New Push Pins - Mustang Evolution
Old 11-19-2017, 06:56 PM   #1
New Push Pins
Pulled too close to the parking spot ground barrier and popped some of the push pins loose under the front bumber. I tried pushing them back in but they don't stay and the shield is still loose. The pins don't look damaged - should I buy a new set? In other words, are the pins made to be used just once? Obviously something needs to be replaced somewhere, and I hope it's not the shield.
cheval is offline   Reply With Quote
Old 11-19-2017, 07:26 PM   #2
iguanaman3's Avatar
Perhaps the holes got enlarged when they ripped out and you need a larger sized push pin.
iguanaman3 is offline   Reply With Quote
Old 11-20-2017, 06:39 AM   #3
jkeaton's Avatar
Yes, you should buy a new set. Preferably a larger size if the holes got enlarged somehow.
03 GT Convertible, 5-speed
07 V6 Coupe
jkeaton is offline   Reply With Quote
Old 11-20-2017, 07:33 AM   #4
What year I know my car a 14 got bumped into by another car and it messed that shield underneath up it is foam so it will give. More than likely as was said the holes in the foam got expanded and that?s why it?s falling I used a washer to get it to hold but ended up taking it off.
rubyredv6 is offline   Reply With Quote
Old 11-20-2017, 08:45 AM   #5
Strange Mud's Avatar
or goop a little rtv in the holes then put in pins wait till it dries. This will make removal harder but you only remove it when you hit stuff
Old 11-30-2017, 08:10 PM   #6
UPDATE: Thanks to those of you who responded. I finally took my Mustang to the very reliable body shop I have used in the past. They did an immediate check, and found that one of the holes in the bumper that receives the pin was indeed torn, so it couldn't hold the pin. They put a special screw through the shield and bumper holes, securing the two pieces. Their charge for the service? A handshake and a "Merry Christmas!"
Wire Pins Billy13 2005-2010 Mustang GT 0 11-08-2016 08:09 PM
eh...hood pins? Feedback 2011-2014 V6 Mustang 18 09-15-2013 09:22 AM
door pins Robbie94gt 1979-1995 Mustang GT 3 01-31-2012 06:01 PM
hood pins or no hood pins? + 87,89,93 octane gas andyr421 1996-2004 Mustang GT 14 11-19-2011 10:15 PM
hood pins or no hood pins...that is the question ballen666stang New Member Introductions & Greetings 10 11-18-2010 10:10 PM
02:33 PM
