Clunking/groaning over speed bumps - Mustang Evolution
Old 02-01-2018, 06:24 PM   #1
Hey guys so today I was driving over some speed bumps and I noticed a sort of clunking/groaning coming from the front right of the car. It kinda sounds like something loose. I was wondering what it could be. I have warranty as far as suspension goes so I will be taking it to the dealer. From what I have read it could be sway bar bushings or control arms. In either case is there an upgraded part I can ask my dealer to install if anything has to get replaced. I?m guessing they won?t swap out the whole control arm or sway bar but if they do can I ask for say Shelby or gt control arms or are they all the same from factory.
rubyredv6 is offline   Reply With Quote
Old 02-02-2018, 04:11 AM   #2
David Young's Avatar
I would be happy about the dealer fixing it for you. I have read, some dealers won't fix it for free. They won't go for upgraded parts and will only use the factory original equipment parts for your Mustang. Let us know how it goes .
David Young is offline   Reply With Quote
Old 02-02-2018, 05:44 AM   #3
Yeah I figured they will only want to install oem parts but I will still give it a try. I know I?m only under powertrain warranty from ford but I do have an aftermarket warranty which so far has been awesome with covering all other costs so I?m thinking they will cover whatever it is.
Old 02-02-2018, 07:17 PM   #4
I got under the car today and everything looks good. The car only has 38000 miles and everything looks pretty much new just dirty but new. I checked everything to see if anything was loose. Everything was tight nothing bent. No struts leaking. I did stop by the dealer and they said they would have to test drive it and make sure it did the same thing again but as I was pulling in I passed over speed bumps and it did not want to make the sound I guess I went to slow trying to replicate it. So I did not leave it with them thinking it would not do it. Then as i am pulling out it does again. But at this point they had told me they would not be able to get it to it until tommorow so I brought it home. At this point I am thinking its a strut mount.
Old 02-03-2018, 03:32 AM   #5
There are Threads on this Forum about 'clunking sounds' from the front. Something about the new up-dated part has a 'heat shield' where the old factory original part didn't. Strut mounts going bad are more of a 'popping' sound, but you never know
Old 02-04-2018, 05:51 AM   #6
Front lower control arms are known to squeak, there's a tsb about it and Ford has redesigned them a half dozen times but not sure any of them were a guaranteed fix. Definitely worth the trip to the dealer though if you've got a warranty that will cover it.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 02-06-2018, 09:55 AM   #7
ZombieSlayer's Avatar
Only time I have heard a similar noise was when a bushing needed greased, or in your case a strut/strut mount was bad. At 38,000 miles though it shouldn't be the case.
On my GT, the BMR vertical link I installed started groaning when going over bumps. It was because after 6-7 months, the bushing needed lubricated. I tested this by spraying WD40 on the bushings (both sides) and the noise has not come back after a couple of weeks of driving.
Another thing that comes to mind is if the Spring isn't sitting correctly on the strut/strut mount, it can cause noise.
Not sure if this is helpful but let us know if your issue turns out to be the same!
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
ZombieSlayer is offline   Reply With Quote
Old 02-06-2018, 03:46 PM   #8
ActorMike's Avatar
Heads up- The Instagram link in your profile does not work.
ActorMike is offline   Reply With Quote
Old 02-06-2018, 07:29 PM   #9
I have not heard the noise recently. Mostly because I have not gone over any speed bumps. I mean struts all look good no leaks. At the moment all dealers are super backed up in my area and regardless of that I am also busy. Only time I could go in is on a Saturday and I know how that will go. Car will stay at dealership until someone can test drive it then they will call me and say we did not hear anything if it gets worse come back. So for now I will leave it be until I have more time but I will definetly keep everyone posted when the solution is found.
Knock sound when hitting bumps at speed swhitfield2013 2011-2014 V6 Mustang 12 11-19-2016 06:14 AM
2016 V6: Clunking sounds when going over bumps on cold start. Red1991 Mustang 101 - Tech Basics | Ask an Expert 0 08-28-2016 10:52 AM
Groaning/Growl/Gurgle pjtavish 1996-2004 Mustang GT 14 10-17-2014 03:05 PM
Speed bumps Loraco The Bar 90 02-11-2011 06:04 AM
08:01 PM
