Missing/Removed Front Heat Shields - Mustang Evolution
Old 10-02-2016, 12:12 AM   #1
I had the SR Performance Sway Bar Kit (front & rear) purchased from AM installed by a local automobile service shop to my 2013 V6 coupe. Months later I started to hear louder compression and popping noise from the front end. I took it to a local Ford dealership since the vehicle is still under the 3 year/36K factory warranty. they informed me the front control arm boots had dried out significantly due to the fact the associated heat shields were missing. I want to know if the heat shields need to be removed to install the SR Performance Sway Bar Kit and can then be reinstalled? Thanks for your time and reply.
rgwest61 is offline   Reply With Quote
Old 10-02-2016, 07:03 AM   #2
Strange Mud's Avatar
idk, but I wonder if yours ever had them.
"every one of you was going 50"
Old 10-02-2016, 07:14 AM   #3
wmschoonover's Avatar
I just installed a SR Performance set a couple weeks ago.
Nothing has to be changed to change the front. So if something required removing, then my car didn't have it.
wmschoonover is online now   Reply With Quote
Old 10-02-2016, 07:54 AM   #4
It's very possible your car was built before the heat shields became standard. There's been about 50 different versions of the front control arms in this car and none of them have solved the bushing issue.
2013 SGM 3.7 | MPT Tune | JBA Titanium Ceramic Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | BBK TB | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 10-02-2016, 10:19 PM   #5
Interesting, I will talk with the local Ford dealership service rep to see if he can tell from my vehicle vin # whether or not it ever had heat shields. I am having to pay $35.00 each side to install new heat shields. If my vehicle never had them I do feel I should have to pay for such. Thanks for your reply.
Old 10-02-2016, 10:33 PM   #6
tym_v6's Avatar
Only the Rev. D front LCAs have tabs with tapped holes to bolt heat shields over the hydro bushings. I'm not sure the heat shields actually prevent bushing failure, but I seem to see less complaints online with the Rev. D LCAs than not, so maybe the shields help.
More here.
Ford Racing GT500 Brake Cooling Shields NewMtang 2011-2014 V6 Mustang 0 07-26-2013 06:01 PM
Any opinions on clear coating shields? Mustang lulu 2011-2014 V6 Mustang 1 06-19-2013 08:32 PM
front o2 sensors removed robertoortiz85 1996-2004 Mustang GT 3 04-08-2012 09:20 PM
Removed my A/C Ibanezplayer272 Pictures and Videos 6 02-02-2006 10:12 AM
03:53 PM
