Does anyone have or know the correct wiring for fuse 47 relay mod that uses a fuse socket connector in the fuse box (without cutting the blue green wire under the fuse box) or the old wiring diagrams from Jsimmons on the fuse 47 relay mod he did?
This is where I am stuck, the fuse socket connector has two wires running out to the relay but I don't know where those two wires connect to the relay or where the inline mini fuse comes into play (assuming after the 30-87 pins are joined)?
According to the information I have, 1 wire from the fuse socket connector goes to the combined wiring for pin 30 and 87 but does the other go to pin 86 for the trigger to turn on the relay or does it go to ground?
It's unclear how the inline fuse is wired in (on 86 or combined 30 and 87) and also if ground (pin 85) is grounded to the chassis or to one of the terminals on the fuse socket connector?
Thanks for any help you can provide, I have no problem wiring at all as I have the experience/tools/parts, just don't want to splice into the blue-green wire under the fuse box (original mod) and want to do the jsimmons mod. However, all of his diagrams/write-ups are gone now and its a bit confusing reading some of the old threads I found on how it was wired with the fuse socket connector instead of cutting the blue-green wire under the fuse box that powers fuse 47.
These are the diagrams I have but it doesn't show how the relay or fuse socket connector are wired.
