Mustang 2012 loses power - dealer couldn't fix - Mustang Evolution
Old 09-22-2017, 11:57 AM   #1
Hello guys.
I have a huge problem.
I have a Ford Mustang 2012 V6 automatic.
After a car wash 5 weeks ago, I suddenly lost power during driving. Eventhough
I pressed on the gas pedal, the car didn't go any faster, but the RPM increased.
After a restart, it ran fine again for 4 days. Then the whole problems started.
Since then, I had the problem everyday. Sometimes it happens after driving 20 minutes,
somtimes it happens right away after driving out of my garage. I am not sure if the
car wash had anything to do with it or if it was the very hot weather that day that
triggered it the first time.
The first time the problem occured, the limp home mode light showed up. But this was
only once. After the restart, it was gone forever. I remember that the speedometer
needle sometimes bounced around when the problem occured or that it stayed at zero
even when I was driving. Also, one time when I tried to turn off the AC, it took 5
seconds before it reacted.
If the problem occurs in "drive" and I move into "reverse", the car doesn't move a bit
and only the RPM increases. After a restart, the "reverse" works. At least so much that
I can drive a few meters in reverse mode. So everytime the problem shows up and I try
to drive reverse, I have to restart the car before the swap from D to R works.
Anyways. I just got the car back from my dealer. The error codes showed that the
molded lead frame had to be replaced. It was done. I waited 2 weeks and thought
that the car finally works again.
But when I was drving home, the problem came again. I restarted, and I made it back
home without it showing up again. It seems that the molded lead frame swap didn't do
anything.
I cleaned the MAF-sensor and the Throttle Body. Nothing changed. I think I may have
****ed something up when I washed my car. I washed it from the front and I think that
water may have went into the engine. Maybe ignition plugs got wet?
My dealer said there is nothing he can really do. He also said that ignition etc. could
not be the reason as there would be lights on and so on. But I do not think that.
I hope someone here can help me out.
Ragnar92 is offline   Reply With Quote
Old 09-22-2017, 12:13 PM   #2
I also hope someone can chime in and help. Your dealer sounds more like they WONT help you. I bet there's something they could do to help you but they WONT. that's pretty messed up.
Old 09-22-2017, 12:15 PM   #3
Thank you silverskoundrel. I feel very screwed over to be honest. It cost me around 850 dollar to replace the molded lead frame. I am lost right now without a working car given that I am self employed and need to be mobile at all times...
Old 09-22-2017, 12:52 PM   #4
It certainly sounds like a lot of crazy things are going out at the same time. To me, I'm reminded of guys who opened the hood and washed the engine down, getting water all over the place and inside some critical items such as the distributor. When that many dumb things are happening I'm lead to believe that water got into some computer elements some how. Can't really help you but maybe a battery disconnect and reset might just do the trick. And don't wash your engine compartment with power washers. Delicately hand wash your baby's most important areas.
MustangPat is offline   Reply With Quote
Old 09-22-2017, 12:53 PM   #5
idk what molded lead frame is lol
Old 09-22-2017, 12:58 PM   #6
The molded lead frame is a part of the automatic transmission. There is a temperature sensor that for the transmission oil and some other stuff in it.
I disconnected the battery 2 weeks ago for 30 minutes. It didn't fix it.
I guess I should not have used a power washer to clean the car from
the front. Probably got wet in the hood...
You are right. I have learned my lession.
Old 09-22-2017, 05:14 PM   #7
Following codes have been shown up:
P01288
P01703
P1780
The last code had something to do with the transmission problem that they have fixed.
The first code is a problem with the cylinder head temp sensor.
I have told my dealer that the problem seems to occur more often
when it is hot outside. But he ignored that. Could it be the reason
it loses power and goes into limp mode?
Where is it located in a Mustang 2012?
Old 09-23-2017, 12:52 PM   #8
Beviking's Avatar
I would try another dealer or shop. Let them know your concern with water under the hood and see if they find anything.
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
Old 09-23-2017, 02:18 PM   #9
I think your car needs to be reprogrammed.
I would think any dealer would do that first before replacing parts that probably don't need replacing.
What your describing sounds like a computer hiccup to me.
Old 09-23-2017, 04:33 PM   #10
Voltwings's Avatar
If the engine is revving and the car is not moving, it sounds like power is not getting transmitted... i wouldn't know how to go about testing a torque converter, but that's the link between the engine and transmission, so i'd start there.
Old 09-23-2017, 06:43 PM   #11
The transmission is computer controlled and they do have some sort of recall on some of them, I heard it was just programming.
I have a 2012 V6 Automatic and my dealer reprogrammed my computer when I was in for the airbag recall.
I never had the problem and don't think I will.
PS:
I did recieve a letter from FORD that warned about the output speed sensor.
Satisfaction # 16N02
I will try to copy this and post it on this post later or in the morning.
It is a programming "FIX"
Old 09-23-2017, 09:22 PM   #12
I found the letter from FORD about the transmission
Here it is:
Name:	for forum.jpg
Old 09-24-2017, 12:35 AM   #13
P01288
P01703
P1780
Yes. The cylinder head temperature sensor will cause the engine to go into limp mode if it fails.
They are typically located on the front of the passenger side cylinder head on Ford engines... But I'm not sure on the 3.7 engines.
Perhaps one of the members who actually owns a V6 will chime in as to the location of the CHT sensor.
Old 09-24-2017, 09:03 AM   #14
Beviking's Avatar
Yeah, if they can take the time and stop looking for ways to upgrade to a V8! Haha, had to drop that one.
Old 09-24-2017, 10:24 PM   #15
NewMtang's Avatar
It sounds like this is an intermittent problem and the dealer is having a problem diagnosing it. You may have to take it back to the dealership several times to get it fixed.
Good Luck! Sorry if this wasn't more helpful.
Old 10-10-2017, 12:46 AM   #16
Junior Member
Hello guys.
anything.
My 2012 v6 went into limp mode several times over the course of a couple of months. I read somewhere that there is a throttle body recall for some models. Mine didn't happen to be one of them. I replaced my throttle body with the larger BBK unit about 6 months ago and haven't had the problem since.
mustang37 is offline   Reply With Quote
Old 10-10-2017, 06:12 AM   #17
David Young's Avatar
Customer Satisfaction Program 16B23. I was on the list and had mine replaced. I wasn't having any problems . I have 'read' some people that bought the BBK throttle body to replace their factory throttle body have been paid the cost from Ford for the BBK throttle body. 'If' their VIN is on the 'list'
David Young is offline   Reply With Quote
suspension still popping after dealer fix grabber12 2011-2014 Mustang GT 10 08-05-2014 10:24 PM
Dealer tried to fix paint chips ThatsCoolBro Mustang Paint, Appearance & Detailing 10 07-01-2014 05:29 PM
03 gt feels like it loses power? Calebnc302 1996-2004 Mustang GT 9 06-21-2013 10:28 PM
86 mustang gt 5 speed loses power at high RPMs lilrafe87 1979-1995 Mustang GT 16 03-28-2012 04:38 PM
Radio/cassette loses power mightymav72 Pre-2005 V6 Mustang 4 03-17-2011 05:40 PM
03:29 AM
