Take off lag - Mustang Evolution
Old 11-17-2017, 11:12 PM   #1
Junior Member
Take off lag
When ever I take off from a dead stop and I have a significant amount of throttle my car lags, then goes really hard. Which is annoying because then my foot bounces on the throttle causing me to accelerate and decelerate.
I think it may be due to the bama tune I’m using. However I can’t go back to stock permanently because I have shorter gears in the rear end. Do any of your automatic S197s do this?
austinh1999 is offline   Reply With Quote
Old 11-18-2017, 06:32 AM   #2
David Young's Avatar
From a dead stop when 'normal' driving?
From a dead stop when 'flooring' the gas pedal?
David Young is offline   Reply With Quote
Old 11-18-2017, 07:50 AM   #3
Do you happen to have AdvancedTrack turned off by any chance? Your traction control might still kick in if it detects any amount of spinning of the tires, it'll bog it a bit, then it'll just take off on you.
AtomGT is offline   Reply With Quote
Old 11-18-2017, 08:23 AM   #4
Junior Member
Yea I do have it on. I’ll try running with it off for the next couple of days.
Old 11-18-2017, 08:59 AM   #5
jayochs's Avatar
is it the hesitation like when you shift into 2nd and between like 2500 and 3500 it lags, and then when you hit over that, all of a sudden there's normal power again?
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 11-18-2017, 09:57 AM   #6
Sounds awesome man! Let us know how it goes, be sure to have the brake pedal engaged while holding the traction control button for about 10 seconds or so. You'll see it turn off in your dash. From there you should be good to go!
Old 11-18-2017, 10:02 AM   #7
Junior Member
I learned to be more careful with the pedal because of it to cause it not to happen. Usually it’s when I give it more throttle than I need but far from flooring it.
Old 11-18-2017, 10:04 AM   #8
Junior Member
It seems to shift normally when cruising or already accelerating. Just take off it does it. But it does do something like that at take off.
Old 11-18-2017, 01:44 PM   #9
Must be your tune. My throttle is very sensitive and peppy but I am running a MPT tune
Power lag????? HELP _nathannnn 2011-2014 V6 Mustang 6 06-01-2014 08:47 PM
CAI LAG Alfienokes 2011-2014 V6 Mustang 26 07-04-2013 12:36 PM
Throttle lag Adamp1 2011-2014 V6 Mustang 8 03-05-2013 01:33 AM
Acceleration lag.. sixpac 1979-1995 Mustang GT 22 06-26-2012 08:27 AM
shift lag! NotoriousSPG Pre-2005 V6 Mustang 3 05-25-2007 08:01 AM
04:45 PM
