2012 Mustang V6 6speed--intermittant cranking issue....HELP! - Mustang Evolution
Old 10-08-2017, 10:38 PM   #1
ridinrightauto's Avatar
Region: Arkansas
ok, so I financed a 2012 Mustang V6 6speed 2 months ago. i have had the car in my possession for a total of about 12 days of the 2 months. it keeps on doing a weird crsnking issue.....sometimes (randomly) i will get in the car and go to start it.....(e brake up, foot on brake pedal, foot on clutch, turn key to on, gauges sweep, turn key to start for a second) car cranks and cranks and cranks....if i leave key in the on position it would crank till the battery died......BY ITSELF.....one time i was driving down the freeway and the car just lost power and stalled out. acted like it lost fuel pressure. then no start again. ive taken it back to the dealership 5 or 6 times.....they think im crazy.....so i finally thought to get a good video of it when it messed up yesterday, called tghe dealership, they sent a tow truck to pick it up and said to bring the video in and let them see......i showed the general manager and he asks me ....why are you not turning the key all the way? im like R U FREAKING KIDDING ME???? u can CLEARLY see my hand turning the key to START until the engine starts cranking....and when i release the key it keeps cranking and cranking and cranking........if i let the car sit (different time periods ranging from 1 minute to overnight or 2 days then it will start up just fine........HELP!! I sure dont want to get stuck with a lemon........Thanks in advance
ridinrightauto is offline   Reply With Quote
Old 10-08-2017, 11:14 PM   #2
Region: Arkansas
forgot to mention that no check engine light, theft light isnt lit up either
Old 10-08-2017, 11:55 PM   #3
Revvv's Avatar
Give that car back to the dealer. You just found out why the previous owner traded it in.
Old 10-09-2017, 05:40 AM   #4
Strange Mud's Avatar
+1 on taking it back to who sold it to you (hopefully there is a wtty). There is a system where once the starter engages it will crank for 10 secs (or start up) and I know that 10 secs seems like forever. Next time count to see if it is over 10 seconds or not. If it is 10 sec then it is just a starting problem....longer than 10 my guess would be a computer problem. Good luck as intermittent issues are tough to diagnose.
Old 10-09-2017, 06:33 AM   #5
jkeaton's Avatar
This.....good luck!
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 10-09-2017, 07:20 AM   #6
jayochs's Avatar
can you return a car after you buy it? everyone's saying return it but i didn't know dealerships allowed that
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 10-09-2017, 08:00 AM   #7
no you can't (realistically)...you MAY be able to get them to fix it.
Old 10-09-2017, 08:58 AM   #8
Revvv's Avatar
It depends on the dealership. A reputable one will take the car back, or do everything in their power to repair it.
Old 10-09-2017, 09:35 AM   #9
jkeaton's Avatar
All depends on the dealer. You should have got, at a minimum, a 30 day warranty, even if you did not buy an extended one. Again, depends on the dealer. If you bought it from Mammy's Used Car Lot on the corner, then probably not.
07 V6 Coupe
Old 10-09-2017, 09:39 AM   #10
Revvv's Avatar
If I ever open a car lot I know what I am going to call it.
Old 10-09-2017, 01:02 PM   #11
RBK
I would ask the dealer to check two things to start out with, are you getting a spark at the plug and do you have fuel pressure on your fuel rail; both while cranking it. One has to be missing or the car would start. With computers controlling everything who the heck knows what the problem could be. Possibly a crank position sensor. Way back when cars use to have a separate starting circuit when you turned the key to start and cranked it. Sometimes the cars would start when holding the key in the crank position and die when you let loose of the key and it returned to the run position, if there is anything like this today perhaps you have a bad ignition switch. I would start with having them replace the crankshaft position sensor; this may be one of those problems that you may just have to start swapping out parts until you hit the correct one.
RBK is offline   Reply With Quote
Old 10-09-2017, 11:18 PM   #12
Region: Arkansas
Called dealer today.....the man said that they drove the car twice today, nothing wrong with it
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 10-10-2017, 07:06 AM   #13
jkeaton's Avatar
You need to be able to ride with them and duplicate the problem. If you can't duplicate the issue, then they really can't do anything.
07 V6 Coupe
Old 10-10-2017, 01:25 PM   #14
Region: Arkansas
Yes I know but it is so Random like when I bought the car I had it for 7 days before it messed up the first time and then it has been in and out of the shop at the dealership and I got it back and it was another 9 days before it did it again. But the first time it happened I was going down the freeway in traffic with no shoulder due to construction and the car just died. Not safe
Old 10-15-2017, 01:21 PM   #15
Junior Member
Yeah give it back to them even if fix that problem you'll have other stuff go wrong seeing that its an electric problem
zacharyevans43 is offline   Reply With Quote
Old 10-15-2017, 03:00 PM   #16
RBK
If the local dealer still hasn't fixed it I believe that Ford has a zone, or district, service manager. You need to escalate the problem to him for help. I believe Ford HQ even has people that you could probably go to. Once they track it down and fix it, I'm sure the car will be fine. I have a 2012 V6 and have never had a problem with it, other than a couple of rattles; engine and electrical have never been a problem.
2012 mustang
Transmission 6speed MT82 QUESTION Victoryrc 2011-2014 Mustang GT 43 04-13-2017 09:24 PM
Starter issue with 2012 V6 caveeagle 2011-2014 V6 Mustang 2 03-24-2017 07:35 PM
2011 Mustang GT 5.0 6speed "Blacksunshine" :: 2011 Ford GT xSTRIKERx Member Garages 0 05-06-2012 10:02 AM
Issues cranking 2012 v6 krgorham 2011-2014 V6 Mustang 10 10-30-2011 03:27 PM
6speed stick in a v6 Ninethourpm Pre-2005 V6 Mustang 29 06-28-2009 09:55 AM
02:26 PM
