What's causing this? - Mustang Evolution
Old 04-06-2017, 11:31 AM   #1
Hawkstang's Avatar
Region: Iowa
It doesn't look good.
Sent from my SM-G930V using Mustang Evolution mobile app
Hawkstang is offline   Reply With Quote
Old 04-06-2017, 11:41 AM   #2
iguanaman3's Avatar
It looks like your wheel is rubbing the shock. What else could it be?
iguanaman3 is offline   Reply With Quote
Old 04-06-2017, 11:44 AM   #3
Hawkstang's Avatar
Region: Iowa
The scrape goes up and down, like its scraping on the upper shock?
Old 04-06-2017, 11:45 AM   #4
Voltwings's Avatar
^^ This.
Old 04-06-2017, 11:45 AM   #5
Siber Express's Avatar
The top of the shock is rubbing the bottom, my Koni's and the stock shocks on my 2010 both did it. I myself didn't worry about it since it is a piece of plastic on metal.
Old 04-06-2017, 11:50 AM   #6
Voltwings's Avatar
For clarification, ^This is what i was originally referring to, but i got ninjad.
The upper cover is just like a plastic dust cover? I cant see it causing that kind of wear without having some obvious wear itself? However, from the camera angle, it does appear that the wear would be somewhere parallel with the rotor and in an area the wheel couldnt touch it?
Old 04-06-2017, 12:05 PM   #7
Hawkstang's Avatar
Region: Iowa
Ok thats what I was thinking. My only concern would be rust probably?
Do you think my new lower control arms are causing this?
Old 04-06-2017, 12:18 PM   #8
I don't think so, mine did it with the stock stuff in it. My 13 did it also just not as bad.
Old 04-06-2017, 12:21 PM   #9
Hawkstang's Avatar
Region: Iowa
Good to know, thanks. Ill keep an eye on it going forward.
What could be causing this? asvpedwin Mustang 101 - Tech Basics | Ask an Expert 1 06-21-2016 06:01 PM
Abs causing car to bog? keeney35 1996-2004 Mustang GT 23 01-02-2016 12:02 PM
valve seal causing smoke Luke02GTmustang General Mustang Discussion 2 10-10-2013 02:34 PM
Intake causing drag? NicholasP 2011-2014 V6 Mustang 20 05-31-2013 10:46 AM
coils or plugs causing misfire? 1quick4.6 1996-2004 Mustang GT 9 03-07-2012 10:52 PM
06:45 AM
