $350) so it was simple math to just get a new battery. QED problem solved and applied some dielectric grease to the terminal for added protection.
Davo007 is offline   Reply With Quote
Old 09-24-2016, 01:45 PM   #7
Just curious. How old was your battery when you replaced it? My positive harness, cable, terminal are perfect. Corrosion was on negative terminal.
Old 09-24-2016, 01:47 PM   #8
Koryak's Avatar
I know the '14 Mustang alternators reduce charging voltage in hot weather so as not to overcharge. This usually takes a half hour of driving from a cold start after the car sits for a few days. Motorcraft batteries have a "magic eye" on top that should show a green dot if the battery electrolyte level is good & fully charged.
If the eye doesn't show anything the battery may have low electrolyte and need distilled water added up to the filler hole bottom after prying up the 2 top covers. It's not really "maintenance free" and an original '14 in AZ might need a drink
Battery warranty is usually pro-rated but Ford might go for it if the alternator charging is out of spec and boiling the water out the vents.
Koryak is offline   Reply With Quote
Old 09-25-2016, 05:46 AM   #9
David Young's Avatar
Your battery must be leaking. The battery blanket on my 2011 is still like new
David Young is offline   Reply With Quote
Old 09-27-2016, 04:36 PM   #10
Battery replacement
My battery was 3 years old. I got a great deal from the dealer on a new battery and a $25 rebate card
Old 09-27-2016, 08:46 PM   #11
Hawkstang's Avatar
Region: Iowa
Do you keep your engine bay clean. Not judging, just curious. I have a 14 and keep the bay clean... no issues so far.
Sent from my SM-G930V using Mustang Evolution mobile app
Hawkstang is offline   Reply With Quote
Old 09-27-2016, 09:01 PM   #12
Pretty clean, but not spotless. I get under the hood every 4-6 weeks to pull the fuse to reser learning. Last time no corrosion. This time big corrosion on negative terminal. That is when I noticed fabric on pad cover that goes around the battery is disintegrating. Battery "eye" is green. I have an appointment at the dealer tomorrow to ask whether this is normal. Guess I would like a replacement cover if battery ok, but wonder why is this happening?
Old 09-27-2016, 11:44 PM   #13
Hawkstang's Avatar
Region: Iowa
Let us know what you find out. Good luck!
Old 09-28-2016, 08:38 PM   #14
Crazy, But Good, Experience at Dealer
I took my 2014 to the dealer this morning to ask about the sudden corrosion on the negative terminal and disintegration of the fabric surrounding the battery cover. Since the battery is 26 months old I was not hopeful of getting a replacement but was concerned about the fabric disintegrating. The dealer found the post was leaking acid and they replaced the battery and cover under warranty. They also did an oil and filter change and rotated the tires under my "Maintenance for Life" plan. Finally, they performed the work for the airbag recall. You can imagine I left a happy camper.......for awhile. I ran an errand after leaving the dealer and thought I should take a quick look to admire the new battery. The battery and cover were new and looked great but I noticed some blackish liquid on a bracket. Then I noticed the same blackish sticky residue on the fender next to the hood. When I tried to wipe it off it took the paint down to bare metal. Apparently, the battery leaked acid when the technician lifted it out and dripped on the fender. AARGH! I immediately drove back and they confirmed what happened and quickly agreed to "100%" take care of it. 20 minutes later I drove out in a Ford Focus loaner which I will have at no charge for a few days while they repaint the area.
What a day, but I certainly am happy at how the dealer handled the situation.
Old 09-30-2016, 11:10 AM   #15
Strange Mud's Avatar
bad tech...great dealer
2012 V6 with suspension, shifting, stopping and sound mods.
Old 10-01-2016, 06:39 PM   #16
tym_v6's Avatar
Indeed, if they do a good job with the paint.
Old 10-01-2016, 07:22 PM   #17
They are saying it will be ready on Monday so will advise on the quality. However, they have a good body shop (I have used it on other vehicles) and the actual area affected was only the size of a quarter.
