2010 v6 Mustang performance cams?? - Mustang Evolution
Old 06-03-2010, 09:49 PM   #1
Hi Everyone!
I am a completly new mustang owner, I have a 2010 v6 mustang, I have done quite a few mods and I really want performance cams! I don't know if there even made for the 2010 v6 but any help would be great! Also thinking of switching to 4.10 gear ratio? Comments? Price to install? So far I was told 795 dollars for labor? I'm excited to have joined the forum, thanks for the insight!
Camaro Eater is offline   Reply With Quote
Old 06-03-2010, 10:17 PM   #2
SVTCOBRA's Avatar
Re: 2010 v6 Mustang performance cams??
The only performance cams I know about for the 4.0 V6 is offered by SuperSixMotorSports. But they also suggest buying their heads as well. I keep debating over doing this. But SuperSixMotorSports is the only one I know of.
here is a link to their products
http://www.supersixmotorsports.com/p...1HeadsCams.pdf
SVTCOBRA is offline   Reply With Quote
Old 06-03-2010, 10:28 PM   #3
Wow! Thank you for the quick reply I will check it out, this forum stuff is fricken cool!
Old 06-03-2010, 10:32 PM   #4
Checked it out, very cool. It claims as you said the need for stage 3 heads... Is it really ness. ? Or can the cams be bought and installed on stock heads?
Old 06-03-2010, 10:50 PM   #5
SVTCOBRA's Avatar
The few people I know that did the cam swap did the head swap too because it was going to be easier to just take the head off and but the new performance head and cam in too. But personally I would because I like to do everything at once.
Old 06-03-2010, 11:12 PM   #6
Thanks for the info!
Old 06-04-2010, 07:12 AM   #7
also your warranty will all be 100% gone if you swap a cams, if you plan to dive into the motor heads/intakes should follow (if they offer any intakes)
Old 06-04-2010, 08:58 AM   #8
Thank you SpectorV for the insight. I need more horses, I have so far bbk intake,jba headers,stack throttle body spacer,demon coil,custom dual exhaust with x pipe and flowmasters, question for you SpectorV how much horses do those bolt ons give me? Oh, also sct tuner is on there. And what can I do to get more horses without forced induction? Do the thing I have on it now void the warranty? Thanks for help! And thank you so much for the welcome, so far this forum is absolutly amazing!
Old 06-04-2010, 11:49 AM   #9
SVTCOBRA's Avatar
Yeah SpectorV brings a good point about your warranty. There is also no after market intake for us six cylinders (or at least not yet).
Old 06-04-2010, 12:24 PM   #10
Yeah, and there's no cali CARB legal throttle body either, bbk has one that fits but CARB is pending, wish I could get more power without forced induction....ideas?
Old 06-04-2010, 06:44 PM   #11
It's sort of tough to squeeze out any more hp's and tq's without diving into the engine or slapping a power adder on. You pretty much have all the bolt ons and the tune...those will be nice supporting mods for a power adder.
Might want to consider some suspension and drivetrain work. Gears and a tlok are great mods for the v6's. I see you mentioned 4.10's...if you have an auto than 4.10's would be the tallest you'd want to go. 3.73's if your a manual. Also the 7.5" tlok will give traction to both wheels and provide better launches. (+ 2 wheel burnouts )
Also, suspension work ~ springs, CC plates, shocks/struts, swaybars, strut tower brace, etc. won't give you any hp, but will help get that power in line and get you moving/handling better.
Old 06-04-2010, 07:36 PM   #12
Thats awesome thank you all for all your knowledge and expertise! As I continue I will have more questions I'm sure, as a matter of fact I just posted another that I would love help with, its regarding a tuner and oil temp.???
It seems and I may be imagining things here, that my oil temp is slightly higher? Is that a normal tuner thing?? Any help would be great!
Old 06-04-2010, 07:42 PM   #13
SVTCOBRA's Avatar
You could also bore and stroke the block to 4.2L and do the head and cam swap. With high compression too.
Old 06-04-2010, 08:55 PM   #14
hottcobra's Avatar
Why not get a power adder?
Old 06-04-2010, 09:31 PM   #15
Hi there! Thanks for the continued help! I just installed today a SCT power tuner, I also have the JBA headers, BBK CAI, Stack throttle body spacer, Stack strut tower bar, Demon coil, performance spark plug wires (Does the coil and wires help with anything??) And thats what I got on it! Any other bolt on power adders? I was thinking underdrive pulleys and of course gear ratio to 4.10 if I can find someone to do it for a reasonable price. Any comments on what is the next step here for power? Thanks again I need all the help I can get!
v6 mustang
2010 v6 Mustang performance add ons? Camaro Eater Pre-2005 V6 Mustang 3 06-04-2010 07:01 PM
stage 2 patriot performance heads an cams o3mustangGTafs 1996-2004 Mustang GT 3 09-06-2006 05:42 PM
02:23 AM
