Fuse 47 - Mustang Evolution
Old 10-05-2016, 07:07 PM   #1
Odai1437's Avatar
Fuse 47
Hey guys i accidentally dropped fuse 47 and i cant find it? Can i drive the car with it being removed?
Instagram: Odaii_7
Odai1437 is offline   Reply With Quote
Old 10-05-2016, 07:50 PM   #2
iguanaman3's Avatar
I would not drive without it. I forgot to replace it once and the engine stuttered and misfired. There is a spare fuse in the fuse panel in the side of the passenger seat footwell though.
iguanaman3 is offline   Reply With Quote
Old 10-05-2016, 07:55 PM   #3
oxfordwhite's Avatar
I tried the fuse 47 trick just lately. Didn't notice any difference. Does the key have to be on when you do this? Car running or not running with key on?
oxfordwhite is offline   Reply With Quote
Old 10-05-2016, 08:52 PM   #4
iguanaman3's Avatar
It only works with automatics since the fuse pull resets the memory for the "learned" shift behavior which causes the tranny to upshift too soon and slows throttle initiated downshifting. I have not done it since I got the Bama V2 tune, I think they found a way around the "feature". I can still conrol my shifts pretty well with the throttle pedal. Oh and it doesn't matter about the key, you are cutting power to the memory module and wiping it..
Old 10-05-2016, 09:26 PM   #5
Thank you Sir.
Fuse/fuse box Iamiguel 2005-2010 V6 Mustang 1 06-15-2012 06:16 PM
FUSE SET UP Debras96stang Pre-2005 V6 Mustang 27 06-04-2006 12:17 PM
Trunk light fuse??????? Murph00 Pre-2005 V6 Mustang 10 06-12-2005 01:35 PM
change the fuse box cigarette lighter to turn off mexor The Bar 9 01-25-2004 04:10 PM
Fuse problems. Brent Pre-2005 V6 Mustang 6 08-22-2003 02:24 PM
08:06 PM
