Strange noise when turning - Mustang Evolution
Old 10-01-2016, 06:43 PM   #1
Location: Camp Pendleton North (San Clemente/Orange County
So I've had this issue a while and still haven't been able to find out what exactly the problem is.
It's an odd noise when turning slow such as into a parking spot sounds almost like the control arm is sticking into something as the wheel turns but there are no marks on it?
Or maybe the electronic steering assist is bad?
Any ideas?
Sent from my 0PM92 using Mustang Evolution mobile app
swhitfield2013 is offline   Reply With Quote
Old 10-01-2016, 06:57 PM   #2
[/URL]https://youtu.be/OQ_OcpODGP4[/URL]
Old 10-01-2016, 06:58 PM   #3
Old 10-01-2016, 07:08 PM   #4
its hard to hear it in the video ill try and make another soon
Old 10-01-2016, 08:24 PM   #5
Hawkstang's Avatar
Region: Iowa
Look under at your rear diff and see if there is oil all over it. They are known to leak, mine is right now lol
Sent from my SM-G930V using Mustang Evolution mobile app
Hawkstang is offline   Reply With Quote
Old 10-01-2016, 09:22 PM   #6
There is? Does that have something to do with it? It sounds like its from the front of the car though? I bought an Eaton and had it put in about a year and a half ago
How would you fix it?
Are you having the same noise issue?
Old 10-01-2016, 09:40 PM   #7
Hawkstang's Avatar
Region: Iowa
If its from the front then no. But if your diff fluid is low you can here noise from the back on turns sometimes. But yes they do tend to leak so doesnt hurt to look.
Old 10-02-2016, 11:07 AM   #8
ak_stang's Avatar
Region: Alaska
I have a similar sound I believe (hard to hear in video), it will pop when I pass through turning the W eel streight, I think it's the upper strut mount bearing
Sent from my LG-AS811 using Mustang Evolution mobile app
ak_stang is offline   Reply With Quote
Old 10-02-2016, 11:47 AM   #9
Hellish Horse's Avatar
Probably Ball Joints. That usually causes a popping noise.
Hellish Horse is offline   Reply With Quote
Old 10-02-2016, 04:00 PM   #10
I do have fluid leaking from the differential as well but the noise is from the front it very well could be the ball bearings I read in another thread to lube it with spray silicone lube but that didn't help
Old 10-02-2016, 04:39 PM   #11
Hawkstang's Avatar
Region: Iowa
See the thread on the leak fix. Its cheap and very easy
Creak noise when turning the wheel sebasflorez Pre-2005 V6 Mustang 19 11-21-2013 01:20 PM
cranking noise when turning left or right Joey8 2011-2014 Mustang GT 25 08-23-2013 12:34 PM
Noise when turning off ignition manicrodder 1996-2004 Mustang GT 9 12-16-2012 06:59 PM
Weird noise when turning 03fastblack 1996-2004 Mustang GT 8 11-08-2012 10:52 AM
turning noise...? soccerfreak2143 2005-2010 V6 Mustang 20 06-30-2011 10:06 AM
02:52 AM
