Noise or low-pitch squeaking sound over bumps - Mustang Evolution
Old 03-14-2018, 11:34 PM   #1
It was going on and off before, but now it's consistent.
From front-left side of my car, when i go over bumps or pot holes, it makes kind of low-pitch squeaking sound. I'm assuming strut on driver's side on the front. (I attached a vid with sound)
Before I even think about replacing any part myself, I wanted to confirm with pros out there.
I'm not a pro mechanic, but I'm trying to learn, and if i figure out about this, then I'm gonna try to replace any parts that is necessary to make this noise go away. It sounds like the wheel may pop out on highway someday.
Any tips will be appreciated.
ajtmxod is offline   Reply With Quote
Old 03-14-2018, 11:51 PM   #2
for those who already viewed my post, i give you my apology. My vid keeps getting an error as an attached file. I'm trying to fix it rn.
Old 03-14-2018, 11:55 PM   #3
the vid is up and running now!
Old 03-15-2018, 09:33 AM   #4
Your video still isn't working.
Old 03-15-2018, 10:39 AM   #5
Getting “format not supported” error message for your video. Best of luck getting it to work, but in the meantime, I don’t think it would cost you anything to take it by a mechanic and have them listen to it. They might even put it up on their rack for free to diagnose it.
Old 03-15-2018, 11:36 AM   #6
Video is now working for me. My guess is the sway bar bushings need lubrication. I would probably use silicone grease, but lots of people use Teflon tape.
DonBurke is offline   Reply With Quote
Old 03-15-2018, 09:26 PM   #7
Thanks for the tip. I can start from there since lubing sway bar bushing or even replacing it is a lot easier than replacing the whole shocks or strut. I'll let you updated once I take a close look at the sway bar bushing, so i can determine if its grease got washed away or damaged.
Old 03-21-2018, 07:36 PM   #8
About a month ago mine was doing the same thing but only over bigger speed bumps. I haven’t heard it since though (haven’t driven over speed bumps) so I’m interested in finding out what it is too. Honestly everything under my car looked brand new though so it might be tough to diagnose.
rubyredv6 is offline   Reply With Quote
Old 03-25-2018, 02:53 PM   #9
During past few days, I researched a bit, and found out there was TBS issued long time ago for this problem. I'm not 100% sure if the TBS i got was the most recent (or the final) TBS, but at least I know that it's not only me who's having the problem. I attached the TBS to this reply.
I'm thinking to replace the whole front lower control arms, and now i'm shopping around what would the cost for this job. Hopefully not too much. I'll let you guys updated.
P.S. I realized that the video that i uploaded was really short (like 2 or 3 seconds), so as soon as it gets played, the screen goes to the ad, but the audio is playing. If you click on play button, you can listen to the low pitch noise.
Old 03-26-2018, 05:11 AM   #10
Strange Mud's Avatar
didn't listen but front LCA's were my front squeek
TSB/Wtty
Old 03-26-2018, 07:14 AM   #11
So are these tsbs covered under warranty or would this be an out of pocket repair.
Also my car was built after the date the TSB was announced so would ford use the same part or would it come repair with the updated part from the factory.
Old 03-26-2018, 08:30 AM   #12
tsb out of wtty is doubtful but if you have a good relationship possible. Mine were replaced with a different revision and I put 30K on them with no issues (nice day toy)
Old 03-26-2018, 11:10 AM   #13
I’m not sure about the warranty. As far as I know, a recall is for anything related to safety, so it’s covered by manufacturer. A TBS is like something “annoying”, but not directly related to safety issue.
About this front squeak noise, some say that replacing only front LCA rear bushing resolves the noise issue. Some say the whole front LCA replacement.
Even if both methods resolve the problem, personally I’m leaning towards replacing the whole LCA. Since I’m jacking up my mustang and get down there, why not do some more and get upgraded. I know I’ll suffer from the budget, but I know that I’ll be smiling while I’m driving. That’s what matters to me. 🙂
Old 03-26-2018, 08:17 PM   #14
Ah ok. I have an aftermarket warranty that I know will pay for it if I take the car in and the dealer diagnoses it but I don't think its worth the hassle of having to leave my car at the dealership for a couple of days. I will probably just live with it myself as long as its not a safety concern and maybe change out bushings in the future. I hear the energy suspension bushings are pretty good though in case anyone is looking at just doing bushings.
Old 04-05-2018, 07:27 PM   #15
tym_v6's Avatar
TSB/Wtty
Hiya, Mud!
Same here. Could even *feel* the vibration through the floorboard sometimes.
IIRC, the latest variant of the front LCAs has heat shields to (allegedly) protect the hydro bushings from engine heat.
Knock sound when hitting bumps at speed swhitfield2013 2011-2014 V6 Mustang 12 11-19-2016 06:14 AM
Squeaking at low speeds! JR4288 2011-2014 V6 Mustang 12 11-02-2014 02:14 PM
high pitch sound winkawak 2011-2014 Mustang GT 0 01-18-2013 06:29 PM
Thump noise over bumps S197stanGT 2005-2010 Mustang GT 5 06-29-2012 12:02 PM
Car Squeaking Over Bumps/Hills/Rolling Roads Shahrum Pre-2005 V6 Mustang 12 03-03-2004 08:47 PM
11:21 PM
