2011 GT dyno video and graphs from Edmunds - Mustang Evolution
Old 03-24-2010, 10:03 PM   #1
Loc: Austin,TX
Inside Line Dyno-Tests the 2011 Ford Mustang GT 5.0
Old 03-24-2010, 11:33 PM   #2
Re: 2011 GT dyno video and graphs from Edmunds
*creams panties*
19Delta is offline   Reply With Quote
Old 03-25-2010, 12:03 AM   #3
MonteCitan's Avatar
Do Want!
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-25-2010, 09:12 AM   #4
hmm I find it very hard to believe it put down 395 on a dynojet with out some out of place correction factor or the drive line is amazing in keeping the power robbing components at bay. The only other choice is its not making 412hp its making 465hp or there about (with a gracious 15% drive line loss)
Old 03-25-2010, 09:32 AM   #5
Loc: Austin,TX
I'm having a hard time accepting this also....
Old 03-25-2010, 12:31 PM   #6
since when does a mustang lose 10-11% in the drivetrain... more like 17 at best. hmmm that puts it at 465hp if 395rwhp is accurate
Old 03-25-2010, 04:58 PM   #7
SVTCOBRA's Avatar
I think we are back in the glory days.
SVTCOBRA is offline   Reply With Quote
Old 03-25-2010, 05:21 PM   #8
jimmy_beaner's Avatar
Region: Iowa
Driveline loss for a solid axle-equipped car like the Mustang is typically 11-13%. This is a bit less than the usual 15-18% you'd expect on an IRS car, as solid axles have fewer power-sapping U-joints in their driveline. Hence, we should expect to see about 358-367 rwhp from this car.
Clearly, the 395 rwhp figure we measured is of particular interest since it implies one of two things -- either Ford is being conservative with its 412-hp flywheel rating, or the preproduction example we tested is unusually healthy. We're leaning toward the former, but we won't know for sure until we test a production 2011 Mustang.
Old 03-25-2010, 08:45 PM   #9
Loc: Austin,TX
So can we expect this car to max out at the 550-60ish level then if the 395 # is right on? If so .......wowza! I will still believe it when I see it.
Old 03-26-2010, 12:16 AM   #10
Region: Iowa
with the high compression, and not much done to the internals... I'm sure you'd need to change some parts
Old 03-26-2010, 01:27 AM   #11
MonteCitan's Avatar
Think back to the LS1 camaro/firebird duo..
At the end of their production run because, aside from engine, the mustangs were far superior in every way and outsold them like whoah.. lol anyhow...
They were rated at a conservative HP # but MOST OF THEM put down exactly, or almost exactly their rated HP on the dyno.. stock..
I think this is the same sort of deal
Plus this was a pre-production car, could have a few tuning differences, different gear ratios here or there, etc...
Old 03-26-2010, 07:21 AM   #12
I thought there was new regulations on monitoring ratings thus the new z06 and gt500 are spot on power wise to what they should be.
Also 10%-11% in a solid axle.. yea I dont think so, more like 17%.
Old 03-26-2010, 02:22 PM   #13
SVTCOBRA's Avatar
You guys think this car would be outrageous to insure?
Old 03-26-2010, 02:29 PM   #14
no more than a 2010 i dont think
Old 03-26-2010, 02:53 PM   #15
Nah, it's a v8, and it'd probably cost around the same as the 2010 GT's would to insure. All depends on age, location, and driving record.
Old 03-26-2010, 10:20 PM   #16
stang1's Avatar
iT WOULD DEPEND ON AGE. i ONLY PAY ABOUT $1,000.00 FOR MY 2010.
2015 Mustang GT Premium
stang1 is offline   Reply With Quote
Old 03-28-2010, 12:15 PM   #17
Loc: Austin,TX
It will be the same as a normal GT,they won't go off of HP rating. Some insurance companies have Cobras in the "no no" category. But a lot of It will depend on age/driving record as stated above.
2011 gt
Evolutions 2011 GT dyno #'s DDTCM 2011-2014 Mustang GT 17 06-02-2010 09:34 AM
Shaundra's dyno video. DDTCM Pictures and Videos 2 02-10-2010 07:20 AM
Dyno video slvr2000stang Pictures and Videos 6 01-05-2007 06:08 AM
93 skyline GT-R dyno video... wow Zim The Bar 21 11-08-2005 01:23 PM
Please Submit Track Slips, and Dyno Graphs: Smokedya95stang Pre-2005 V6 Mustang 2 03-04-2004 08:40 PM
12:27 AM
