Side window Louvers - Mustang Evolution
Old 12-11-2010, 06:02 AM   #1
M3hunter's Avatar
Question Side window Louvers
Does someone has DG Custom side window Louvers or simillars? Can you see out through the openings while you are driving?, Your color match, was simillar to the car paint?
2011 GT Premium, Brembo, 3.73, KONI STRT, Steeda Sport springs, GT500 strut mounts, Strano's adjustable swaybars, 275/40R19 Michelin Pilot Super Sport, HAWK HPS, ATE DOT 4, CS style rear pedestal spoiler, AM Eleanor side scoops, "C style" side decals, Black BOSS style roof vinyl, black custom hood vinyl & Black pony.
M3hunter is offline   Reply With Quote
Old 12-11-2010, 07:56 AM   #2
Re: Side window Louvers
Give SD Mustang Accessories a try.
msgt46270 is offline   Reply With Quote
Old 12-11-2010, 05:34 PM   #3
stang1's Avatar
Thumbs up Re: Side window Louvers
I have them. The color matched perfectly and you can see out the windows with no problem. They really look GOOD!
stang1 is offline   Reply With Quote
Old 12-12-2010, 08:35 AM   #4
M3hunter's Avatar
Thanks for the advice Stang1. Do you have pictures of them in your car?
Old 12-13-2010, 08:27 AM   #5
silverhorse racing has the best ones ive seen
Old 12-13-2010, 05:36 PM   #6
M3hunter's Avatar
I know, but that will mean, that I have to remove and replace my back windows, and that is something I don't want to do, because after that I might have wind noise if I do the change.
Old 12-14-2010, 07:49 AM   #7
if you dont want to remove the rear windows then you are stuck with the stick on or screw on units from the aftermarket
Old 12-18-2010, 07:58 AM   #8
I did it to my car and no wind noise. I did have problems but not SHRing fault or the louvers at all. I bought a set off Craigslist or a forum and when I took it in to get painted, the dumb azz painted the inside of the louver. They paint the outside and painted the inside black. I install the louvers and a friend riding in the back tells me there is wind noise. I check it out later and I was lucky not to lose the louvers. The bonding stuff wasn't sticking to the louvers because of the paint. So I pulled off the louvers and yes pulled off, that easy. Removed the paint and applied more bond stuff and now no problem.
If your going to get these, have SHR paint them too. I had to get mine paint two time before they were done right.
Old 12-18-2010, 09:39 AM   #9
stang1's Avatar
I had mine painted when I ordered them. They are only painted your car color on the outside and the inside is unpainted black plastic. I cleaned the window with alchohol before application. I have had mine on for ten months now and no problems.
Old 12-18-2010, 10:09 AM   #10
M3hunter's Avatar
Thanks for the suggestion Guys
Side Window Louvers ridenmystang Mustang Audio & Video 13 05-23-2007 05:49 PM
Back window louvers? BGomez Pre-2005 V6 Mustang 25 01-04-2007 05:22 PM
Roush rear side window louvers and hood scoop, installed now! Rick0636 Pictures and Videos 17 05-23-2006 11:40 PM
Rear window louvers WhiteStang99 Mustang Audio & Video 84 05-04-2006 04:55 PM
window louvers jimmy_beaner Mustang Audio & Video 10 03-21-2006 10:04 AM
11:23 AM
