2011 5.0 Forged? - Mustang Evolution
Old 06-25-2010, 09:05 PM   #1
2011 5.0 Forged?
Does the new 2011 5.0 come with forged internals or not? Ive heard the crank and rods are forged and the pistons are not. I dont see why they wouldnt just forge the pistons as well if thats the case. Seems like they wouldve done that before the crank. And I hear the rods are still the weak point. Also, if the internals are forged, what would hold these engines back? Do they have a higher compression ratio? Just wondering.
tigerfan2771 is offline   Reply With Quote
Old 06-26-2010, 01:20 PM   #2
a3705872's Avatar
Re: 2011 5.0 Forged?
They have high compression ratio, it's 11:1 which puts a damper on running a high boost psi. Most are using about 5-6 lbs of boost due to the ratio. Rumor has it that Ford will use direct injection in 2012, which should solve the compression issue and a bump up in HP, but that's just speculation. I don't think the pistons are forged because they used some type is special coating that is used in the ecoboost engines.
a3705872 is offline   Reply With Quote
Old 06-26-2010, 07:00 PM   #3
Loc: Austin,TX
2011 to piss of 2010 owners now the 2012 could be better to piss off the 2011 owners.....lmao!
Old 06-28-2010, 01:16 PM   #4
nope they have crappy internals, the crank might be forged but I doubt it... basically they wont take much boost with the high compression, about like 96-98 cobras did (maybe a bit more boost)
Old 06-28-2010, 03:41 PM   #5
I dont see the point of the crank being forged if the rods and pistons arent. Oh well, sounds like Ford screwed the aftermarket with this one.
Old 06-28-2010, 07:09 PM   #6
MrTibbij's Avatar
Send a message via AIM to MrTibbij
I read an article in one of the auto mags about the 2011 5.0 which stated that the ford performance division said that a stock engine could take about 10 pounds of boost without touching the internals. This was a quote, but I wish i could find the article again. If I do I will post it, just an observation, but no I do not think the internals are forged.
MrTibbij is offline   Reply With Quote
Old 06-29-2010, 07:43 AM   #7
manual mach 1's have forged cranks and nothing else~
I think 10 psi is possible if the tune is dead on, should top the motor out around 500-550rwhp~
Old 06-29-2010, 05:51 PM   #8
MrTibbij's Avatar
Im liking that number =) but i think i am gonna keep it n/a
Old 06-29-2010, 06:17 PM   #9
Arent the rods the weakest link? And then the pistons? Why would they just have a forged crank? Not disagreeing, just wondering why.
Old 06-30-2010, 08:26 AM   #10
no idea why they did it~ im sure it makes it stronger somehow
Old 07-01-2010, 01:52 AM   #11
02MGGT's Avatar
You gotta remember Ford had to mortgage everything stay alive. Engine programs are expensive, they had to work with-in a limited budget.
I be Trollin' Mon
02MGGT is offline   Reply With Quote
V6KR - Stroked/Forged/Blown 4.2L 2002 James02Mustang Pre-2005 V6 Mustang 59 11-20-2010 07:41 PM
True Forged Mach 5's on the Car! SpectorV Pictures and Videos 24 04-24-2009 03:54 PM
02 mustang gt>forged cobra swap,t56, $10,000 SimplyOrange Mustangs for Sale and Wanted 44 10-08-2008 02:19 PM
Last year of forged pistons in 5.0? bullitt482 1979-1995 Mustang GT 7 04-28-2006 08:00 AM
Would these Forged Pistons work with a 4.2L block? Brent Pre-2005 V6 Mustang 17 06-22-2004 03:06 PM
12:18 PM