Old 10-01-2016, 09:28 PM   #18
Hawkstang's Avatar
Region: Iowa
Its not the size its the blend job. I agree with tym... be VERY picky and do not leave until you inspect it thoroughly in good light. Also look everywhere for overspray.
Old 10-01-2016, 09:52 PM   #19
Not my first rodeo or body shop visit, but thanks.
Old 10-01-2016, 10:38 PM   #20
Hawkstang's Avatar
Region: Iowa
Then why are you on here?
Old 10-01-2016, 10:40 PM   #21
Sorry, did not mean to offend you man.
Old 10-01-2016, 10:56 PM   #22
Hawkstang's Avatar
Region: Iowa
Not offended, just trying to help. I had to get a fender painted last year and i didnt notice the overspray on my glass roof until a few days later. Just trying to be helpful
Old 10-01-2016, 11:03 PM   #23
Revvv's Avatar
Wow, the last battery I had in my truck lasted 10 years. The battery in the Grand Cherokee was replaced last year after 7 years of abuse.
I have a hold top Optima that was used as a secondary battery in my truck. It was, and still is connected to the 1500 watt power inverter under the seat. I have had the Optima long enough for the plastic to fade. The battery is still going strong. I do have the batteries not in use on a trickle charger / battery tender that are in my dead truck. Regardless, the lifespan of your battery seems short to me.
Old 10-02-2016, 12:14 AM   #24
tym_v6's Avatar
When my battery is on its way out, I'm planning to go with an Odyssey AGM battery. Anyone have experience with AGM batteries?
Old 10-02-2016, 12:24 AM   #25
Hawkstang's Avatar
Region: Iowa
Hey revv, what part of the country you live in? Im wondering if the cold winters up north shorten my battery life... usually 6 yrs tops up here
Old 10-02-2016, 12:26 AM   #26
Revvv's Avatar
The cold definitely has an effect on battery life. I am in GA, right on the Savannah River.
Old 10-02-2016, 07:49 AM   #27
my OEM Tacoma batt lasted 11 yrs!!!!
Old 10-04-2016, 07:15 PM   #28
Hawkstang: Interesting update based on your words of caution. I still do not have my car back from the battery acid on paint issue. The area involved was about the size of a quarter on the "ledge" right next to where the hood closes. Last Wednesday they told me it would take a couple of days. Latest update is their body shop delivered my car today but the service advisor rejected it due to excess "orange peeling". They sent it back for another try. I am not sure how much they are painting but this is turning into more than I expected. At least I have a free rental while they get it right.
Old 10-04-2016, 07:26 PM   #29
tym_v6's Avatar
^Hopefully they're not just throwing excuses at you to cover for them f***ing up. Yes, that is how much I trust Ford stealerships these days after my experiences.
Old 10-04-2016, 08:11 PM   #30
Hawkstang's Avatar
Region: Iowa
They may have repainted the entire panel. Good that they rejected it though, I had to live with orange peel on my bumper. I wasnt letting that place touch my car again. Best of luck, I hope it comes back as good as it went in!
Old 10-04-2016, 08:18 PM   #31
Me, too. The affected area WAS very small.
Old 10-07-2016, 09:08 PM   #32
Final report is the repaint of the spot with battery acid turned out perfectly. No overspray or issues.
**2013 Gear swap & tune while keeping warranty? HanSolo 2011-2014 V6 Mustang 18 06-04-2016 01:12 PM
Aftermarket parts & Warranty Maleficent 2011-2014 V6 Mustang 4 09-10-2014 04:12 PM
Bama tuner & warranty Mathew r Wright Other Special Edition 4 11-09-2012 09:42 AM
governor, driveshaft & warranty ashpow24 2011-2014 V6 Mustang 18 06-18-2012 05:51 AM
exhaust & warranty 04TRV6 2011-2014 V6 Mustang 20 03-04-2012 07:26 PM
05:17 AM
