Suspension suggestions - Mustang Evolution
Old 01-04-2017, 04:00 PM   #1
wmschoonover's Avatar
I have a 2014 3.7L and I have it lowered with an Air Lift Performance V2 digital system. Other than that, I have installed a SR Performance sway bar kit (Front Adjustable at center adjustment)
Since I drive lowered, I was curious what if any other suspension modifications I should do for best performance and ride quality.
This is my ride height at 26 1/2 inches from ground to center of wheel well.
Name:	ImageUploadedByMustang Evolution1483570629.144856.jpg
I'm on 255/35R20's all around.
I have adjusted my dampers to a fairly good ride, I'm just curious if I could get even better results.
wmschoonover is offline   Reply With Quote
Old 01-04-2017, 05:31 PM   #2
Voltwings's Avatar
That entire statement is contradictory.
You're on 20" rims
Narrow tires
Knock off sway bars
air ride suspension
WAY too low of a ride height
None of that = good handling.
Old 01-04-2017, 06:12 PM   #3
FastFord13's Avatar
Ouch......
Sent from my LG-H812 using Mustang Evolution mobile app
Old 01-04-2017, 06:27 PM   #4
You're on 20" rims
Narrow tires
Knock off sway bars
air ride suspension
Actually handling is very good. Corners like a dream and for all practical sense it is very smooth.
Yeah sway bars aren't high dollar, but sway bars are basically thick metal bars so brand shouldn't effect anything except for the bushings.
I asked about ride QUALITY not handling. Like I said. Handling isn't an issue.
Just curious if upper and/or lower control arms etc would effect my ride or if I should just leave it alone.
Old 01-04-2017, 06:28 PM   #5
Voltwings's Avatar
Attachment 214082
Originally Posted by FastFord13 View Post
Ouch......
He asked, i answered
Old 01-04-2017, 06:31 PM   #6
Voltwings's Avatar
1. Actually handling is very good. Corners like a dream and for all practical sense it is very smooth.
2. Yeah sway bars aren't high dollar, but sway bars are basically thick metal bars so brand shouldn't effect anything except for the bushings.
3. I asked about ride QUALITY not handling. Like I said. Handling isn't an issue.
4. Just curious if upper and/or lower control arms etc would effect my ride or if I should just leave it alone.
1. Ok.
2. Not true.
3. Pretty sure you did. Unless i misunderstand what "best performance" is referring to.
4. No.
Old 01-04-2017, 06:39 PM   #7
Well since I replaced the stock sway bars with thicker/adjustable sway bars, then it should be an improvement if even just a small one.
Trust me, last SR Performance part I'll ever purchase after the trouble I got from their crappy shifter (replaced that junk with MGW)
As for wheels/tires... have no desire to run a 9/10 staggered set due to this being my daily driver.
Old 01-06-2017, 07:17 AM   #8
Mugeismo's Avatar
I agree with Volt.
That being said, I would recommend you take a look at the handling packages by BMR. Most of their packages are for the 05-10 Mustangs, but you can still find the equivalent 11-14 parts. That should give you a reasonable idea of what else you could add.
2016 Nissan Rogue - daily driver
1995 Ford Mustang GTS - cruise project
Mugeismo is offline   Reply With Quote
Old 01-08-2017, 01:48 AM   #9
Harm_3.7's Avatar
I'm on bags too but I'm gonna be honest the lower you ride the worse the ride quality. I've had springs, coilovers, and bags but by far the bags have been the best ride quality out of those 3. I'm riding lower than when I was slammed on my coilovers but the ride quality is way better. Airlift suggests to ride at around 45 psi on all four corners to get the best ride quality. Maybe try raising up your ride height to get better ride quality.
IG: justaslow3.7
Harm_3.7 is offline   Reply With Quote
Old 01-08-2017, 12:16 PM   #10
I've adjusted height and honestly there is little difference between my 26 1/2" height and when I raised it the other day for some snow that came in. Don't know the height I'm at but it does make it easier to go over the two speed bumps I have to drive over (work) since I don't have to slow down as much.
Like I said before, my ride quality is very good especially for being lowered but I have adjusted my dampers multiple times to get it here.
Harm_3.7, do you have any other suspension parts installed? Since we both have a similar year, engine, and air lift, that would be a good determining factor in what I might or might. It want to do.
Old 01-08-2017, 12:48 PM   #11
Harm_3.7's Avatar
I'm running a BMR upper control arm with the mount, BMR lower control arms, BMR control arm brackets, pan hard bar, and sway bars. The reason I did the upper and lower control arms was to get my 1/4th track times down not really for ride quality.
IG: justaslow3.7
Old 01-08-2017, 02:19 PM   #12
IG: justaslow3.7
Thanks. That is the information I was needing. Might do upper and lower to prevent wheel hop on launches.
Old 01-08-2017, 02:43 PM   #13
Harm_3.7's Avatar
Only reason I did the upper was I upgraded to a one piece driveshaft and wanted to adjust the pinion angle. If you do lower control arms and the control arm brackets you should be good on wheel hop.
IG: justaslow3.7
Old 01-08-2017, 03:08 PM   #14
IG: justaslow3.7
Thanx.
Suspension upgrade suggestions liv4spd 2011-2014 V6 Mustang 33 07-24-2015 07:35 PM
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
Suggestions? jleber123 General Car Discussion 33 11-13-2012 07:23 AM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Rear suspension suggestions MustangMatt Pre-2005 V6 Mustang 15 12-20-2004 03:05 PM
09:48 AM
