MT82 Clutch Spring Delete walkthrough - Mustang Evolution
Old 11-12-2017, 12:27 PM   #1
3SevenStangVids's Avatar
Did a quick video explaining how to remove the clutch assist spring with ease. Did this on my last 3.7 and had no issues from it being removed. Was left with a much more precise feel in the clutch, leaving you feeling more connected with the car when going through the gears and taking off. Some people have had play at the top of their clutch after doing so and some haven't. I haven't experienced this in either 3.7 i have done it on but I've seen a video of someone who has. If this is a problem, you can look into an aftermarket spring available from Steeda which will still give a better feel over stock.
2012 3.7L MCA 13.09 @ 106.66 MT82 MPT93 BBK LTH ORX ATAK 73MMTB LONEWOLF INTAKES BBK CAI FRPP 3.73 AE 1PC DS J&M LCA'S STS+2POST CLUTCH SPRING DELETE STRANGE 10WAY SHOCKS SOLD
2014 5.0 MUSTANG - 12.1 @ 116.5 6R80 3.15'S MPT93 LETHAL ORX CUSTOM 3" OTA VIKING SHOCKS UCA LCA
2012 3.7L BASE -MPT93 STEEDA CAI BORLA STYPES
3SevenStangVids is offline   Reply With Quote
Old 11-12-2017, 03:05 PM   #2
jayochs's Avatar
i swapped mine with that steeda one....what a waste of effort, time and money. absolutely no difference. apparently our springs are different from the heavy GT springs, so the steeda one made no difference...steeda knows this, but advertises incorrectly.
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 11-14-2017, 11:29 AM   #3
Removed the spring from mine a while back but noticed after sitting overnight the pedal would sink about half an inch so I ended up putting it back in.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 11-14-2017, 12:12 PM   #4
Voltwings's Avatar
The pedal does have about 1/2" of slack, but it's not engaging the pressure plate at that point, it literally is just slack in the pedal.
Old 11-14-2017, 06:37 PM   #5
Yea, but this wasnt lift up 1/2" and fall back down like slack would be. When you'd pull it up it in the am, it would stay up.
Old 11-15-2017, 06:12 AM   #6
Voltwings's Avatar
Hmm, that is interesting, because ours literally is just like a little slack / dead area.
Old 11-15-2017, 11:17 AM   #7
Beviking's Avatar
Nice! Replaced mine (GT) with the Steeda spring. Drove a few days w/o the spring and loved it! Very good feel of engagement and little slack at the top. Got the Steeda spring and installed it. It?s better than stock for the GT, but not as good of a feel as no spring. Just feel like something will wear out faster if I run no spring. More experienced guys say it won?t, Im just chicken! Lol
'12GT Premium, Roush TVS & BAP, VMP Elbow, 82mm, JLT CAI & Catch Can, Eiback Sports, Steeda Cambers & Adj UCA, Adj panhard & Brace, LCAs+Relos, Diff Bushing, Ford Diff Cover, Axle Catch Can, 3.73, Shaftmasters DS, MGW, BG Syncro II, Blowfish Shifter Support Bracket, Trans Mount Insert, MBRP 3" H pipe, Borla 3" Touring Pipes/Axlebacks, High Flow GT Grill Insert, Steeda Spyder Wheels (20X9.5/11), 275 fronts, 315 rears, Lakewood drag shocks, Cervini Hood, big smile
Beviking is offline   Reply With Quote
Old 11-15-2017, 01:24 PM   #8
Voltwings's Avatar
It wont, it's only there to reduce pedal effort. That being said, it's 100% personal preference, there is no right or wrong.
Old 11-17-2017, 08:12 PM   #9
Beviking's Avatar
Well then, anyone need a Steeda spring? I?m taking it out.
Going to neutral w/o engaging clutch MT82 ActorMike 2011-2014 V6 Mustang 37 04-04-2017 04:27 PM
MT82 Clutch Power Limit tgmeyer 2011-2014 Mustang GT 8 02-21-2017 03:47 PM
Is my clutch not releasing enough or is my mt82 going bad? Josh_101 2011-2014 V6 Mustang 27 09-07-2015 08:19 PM
Solved all the MT82 problems with new Clutch Kit mustangcito 2011-2014 Mustang GT 11 10-25-2014 02:30 AM
Spongy clutch after removing clutch assist spring. Fax22 2011-2014 Mustang GT 2 09-06-2014 10:19 PM
08:48 AM
