V6 cats welded on? - Mustang Evolution
Old 10-04-2016, 08:38 PM   #1
V6 cats welded on?
If I recall correctly v8 mustangs cats are bolted on while the v6 is welded on is there a reason for the difference. Also correct me if I'm wrong but I'm pretty sure the v8 version is bolted on.
rubyredv6 is offline   Reply With Quote
Old 10-04-2016, 09:03 PM   #2
Voltwings's Avatar
My personal guess is the factory backed racing efforts don't have to have a custom piece made, they can just unbolt the factory cats, whereas there is no v6 factory backed effort.
The new GT has welded cats as well, but the GT350 is the new factory backed effort (as opposed to the Boss 302 of the S197 platform) and has a mid pipe that can be unbolted for easy installation for an O/R mid pipe. That is my guess at least.
Old 10-04-2016, 10:41 PM   #3
Interesting. I would think welding would be more expensive for a manufacturing line to produce but I guess it would be more durable than clamps. I wish they had made them clamp on for the v6 it would be so much easier to go catless and to go back from catless to catted when doing emissions tests (doesn't really concern me but still)
Old 10-05-2016, 07:43 AM   #4
Voltwings's Avatar
Welding is dirt cheap, especially because the ease of automation. For a bolt on affair, there's what, 10 bolts bolts, 10 nuts, and 2 flanges that have to be taken into account (cost of parts), and then the machinery for installing bolts and torquing them is more complex than just running a seam weld around a butt joint.
Old 10-05-2016, 12:55 PM   #5
SolarFlarin's Avatar
Region: Rhode Island
I agree that sucks, but if you really wanted to you could have a local garage or exhaust specialist fabricate you a flanges to swap back and forth. Is it worth it? Depends but it is possible and I wouldn't think it cost that much.. I never knew that so thanks for bringing it up.. Good Luck
SolarFlarin is offline   Reply With Quote
slp welded in sean03gt 1996-2004 Mustang GT 13 05-23-2013 09:32 PM
bars welded under the car? dray492 1979-1995 Mustang GT 10 06-20-2012 11:14 PM
Welded doors Nathan69 2005-2010 Mustang GT 31 02-20-2011 01:18 PM
Welded Rear End (offroad forum) Scut95 The Bar 12 02-27-2009 06:35 PM
99 V6 going to have cats cut and pipe welded back in place with 40 series flowmaster? bpmadsx Pre-2005 V6 Mustang 18 05-17-2004 01:26 AM
12:47 AM
